Front air dam on car for mileage?
  • Thread starter Thread starter sc2dave
    Air Car
The discussion centers on the impact of front air dams on vehicle gas mileage, exploring the relationship between aerodynamics and fuel efficiency. Participants examine various factors influencing performance, including speed, drag coefficients, and the design considerations of different car models.
  • Some participants suggest that front air dams can improve gas mileage by enhancing aerodynamics, while others question the extent of this effect, particularly at lower speeds.
  • One participant notes that air resistance is proportional to the square of velocity, implying significant effects at high speeds (over 100 mph), but others argue that drag impacts fuel consumption even at typical highway speeds (around 70 mph).
  • There are conflicting views on the accuracy of calculations regarding power loss due to aerodynamic drag, with some participants providing specific formulas and estimates, while others challenge the assumptions and parameters used in those calculations.
  • Some participants assert that automobile manufacturers prioritize aerodynamics in design, citing examples like the Honda Insight, while others contend that aesthetics often take precedence in the design of certain vehicles.
  • Disagreements arise over the interpretation of drag coefficients and the implications for different car models, with participants providing data to support their claims.
Participants do not reach a consensus on the effectiveness of front air dams for improving gas mileage, nor on the specifics of aerodynamic drag calculations. Multiple competing views remain regarding the influence of speed and design on fuel efficiency.
Some calculations and claims rely on specific assumptions about vehicle parameters and conditions, which may not universally apply. The discussion reflects a range of perspectives on the importance of aerodynamics in vehicle design.
sc2dave
do front air dams help to increase gas mileage a bit?
They can, depending on the car since they affect the aerodynamics.
I don't know how much the air dam effects mileage (though I suspect they do), but I can say that they effect handling. In the past, I have had several Corvairs, and (despite a certain lawyer, who doesn't drive) they are very quick responding, great handling cars - - - as long as the air dam is in place. Without it though, they get squirrely at speed in cross-winds.
KM
PS. Though rear-engine cars are great in the hands of those who understand the feel and intricacies of driving, I wouldn't put one in the hands of a driving 'neophyte'. Oversteer will allow you to do great things handling-wise with a car, but for the uninitiated, it will also allow the driver to get into trouble. That's why front-wheel drive cars are so popular with manufacturers.
Air resistance is proportional to velocity squared. Therefore, if you drive at speeds of about over 100miles/hour, then aerodynamics takes on an effect in a cars preformance and gas mileage, but at lower speeds, the effect is neglegable.
Regards,
Nenad
Where did 100 mph come from? Drag actually does have a significant impact on fuel consumption at regular highway speeds (~70 mph). Total drag might consume up to ~20 hp at that speed, which is significant.
I hope nobody's suggesting breaking any speed limits, especially by significant amounts... :mad:
I don't think so. In an upper limit, the power lost in aerodyn drag can be estimated as:
[tex]W=0.5\rho C_x S U^3=0.5\cdot 1.2 Kg/m^3 \cdot 0.35\cdot 1.5 m^2 \cdot (28 m/s)^3 \sim 7 kW \sim 9 HP[/tex]
at 100Km/h, in a car with frontal area of 1.5 m2, standard air conditions, and aerodynamic drag coefficient 0.35 (medium).
Actually, the vehicle will loose a 8% or less of useful energy wasted in aerodynamic friction. To say the truth, automobile manufacturers don't worry too much about the aerodynamics of low powered cars. The external shape of this kind of cars are dominated by how it looks more than how it aerodynamically works.
Clausius,
While I agree with your calculation, I postulated 70 mph=110 kph, which is actually fairly low for most American highways (despite being above most speed limits). Also, cars popular here tend to be a bit bigger than 1.5 m^2. 20 hp is not unreasonable for a sedan if the parameters are changed slightly.
Your claim about 8% losses is completely incorrect, though. At your estimate of 9 hp lost to drag, that would imply that it requires 110 hp to go 100 kph, which it clearly does not. Manufacturers do worry a lot about aerodynamics. Even the horribly underpowered Prius and Insight have highly optimized shapes. Cars haven't been designed on looks (and packaging) alone for more than 20 years now.
