Thread Closed
Julian Barbour on does time exist
Share Thread Thread Tools
Nov26-12, 05:21 PM   #86
Quote by marcus View Post
If one accepts GR then the decay of a radioactive nucleus will affect the geometry of the universe (as the distribution of mass always does, in GR) and according to QM the time when the nucleus will decay has not yet been determined (unless you postulate "hidden variables") and cannot in principle be predicted. Thus the geometry (the metric) of the universe is not predetermined.
So if one accepts ordinary physics (GR and QM) there can be no block universe.
George Ellis put this amusingly in his FQXi essay that I linked to above. He described a massive rocket powered sled zooming back and forth along a track under the control of a radioactive decay (Schrödinger Cat) mechanism that tells it when to go east and when to go west.
The hidden variable problem goes away in a Block Universe; nothing remains to be determined because it already exists. The unknown variables are hidden from us locally but reside local to the respective particles in the future. "When" a nucleus decays relative to an observer is a problem of information availability, not some intrinsic Universal randomness.
I emboldened the words in your post which show that we have problems thinking without a "flow of time". Technically, neither GR nor QM have any mechanism for a FLOW of time whatsoever. They are completely time-symmetric theories, yet you are suggesting that one direction is preferred over the other. The time parameter is only a marker along the 4D Block Universe in my view.
Nov26-12, 05:29 PM   #87
Recognitions:
Gold Membership Gold Member
Quote by rjbeery View Post
nothing remains to be determined because it already exists...
You are on your own, RJ. Working physicists assume QM. Your picture is incompatible with QM. I've tried explaining this to you but it doesn't seem to get across.
How about you read a few pages of Rovelli's wide-audience essay Unfinished Revolution, that I suggested you look at earlier?
Section 1.2 "Time" is less than a page long. It starts at the bottom of page 3 and covers part of page 4.
Google "rovelli unfinished revolution" and you get the arxiv version: http://arxiv.org/abs/gr-qc/0604045
Nov26-12, 05:39 PM   #88
I will, and I will also read George Ellis' FQXi essay but I could not find your link to it. I assume I can Google it without much problem. Regardless, I'm not speaking from a position of naivete; QM is not incompatible with Block Time and I'd be happy to discuss specifically why you think this (other than referencing others' papers).
Nov26-12, 05:47 PM   #89
Recognitions:
I gave the link in the post I pointed you to:
http://fqxi.org/community/essay/winners/2008.1
go there, scroll down to "second community prize", there is Ellis's abstract and a link to the PDF.
I already explained the incompatibility using the same example Ellis did, radioactive decay changes the distribution of mass---Ellis's rocket sled just makes it more colorful.
Nov26-12, 06:07 PM   #90
Recognitions:
I need to plug ahead with how time (as a flow on the observable algebra) emerges. For continuity, here are the essentials of the last post:
Given an algebra A of observables and a state of the world ω it is possible to derive a unique flow αt on the algebra. Taking each observable A into a progression of "later" evolved observables αtA, for every timeparameter number t.
A nice thing is that this "thermal time" construct RECOVERS ordinary time when we start with a conventional Hamiltonian H and hilbertspace H. this is what Connes Rovelli show on pages 16 and 17 of their paper. See link:
Sources
http://arxiv.org/abs/gr-qc/9406019 pages 16,17
WikiP: "Gelfand-Naimark-Segal construction"
WikiP: "KMS state"
WikiP: "Tomita-Takesaki theory" (not so good I think, but at least article exists)
WikiP: "Polar decomposition" (article exists, I haven't used or evaluated it)
The basic situation that general covariant quantum physics deals with is an algebra A of observables. That's the world. After all QM is about making measurements/observations. And a temporal flow αt is a oneparameter group of automorphisms of that algebra.
automorphism means it maps an observable A onto another observable αtA which you can think of as making the same observation but "t timeunits later".
oneparameter group means that doing αs and then doing αt has the same flow effect as doing αs+t. the parameter t is a real number.
And automorphism means it preserves the algebra operations, it is linear etc etc.
Observables are in fact an algebra because you can add and multiply observables together to predict other observables or to find how they correlate with each other.
The statistical quantum state of the world is represented by a positive functional on the algebra which we can think of as a density matrix ω and its value on an observable A can be written either as ω(A) or as trace(Aω). The state ω is what gives the observables their expectation values and their correlations.
