New Reply
change in speed of the bullet after striking an object
Share Thread
Dec17-12, 03:03 PM   #1
1. The problem statement, all variables and given/known data
A gangster fires a bullet (m1 = 30 g, v1 = 190 m/s) at Stupendous Man (m2 = 31 kg), but it simply bounces away elastically. If Stupendous man was standing on a frictionless surface, what is the change in speed of the bullet after striking stupendous man? Be careful with signs and units!
2. Relevant equations conservation of momentum, mv1+mv2=mv1+mv2
3. The attempt at a solution the man is not moving initially, and final, i got 0.183 for the final bullet speed but thats not right, Iam confused about how to find the final for the bullet?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Dec17-12, 03:49 PM   #2
Mentor
Quote by omc1 View Post
3. The attempt at a solution the man is not moving initially, and final, i got 0.183 for the final bullet speed but that's not right, I am confused about how to find the final for the bullet?
You haven't explained how you got that result, so it's hard to say where you went wrong.
The problem doesn't state the direction in which the bullet bounces away, so I would assume that the bullet goes back toward the location it was fired from.
Did you use the fact that it's an elastic collision ?
Such a problem can often be solved most easily in the center of mass reference frame. If you do, don't round-off anything until your final answer.
Dec17-12, 04:00 PM   #3
i thought i was using the formula for elastic collision, .03*190=.03*V2+31*V2, but I though the man did not move so I am confused about that, how would I apply the cm to this?
Dec17-12, 04:06 PM   #4
Mentor
That is for an inelastic collision. That's evident because you have both the bullet and the man traveling at the same velocity.
Dec17-12, 04:38 PM   #5
but i dont know either final velocity...
Dec17-12, 10:12 PM   #6
Is the answer 0.367ms-1.
Soln:
We have two equations (one from momentum conservation and the other from kinetic
energy conservation) with two variables (final velocities of the bullet and the man).Solve these
two equations and get the final velocity of the man in terms of initial velocity of both and their masses.
The final equation will be:
V=M2U2/(M1+M2)
where M1 is the mass of the man,
M2 is the mass of the bullet,
U2 is the velocity of the bullet.
Dec18-12, 05:22 AM   #7
yes, that is the answer, why is the mass combined because the bullet bounces off.
Dec18-12, 10:42 AM   #8
Mentor
A gangster fires a bullet ...
In your above equation (from your Original Post), you have two unknowns. You need another equation in order to get a solution.
Let's call the final velocity of the man, V2, and the final velocity of the bullet, u2.
The initial velocities being V1 = 0 m/s and u1 = 190 m/s .
Similarly, let M be the mass of the man, M = 31 kg. Let m be the mass of the bullet, m = 30 grams = 0.03 kg.
(I took it upon myself to change some variable names.)
Conservation of momentum gives [itex]\ mu_1+MV_1=mu_2+MV_2\ [/itex] where V1=0, for the (initially) stationary man.
[itex]\ mu_1=mu_2+MV_2\ [/itex]
The other equation you need is from conservation of kinetic energy (It's an elastic collision.)
[itex]\ (1/2)m{u_1}^2=(1/2)m{u_2}^2+(1/2)M{V_2}^2\ [/itex]
New Reply
Similar discussions for: change in speed of the bullet after striking an object
Thread Forum Replies
Angular Motion Of A Bullet Striking A Door Introductory Physics Homework 20
Angle of a bullet striking a solid object Classical Physics 0
Test of power on a swinging mass striking an object Advanced Physics Homework 1
[SOLVED] The speed of a bullet may be determined by allowing the bullet to pass throu Introductory Physics Homework 9
Bullet striking block, maximum height obtained? Introductory Physics Homework 9