Edit: If you pulled the 8% statement from some website, you might be misunderstanding the wording. As I remember, that's about right for the fraction of aerodynamic drag that arises due to skin friction rather than pressure effects.
Stingray said:
Clausius,
Well, if you want to change the parameters, I will change the whole formula, because it is completely innacurate. The [tex]C_x[/tex] factor is a rough simplification of the car's aerodynamic. It is based on averaged experimental results, on how it is measured the coefficient. Also, it is false that the aerodynamic drag is proportional to the square of the speed.
Well, this is your personal opinion. I don't think so. I don't think that Ford thought too much in aerodynamics when designing the Ford Focus. On the other hand, i do think that Ferrari thinks of aerodynamics indeed. But the purposes of both cars are different.
Also, i didn't understand what you meant in your edit.
Really? I thought it was reasonably accurate (~10%) over 50 mph or so. In any case, my only point was that a large fraction of the power needed to maintain highway speeds is lost to drag.
If you look at the drag coefficients of even the lowliest economy cars over the past thirty years, you'll see a steady downward trend. I don't believe that's accidental.
In the particular case of the Honda Insight - a car whose sole existence is to optimize fuel economy - the engineers spent a great deal of effort getting a 0.25 drag coefficient. As far as I know, that's the lowest of any production car.
Also, the Ford Focus has a better drag coefficient than any Ferrari (but they're more concerned with lift than drag). It's actually as good as older high-end cars that are known to have had extensive aerodynamic development (e.g. MB E-class).
Drag can be split up into two parts. One is roughly independent of the object's length (in the direction of the flow), while the other is not. This latter effect is directly due to viscosity, and as I remember, it is ~10% of the total drag in most cases.
How can you prove that?
Stop writting about aerodynamics. This statement proves you have NO IDEA of what are you talking about. I am not going to say anything more, because you have disqualified yourself in this stuff.
Manufacturers usually give their cars' specifications. Play with google a bit, and you'll get that the Focus has a drag coefficient of 0.32. The 360, F430, 550, and 575M Coupes are 0.33 (convertibles are higher). The Enzo is 0.36. You can look up older models if you want, but I doubt you'll find anything lower. I can give specific links if you want.
You don't have to act so rude. I may be wrong about the 10% factor for cars, but skin friction is certainly a real effect. If I said something else incorrect, I'd actually like to know.
Clausius2 - normally you have very informative posts but I do believe you have a mistake or poorly phrased statement above. If 9HP is the aero drag estimate and this is 8% of the overall friction then the overall losses would be 112.5HP at 100KpH, a very high number. Did you happen to intend to say 80% of the overall friction, for a total of 11.25HP at 100KpH, a more reasonalbe sounding figure?
No I didn't mean anything of what you said. I meant an 8% of the TOTAL available engine power is lost in aerodynamic drag at 100km/h. I could have said an 8.1%, an 8.5%, a 10%, but never a 20%, a 30% or so, which I think they do are very high numbers.
They really should be stating at what Reynolds number those Cd's are calculated at. Without some kind of reference, the number is not quite meaningless, but leaves a lot open to question. Chances are it's not an apples-to-apples comparison
That's true. Comparing them too strictly isn't quite fair. Still the Reynolds number for all interesting speeds is extremely high (at least a few times [tex]10^6[/tex]). If you look at typical graphs of drag coefficients versus Reynolds number, there's often a severe dip around [tex]5 \times 10^{5}[/tex], and then the coefficient increases again and becomes nearly constant for a long time. Of course that dip moves around depending on the various things (e.g. surface roughness), but I recall it occurring at very low speeds for most cars.
The dip might still be important near 100 kph (I imagine this would be a nice goal for the engineers to place it where people drive a lot), but I'm going to assume that manufacturers measure things at higher speeds where the drag coefficient is approximately constant. As evidence, calculated and measured top speeds (when its drag-limited) usually come close, which wouldn't happen if only the lowest possible drag coefficient was given.