A nice thing about a density matrix ω is that it has a square root ω1/2. Think of writing it as a diagonal matrix with all positive entries down the diagonal, and taking the square root of each entry.
The observable algebra (think matrices) IS a vector space. You can add matrices entry-wise and so on. The celebrated GNS construction makes a vectorspace out of |ω1/2⟩ together with all the other density matrices and their like which you can get by applying elements A of the algebra to that root vector. that is called the FOLIUM of ω
|Aω1/2⟩ for all A in A
It is a hilbertspace. The special good things about this hilbertspace (they give it a name, K) is that the algebra acts on it, after all it was MADE by having the algebra act on the single root vector |ω1/2⟩ and seeing what you get, and the other thing is just that: it has what is called a "cyclic vector", a root or generator: the whole hilbertspace is made by having the algebra of operators act on that one |ω1/2⟩, as we have seen.
ω(A) = ⟨ω1/2|A|ω1/2
Now what C&R do is they construct an operator, by giving its polar decomposition. This is what happens on page 17. And the operator obtained by putting the polar decomp. together has the effect of doing a matrix transpose, or mapping A → A*. They call this operator S.
SA |ω1/2⟩ = A* |ω1/2
There is some intuition behind this (there is already something about it on page 7 but I'm looking at page 17). It is like swapping creation and annihilation operators. Undoing whatever an operator does. Partly it is like getting your hands on what is implicitly an infinitesimal time-step, except there is no time yet. More importantly, transpose is tantamount to commuting
(AB)* = B*A*
So if we can just take the anti-unitary part out of the picture it's almost like swapping order: AB → BA. Yes very handwavy, but there is some underlying intuition, will get back to this.
We are going to build from that swapping or reversal operator S. In particular we will use the positive self-adjoint part of the polar decomposition. More about this later.
Nov26-12, 07:35 PM   #91
OK, I read Ellis' paper and I'm not seeing his point or the problem with the rocket sled. Any macro-scale process which is dependent upon an apparently random quantum process can be time-reversed in the same way that thermodynamic systems are: an extraordinarily unlikely series of physically plausible events "conspire" to make it happen.
Did I drop the glass on the floor to watch it shatter, or did the heat in the floor molecules synchronize at precisely the right moment to make the shards jump into the air, coalesce and fuse into a proper glass shape, flying up onto the table only to be stopped by my hand? Equivalently, did ongoing radioactive decay make the sled change directions, or did rogue alpha particles bombarding our nucleus-switch cause the direction changes?
Ellis' arguments are basically all Epistemological in nature. He is trying to tie a preferred direction of time to the fact that we apparently only know things about the past. He says
Quote by Ellis' paper
A closely related feature is the crucial question of time irreversibility: the laws of physics, chemistry, and biology are irreversible at the macro scale, as evidenced inter alia by the Second Law of Thermodynamics, even though the laws of fundamental physics (the Dirac equation, Schroedinger’s equation, Maxwell’s equations, Einstein’s field equations of gravity, Feynman diagrams) are time reversible. This irreversibility is a key aspect of the flow of time: if things were reversible at the macro scale, there would be no genuine difference between the past and the future, and the physical evolution could go either way with no change of outcome; both developments would be equally determined by the present. The apparent passage of time would have no real consequence, and things would be equally predictable to the past and the future.
He claims that the macro scale events are irreversible* via the Second Law of Thermodynamics, therefore time flow exists in one direction. The problem is that entropy only increases until equilibrium is reached! What would Ellis say about time flow direction in a theoretical Universe in systemic thermal equilibrium?
*As I'm sure you are aware, the Second Law of Thermodynamics is a tendency or likelihood, not a law. Is Ellis suggesting that the preferred direction of the flow of time is also a mere likelihood? This is a spurious argument.
Nov27-12, 08:08 AM   #92
Marcus, Your sequence of posts 80, 85,90 are really helpful in following what Connes and Rovelli are doing. Hope you continue with them. One point I'm not clear on. In Rovelli's recent paper (1209.0065), he remarks that "The root of the temporal structure is thus coded in the non commutativity of the Poisson or quantum algebra” (near the end of p.1). The "thus" puzzles me. Is it indeed obvious?
Nov27-12, 08:40 AM   #93
Recognitions:
Quote by Paulibus View Post
No it's not obvious, to me at least. Instead it strongly piqued my curiosity.
I am beginning to understand now (but keep in mind that I am not an expert or an active researcher, I just watch developments and hopefully comprehend a bit of it.)
