Theoretical gage factor for resistive wire strain gages?
The sensitivity of resistive wire strain gauges to applied strain is modeled by the gage factor, defined as K = (ΔR/R) / (ΔL/L). According to Eugene Frank's 1946 pamphlet, the theoretical gage factor for stretched wire is 1.7, but actual measurements show a significantly higher factor of around 20 for commonly used Advance wire. Frank's model attributes changes in resistance to both the length and diameter alterations of the wire during stretching, maintaining constant volume as dictated by Poisson's ratio. The discussion highlights the discrepancy between theoretical predictions and practical measurements, emphasizing the complexities involved in accurately predicting strain sensitivity. Understanding these factors is crucial for improving the design and application of strain gauges.
Stephen Tashi
Homework Helper
Education Advisor
What model correctly predicts the sensitivity of a resisitive wire straing gage to applied strain?
This question is motivated by an an old pamphlet found in a used book store, "Theory Of Strain Gage Flight Test Instrumentation" by Eugene Frank, 27 May 1946.
The gage factor of a strain gage made from resistive wire is defined as
K = \frac{\triangle R/ R}{\triangle L/L}
where R is the total resistance of the un-strained gage, L is the total length of un-strained "the specimen" being measured and the deltas are the respective changes in these quantities when a load is applied.
Frank says:
Theoretically, the stretched wire length under discussion should have a strain sensitivity or gage factor of 1.7 due to the geometric change during the stretching process as mentione above. Actually, for reasons unknown, measured strain sensitivity factors differ from the theoretical. For Advance wire, which is most commonly used for strain gauge wire ( 45% Ni & 55% Cu) the gage factor is approximately 20.
Frank's model assumes the change in resistance of the wire is entirely due to the change in the length and diameter of the wire as it is stretched.
When a wire is stretched elastically, its length changes and so does its diameter. To keep the wire's volume constant, its diameter will diminish by a factor of 0.3 as its length increases, corresponding to Poisson's ratio. The electrical resistance of a wire is affected by both the changes in length and in diameter.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