Huh? Common cars range between 100-400 hp in their optimal gear, and much less in a realistic gear. Also, fuel economy (the original point of this thread) is terrible at full throttle. I don't understand your point.
Stingray,
When C2 referred to total available power, he probably meant gross vs net. "Full throttle" would not make any sense in the context.
So, 8% of total power = 8% before the inefficiency of the transmission, inefficiancy of the tires, etc., are factored in.
If the cars drag coeffecient is high would that also lead to a high downforce?
Not necessarily, but optimizing downforce usually has a negative effect on drag. In F1 cars, for example, drag coefficients near 1 are not uncommon. This is done in order to achieve lift coefficients around -3.
There are, however, very few street cars that generate downforce. Almost all actually lift at high speed. A few modern Ferraris and other exotics are the exceptions (still, their lift to drag ratio is very small).
Eliminating lift is generally much more important than reducing drag for high-powered sports cars, so this design goal is probably the reason for their mediocre drag coefficients.
Aerodynamics also affects engine and brake cooling, and these systems must be very efficient on exotic sports cars. Again, getting this right is probably more important than lowering drag.
To add to Stingray's comments, not necessarily.
A high downforce (essentially upside-down lift) will usually result in an inherent high drag, but not necessarily the other way round. I was going to use the F1 example too, but Stinger beat me too it.
To simplify the original topic, the purpose of an airdam is to improve the aerodynamics of a vehicle by not allowing the airflow to pass under the vehicle. The underside of most vehicles is an aerodynamic nightmare.
At Nascar speeds cars will actually go airborne if the front end of the vehicle is lifted or if the airdam is torn off.
Does an airdam improve gas mileage? One would probably help some at 75mph on the interstate highways. For most practical purposes in everyday driving they don't help much. And since they are located so close to the ground that they are easily broken.
At ANY speed - your mileage is determined by how much energy the engine has to put
out to keep you going at that speed. The gas you pay for is providing the engine with the
energy to compensate for the energy losses.
What are the energy losses?
1) Air resistance
2) Rolling Resistance
The latter includes the friction of the various mechanical components of the drive train
as well as the resistance due to the flexing of the tires.
Thermodynamics also dictates that a big chunk [ the majority ] of the chemical energy
in your fuel goes into waste heat.
Essentially ALL the energy you pay for ends up as heat.
This heat gets exhausted to the atmosphere by your radiator and tailpipe. It also ends
up in heating your tires - which are also cooled by the atmosphere. The drive train gets
warm too. The energy due to air resistance is given up to kinetic energy of the air that
the car displaces. [ That air dam decreases some of the turbulence - and hence the
turbulent kinetic energy - of the air under the car.]
The portion of the fuel energy that ends up as the desired kinetic energy of the car
eventually finds its way to being dissipated by the brakes.
So if you want to know where the energy is going - look at how the energy from the
gasoline eventually winds up as heat.
Dr. Gregory Greenman
Physicist
so,a spoiler should help at least a little bit,then,right?
Not necessarily. It could be designed to reduce lift at the expense of drag, or may not be designed to do anything other than look aggressive (most aftermarket designs). Throwing on some random spoiler not designed for the car could make things worse.
what about for just a modest gian in mileage then? i am not worried about lift or anything like that
I meant that an improperly designed spoiler (or one designed more for reducing lift) may make your fuel consumption worse.
anyone work on anything like this? where you try to minimize drag , to save gas?
Air resistance increases over 55 MPH `98 Kph as the atmosphere itself becomes less capable of Parting around the vehicule such that at speeds greater then that the resitance from Airflow increases as the Car now pushes a Dam (like a wave) of Air in front of it.
Air resistance on Cars is quite well Included in all car designs, never seen the car commercials touting exactly that? as it improves fuel milage.
  • · Replies 33 ·
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 42 ·