When the world is an algebra of observables then it HAS to be that the temporal structure is coded in the non-commutativity because it is coded in the fact that it matters which observation you make first.
And when we look at the Tomita construction and the KMS condition what we see is a mathematical struggle involving the study of AB versus BA. Like combing the flow out of a tangled head of noncommutative hair. I will get a page reference to Connes Rovelli that illustrates.
I'm so glad you are interested in this too! We'll certainly continue working thru it, as you suggest. My intuition now is that noncommutativity of measurements or observation has within it the essence of timeflow, but that I just need to study the stuff some more to see how.
A page reference. Try Connes Rovelli page 13 equation 23. The important thing is not to get bogged at the start by trying to grasp every little math detail but to see the main thing they are doing. They are invoking the "KMS condition". The state ω is a functional on the observables and it has the property that ω(AB) is almost the same as ω(BA). In fact it would give exactly the same number if you apply the TIME EVOLUTION flow gamma to A slightly differently. You can compensate for swapping the order if you "skootch" A by a little in the time-evolution.
This equation 23 is the KMS condition which you also see as the last equation in the WikiP article "KMS State" where they say that a KMS state is one satisfying a certain "KMS condition" which is verbatim the same as equation 23.
Intuitively IMHO, KMS condition gives a way of defining a steady state which is somehow more generally applicable than older ways, but which reduces back to, say, Gibbs idea of equilibrium where that is applicable. The people who showed you could recover the older idea from KMS have names like Haag Hugenholtz Winnink. The S in KMS stands for Julian Schwinger, who shared the QED prize with Feynman. KMS dates back to late 1950s. this is just nonessential human interest stuff but it sometimes helps
Nov28-12, 12:30 AM   #94
Quote by Marcus
This is what I had concluded also, sketched in a doggy sort of way below. But must an algebra of observables be non-commutative? and if so, why? Two reasons seem possible to me.
One (rather special); is because one chooses to describe the world in a quantum mechanical context, where congugate observables are (still mysteriously?) non-commutative.
Two (more generally); because the world is three-dimensional, for any context we find useful to quantify and describe change in, such as QM and GR.
I speculate that scalar changes of physical quantities in one dimension are perforce commutative, and that in two dimensions the same is true; the order in which like quantities (say vectors) are added doesn't matter (parallelogram law). But in three dimensions non-commutative change becomes possible (like successive rotations about non-colinear axes, described by adding polar vectors or tensors).
Does non-commutative change only happen in three dimensions, which we seem (still mysteriously) to be endowed with? And could GR's pseudo-dimensional time emerge in the way Connes and Rovelli postulate just because we live in three spatial dimensions ?
Nov28-12, 03:35 AM   #95
In checking KMS state in Wikipedia, I noticed that George Green is in the background. George was a self-educated younger contemporary of Jane Austen's. I'm fearful whenever his functions are involved in something; there was genius in the water they drank in those far-off days. Just non-essential human interest stuff which guides my wary path!
Nov28-12, 09:20 AM   #96
Recognitions:
I wish she could have met Sadi Carnot b. 1796, whose book Réflexions sur la puissance motrice du feu was published while he was still in his twenties. He was another younger contemporary. Here is a portrait:
http://en.wikipedia.org/wiki/Nicolas...rd_Sadi_Carnot
Sense and Sensibility (1811), Pride and Prejudice (1813), Mansfield Park (1814), Emma (1816)
Reflections on the Motive Power of Fire (1824)
Nov30-12, 04:14 PM   #97
Recognitions:
I should keep on developing the thermal time idea, as in posts #90. 92, 93... I got distracted elsewhere and left the job half done. Thanks to Paulibus for help and encouragement!
I will include plenty of links to source and background articles e.g. from WikiP
http://en.wikipedia.org/wiki/Gelfand...l_construction
I'm not an expert and can't be completely sure my take on every point is correct. But it seems to me that the GNS construction is the key thing.
Observables form an abstract normed algebra of the C* type. Most basically an algebra is something with addition and multiplication. Think of a bunch of n x n matrices over ℂ. The matrices themselves form a n2 dimensional vectorspace.
Starting with an algebra you can CONSTRUCT a vectorspace that the algebra acts on.
GNS is a slightly more refined version. You start with an algebra [A] with a specified positive linear functional ρ defined on it. Think of a density matrix, a generalized "state".
ρ(A) is the complex conjugate of ρ(A*).
