| New Reply |
The area form of a Riemannian surface |
Share Thread | Thread Tools |
| Oct17-12, 08:04 AM | #1 |
Let $$(M,g)$$ be an oriented Remannian surface. Then globally $$(M,g)$$ has a canonical area-2 form $$\mathrm{d}M$$ defined by $$\mathrm{d}M=\sqrt{|g|} \mathrm{d}u^1 \wedge \mathrm{d}u^2$$ with respect to a positively oriented chart $$(u_{\alpha}, M_{\alpha})$$ where $$|g|=\mathrm{det}(g_{ij})$$ is the determinant of the Remannian metric in the coordinate frame for $$u_{\alpha}$$.
Let $$u^{i}=\Phi^{i}(v^1,v^2)$$ be a change of variables (so $$\Phi: V \to U$$ is the diffeomorphism of the coordinate change). Calculate the effect on $$\sqrt{|g|}$$ and $$\mathrm{d}u^1 \wedge \mathrm{d}u^2$$ to prove $$\mathrm{d}M$$ is independent of the choice of positively oriented coordinates. |
| Oct17-12, 09:46 AM | #2 |
The intelligible way to introduce the canonical volume form dM on a riemannian manifold is by declaring it to be the top form that takes the value 1 on any positively oriented g-orthonormal basis. This is obviously well-defined simply because the transformation matrix btw any 2 such basis is an element of SO(n) which has determinant 1. Then, we may ask what is the local expression of this form in terms of local coordinates u.
For this, pick an arbitrary positively oriented g-orthonormal basis v. Then [tex]dM=\det(A)du^1\wedge ... \wedge du^n[/tex] where A= "transformation matrix from basis ∂/∂u to basis v" = (g(∂/∂ui,vj)). On the other hand, go ahead and compute gij=g(∂/∂ui,∂/∂uj) to be AČ. Thus conclude that wrt local coordinates, dM has the form from your definition. |
| Oct17-12, 05:03 PM | #3 |
I got $$\mathrm{d}u^1 \wedge \mathrm{d}u^2=\mathrm{det}(\Phi) \mathrm{d}v^1\wedge\mathrm{d}v^2$$. I also know $$g_{ij}=\langle \frac{\partial}{\partial u^i} \frac{\partial}{\partial u^j} \rangle$$, moreover, for a surface $$f: U \to \mathbb{R}^3$$ the components of its first fundamental form $g$ after a change of variables $$u=\Phi(v)$$ becomes $$g'_{ij}(v)=\frac{\partial u^k}{\partial v^i}\frac{\partial u^l}{\partial v^j}g_{kl}(\Phi(v))$$. But I don't know how to apply chain rule to the expression $$g_{ij}=\langle \frac{\partial}{\partial u^i} \frac{\partial}{\partial u^j} \rangle$$ which is not related to any $$f$$?
| Oct18-12, 02:46 AM | #4 |
Followed by Willie's hint. Write $$u^1=u^1(v^1,v^2)$$ and $$u^2=u^2(v^1,v^2)$$ to get $$\mathrm{d}u^1 \wedge \mathrm{d}u^2=\mathrm{det}(A)\mathrm{d}v^1 \wedge \mathrm{d}v^2$$where $$A:=\begin{vmatrix}\frac{\partial u^1}{\partial v^1}&\frac{\partial u^1}{\partial v^2}\\ \frac{\partial u^2}{\partial v^1}&\frac{\partial u^2}{\partial v^2}\end{vmatrix}$$ is the Jaobian for $$\Phi$$
Denote the new Remannian metric by $$g'$$ and apply chain rule to get $$g'_{ij}=g_{kl}\frac{\partial u^k}{\partial v^i}\frac{\partial u^l}{\partial v^j}.$$ Which is equivalent to $$(g'_{ij})=(A)(g_{ij})(A)^t$$, take determinant on both sides yield $$|g'|=|A|^2|g|$$. Now $$\mathrm{d}M=\sqrt|g'| \mathrm{d}v^1 \wedge \mathrm{d}v^2=|A|\sqrt|g|\frac{1}{|A|}\mathrm{d}u^1\wedge\mathrm{d}u^2= \sqrt|g|\mathrm{d}u^1\wedge\mathrm{d}u^2$$ |
| Oct18-12, 08:34 AM | #5 |
Well done!
| New Reply |
| Thread Tools | |
Similar Threads for: The area form of a Riemannian surface
| Thread | Forum | Replies | ||
| Surface area of a beaker of water w/ surface tension? | Chemistry | 1 | ||
| Maximum Surface Area of a Flat Surface | Classical Physics | 27 | ||
| Polar Regions: Area, Arc Length, and Surface Area | Calculus & Beyond Homework | 2 | ||
| Surface Area of of an area - parametric surface | Calculus & Beyond Homework | 34 | ||
| Riemannian volume form without local coordinates | Differential Geometry | 10 | ||