GNS construction gives you a hilbertspace [H] with the algebra ACTING on it and a CYCLIC VECTOR ψ in [H] such that
ρ(A) = ⟨ψAψ⟩
and I'll explain what a cyclic vector is in a moment. That one vector can generate the whole hilbertspace.
Two things to stress: The construction gives us a REPRESENTATION of the abstract [A] as a bunch of operators acting on the constructed [H]. It is just as if the algebra were not abstract but all along consisted of ("matrices" i.e.) operators on the hilbertspace. GNS tells algebras they don't have to be abstract if they don't want---we can always build a good hilbertspace for them to act on where they'll feel completely at home, as operators.
The other thing to stress is what a cyclic vector is. Essentially it means that the whole hilbertspace can be gotten just by acting on that one vector ψ by elements A of the algebra---and taking limits if necessary, the set [A]ψ is dense in [H].
Intuitively GNS works this way: you make the hilbertspace by considering [A] itself (the "matrices") as a vectorspace and factoring out stuff as needed. So any "matrix" can be considered both as a vector or an operator on the vectors. And the original state functional, the "density matrix" ρ, well intuitively we can take its square root and that will be a square matrix and therefore can be viewed as the vector ψ. That's basically where the cyclic vector ψ comes from and why ρ(A) = ⟨ψAψ⟩.
So far we are just using the GNS construction. Thanks to Mssrs Gelfand Naimark Segal for the goodies. Now the next key step is to define an operator S on [H] using the cyclic vector. For every A in [A] we consider the vector Aψ and we say what S does to that.
SAψ = A*ψ
That defines SA adequately because the vectors Aψ are dense in the hilbertspace.
It's called "anti linear" or "conjugate linear" because in multiplying the source by a scalar converts into multiplying the target by its complex conjugate. The * operation is conjugate linear in that sense and it carries over to S.
Next we take the polar decomposition of S.
http://en.wikipedia.org/wiki/Polar_decomposition
It is a piece of that POLAR DECOMPOSITION that gives us thermal time.
(This is how thermal time arises, from nothing but an abstract algebra and a statistical state defined on that algebra.)
There's a encyclopedia article on Tomita-Takesaki business: S and it's polar decomp. etc:
http://arxiv.org/abs/math-ph/0511034
the first couple of pages seem enough. It is pretty basic and clearly written.
It's from the Ensevelier Encyclopedia of Mathematical Physics.
Nov30-12, 09:17 PM   #98
Recognitions:
Before proceeding to derive the thermal time flow from that operator S mentioned at the end of the preceding post, I should review some of the motivation. TT is general covariant which other kinds of physical time are not. And yet it agrees with regular physical time in several specialized cases.
I'll quote from post #74 earlier where these were mentioned.
http://www.physicsforums.com/showthr...88#post4171588
This is paraphrasing the Connes Rovelli paper which has 77 cites, over a third of which are in the past 4 years. So it is fairly well known and still probably the best source on TT definition and basics.
==quote post #74==
... I'll run down the main corroborative cases they give on page 22, in their conclusions. These are explained in the preceding section, pages 16-21.
== quote http://arxiv.org/abs/gr-qc/9406019 ==
Classical limit; Gibbs states. The Hamilton equations, and the Gibbs postulate follow immediately from the modular flow relation (8).
Classical limit; Cosmology. We refer to [11], where it was shown that (the classical limit of) the thermodynamical time hypothesis implies that the thermal time defined by the cosmic background radiation is precisely the conventional Friedman-Robertson-Walker time.
Unruh and Hawking effects. Certain puzzling aspects of the relation between quantum field theory, accelerated coordinates and thermodynamics, as the Unruh and Hawking effects, find a natural justification within the scheme presented here.
==endquote==
They also include three other supporting points. One that is not discussed in the paper and they simply mention in passing is the widely shared notion that time seems bound up with thermodynamics and there are indeed hundreds of papers exploring that general idea in various ways (far too numerous to list). Their idea instantiates this widely shared intuition among physicists.
Another supporting point is that the thermal time formalism provides a framework for doing general relativistic statistical mechanics. Working in full GR, where one does not fix a prior spacetime geometry, how can one do stat mech? A way is provided here (and see http://arxiv.org/abs/1209.0065 )
The sixth point is the one they give first in their "conclusions" list---I will simply quote:
==quote gr-qc/9406019 page 22==
Non-relativistic limit. In the regime in which we may disregard the effect of the relativistic gravitational field, and thus the general covariance of the fundamental theory, physics is well described by small excitations of a quantum field theory around a thermal state |ω⟩. Since |ω⟩ is a KMS state of the conventional hamiltonian time evolution, it follows that the thermodynamical time defined by the modular flow of |ω⟩ is precisely the physical time of non relativistic physics.
==endquote==
There is one other supporting bit of evidence which I find cogent and which they do not even include in their list. This is the uniqueness.
==endquote==
So there is the uniqueness of TT
and the fact TT independent of arbitrary choices, all you need is the algebra of observables (the world) and a positive linear functional defined on it (the state of the world: our information about it.) You don't have to choose a particular observer or fixed geometry
and the fact that TT recovers the time that cosmologists use--standard universe time in the standard cosmic model.
and the fact that TT recovers ordinary physics time when you specialize to a NON general covariant case---with a Hamiltonian and the Hilbert space of usual QM.
and other good stuff that Connes and Rovelli mention.
That all makes me tend to think that this is a good way to get your basic time. It is set up as a ONE-PARAMETER FLOW operating on the OBSERVABLES ALGEBRA.
The flow is denoted αt where t is time, and it carries any given A in [A] into subsequent observables αtA.
Dec1-12, 11:54 AM   #99
Recognitions:
The hang-up some people say they have about the TT hypothesis centers on the word "equilibrium". The root meaning here is "balanced" but the STATE that we are talking about is "4D" or timeless. It represents how we think the world is. Period. Including all physical reality past present and future. So naturally it does not COME into equilibrium. Ideally it simply IS how it is. Our idea of how the world is must not change with time and therefore it is in balance---an equilibrium state.
(But people have a mental image of something "arriving" at equilibrium---imagined as a state at a certain time. That's the wrong way to think about a timeless state.)
I think the way to understand TT is as the logical completion of the Heisenberg picture. You could call it "general covariant Heisenberg time". In the Heisenberg picture the world is an algebra of observables and there is just one state. The hilbertspace is not essential, you only use one state in it and you can throw away the rest. The hilbertspace was used, historically, to construct the algebra, but once you have the algebra you can discard it and you will always be able to recover that sort of representation (by GNS) from the algebra itself. That one state vector that you keep is really just a positive linear functional on the algebra. Something that assigns expectation values to observables.
And once we have specified [A] and the state functional ρ we automatically get a flow αt on the algebra, by Tomita. The idea of global time is given automatically independent of any observer or any assumption about background geometry.
The best independent critical commentary on TT which I have seen is by the mathematician Jeff Morton (Baez PhD and Baez co-author now at Lisbon). You can see that he gets hung up on what I believe is the wrong "equilibrium" notion. But he has otherwise a very clear assessment. His insight helped me when I was confused earlier about the TT. This is from his blog "Theoretical Atlas" October 2009. I've added an exponent 1/2 to align his notation with other sources used in this thread. He uses ω, instead of ρ, for the state.
==quote Jeff Morton==
First, get the algebra [A] acting on a Hilbert space [H], with a cyclic vector ψ (i.e. such that [A]ψ is dense in [H] – one way to get this is by the GNS representation, so that the state ω just acts on an operator A by the expectation value at ψ, as above, so that the vector ψ is standing in, in the Hilbert space picture, for the state ω). Then one can define an operator S by the fact that, for any A in [A], one has
(SA)ψ = A*ψ
That is, S acts like the conjugation operation on operators at ψ, which is enough to define since ψ is cyclic. This S has a polar decomposition (analogous for operators to the polar form for complex numbers) of JΔ1/2, where J is antiunitary (this is conjugation, after all) and Δ1/2 is self-adjoint. We need the self-adjoint part, because the Tomita flow is a one-parameter family of automorphisms given by:
αt(A) = Δ-itit
An important fact for Connes’ classification of von Neumann algebras is that the Tomita flow is basically unique – that is, it’s unique up to an inner automorphism (i.e. a conjugation by some unitary operator – so in particular, if we’re talking about a relativistic physical theory, a change of coordinates giving a different t parameter would be an example). So while there are different flows, they’re all “essentially” the same. There’s a unique notion of time flow if we reduce the algebra [A] to its cosets modulo inner automorphism. Now, in some cases, the Tomita flow consists entirely of inner automorphisms, and this reduction makes it disappear entirely (this happens in the finite-dimensional case, for instance). But in the general case this doesn’t happen, and the Connes-Rovelli paper summarizes this by saying that von Neumann algebras are “intrinsically dynamic objects”. So this is one interesting thing about the quantum view of states: there is a somewhat canonical notion of dynamics present just by virtue of the way states are described. In the classical world, this isn’t the case.
Now, Rovelli’s “Thermal Time” hypothesis is, basically, that the notion of time is a state-dependent one: instead of an independent variable, with respect to which other variables change, quantum mechanics (per Rovelli) makes predictions about correlations between different observed variables. More precisely, the hypothesis is that, given that we observe the world in some state, the right notion of time should just be the Tomita flow for that state. They claim that checking this for certain cosmological models, like the Friedman model, they get the usual notion of time flow. I have to admit, I have trouble grokking this idea as fundamental physics, because it seems like it’s implying that the universe (or any system in it we look at) is always, a priori, in thermal equilibrium, which seems wrong to me since it evidently isn’t. The Friedman model does assume an expanding universe in thermal equilibrium, but clearly we’re not in exactly that world. On the other hand, the Tomita flow is definitely there in the von Neumann algebra view of quantum mechanics and states, so possibly I’m misinterpreting the nature of the claim. Also, as applied to quantum gravity, a “state” perhaps should be read as a state for the whole spacetime geometry of the universe – which is presumably static – and then the apparent “time change” would then be a result of the Tomita flow on operators describing actual physical observables. But on this view, I’m not sure how to understand “thermal equilibrium”. So in the end, I don’t really know how to take the “Thermal Time Hypothesis” as physics.
In any case, the idea that the right notion of time should be state-dependent does make some intuitive sense. The only physically, empirically accessible referent for time is “what a clock measures”: in other words, there is some chosen system which we refer to whenever we say we’re “measuring time”. Different choices of system (that is, different clocks) will give different readings even if they happen to be moving together in an inertial frame – atomic clocks sitting side by side will still gradually drift out of sync. Even if “the system” means the whole universe, or just the gravitational field, clearly the notion of time even in General Relativity depends on the state of this system. If there is a non-state-dependent “god’s-eye view” of which variable is time, we don’t have empirical access to it. So while I can’t really assess this idea confidently, it does seem to be getting at something important.
==endquote==
Jeff Morton's blog: http://theoreticalatlas.wordpress.com
The state (a linear functional on the observables) is what we believe to be timelessly true about the world.
The world is the algebra of observations.
So far this is more or less what Wittgenstein said in chapter 1 of Tractatus. I wonder why the algebra of observables should be normed, and over the complex numbers, and equipped with a conjugate-linear * involution. Why should the world be a C* algebra? (I must be kidding )
See post #65 http://www.physicsforums.com/showthr...56#post4169556
Dec2-12, 03:02 AM   #100
Your series of posts describing how time can be described has been most illuminating for me, Marcus, and it does indeed seem consistent with Wittgenstein's philosophical take that you quoted. Thanks for explaining an abstract perspective that Heisenberg would have appreciated in a way that I could actually make a lot of sense of.
But to be really convincing, even if the world is, as you say, "an algebra of observations", I guess that folk like Barbour, Connes and Rovelli may have to formulate some kind of predictive description, with an aspect that can be verified by physical evidence.
Time, that non-reversible Moving Finger, is a slippery concept to handle, even by mathematically inclined folk with plenty of Wit. I have neither Piety nor sufficient Wit and find myself wondering about really elementary "why" questions to add to your list, like why does Planck's constant exist at all, so making ODTAA a non-commutative process?
I suspect it is because no Operation (One Damn Thing) that happens After Another, does so on a virgin playing field, even if the operation is algebraic and the playing field is as tenuous and ether-like as the cosmic microwave background. Perhaps both the operations and the algebra are only descriptive shadows of reality cast on the cave walls of our minds?
Dec2-12, 03:13 AM   #101
Time, that non-reversible Moving Finger,...
Did you mean to say
Time, those non-reversible Moving Many Fingers,...
Dec2-12, 04:26 AM   #102
Just a quick question, what is the current state of quantum gravity??
Thread Closed
Thread Tools
Similar Threads for: Julian Barbour on does time exist
Thread Forum Replies
Does time exist? General Discussion 56
First post: "End of Time" by Julian Barbour Science Textbook Discussion 0
Time observables (but not time operators) DO exist in QM General Physics 1
[SOLVED] Julian Barbour's "End of Time" Science Textbook Discussion 2
