Beam Moment Support: Debunking the Need for End Moments
  • Context: Undergrad
  • Thread starter Thread starter chandran
    Beam Moment
The discussion centers on the structural behavior of beams under applied moments. It concludes that a beam with no constraints can be supported at one end like a simply supported beam, rather than requiring fixed end moments. This challenges the conventional theory that a moment applied at a point necessitates a corresponding moment at the beam's ends for stability. Instead, applying a force at the end of the beam can effectively counteract the rotation caused by the moment.
  • Understanding of beam mechanics and structural analysis
  • Familiarity with simply supported and fixed beam concepts
  • Knowledge of moment application and its effects on structures
  • Basic principles of equilibrium in static systems
  • Research the principles of simply supported beams in structural engineering
  • Study the effects of applied moments on beam stability
  • Explore the mathematical equations governing beam equilibrium
  • Investigate case studies involving unconventional beam support methods
Structural engineers, civil engineering students, and professionals involved in beam design and analysis will benefit from this discussion.
chandran
i have a beam with no constraints. Now i apply a moment at some point in the beam. Now am i correct to say that i need not fix the end of the beam(like a beam inserted into a wall). instead i could support the end of the beam like a simply supported beam.
because a moment tries to rotate the object with the axis as the point of application of moment. I can always prevent rotation by applying force at some other point(simulating like a simply supported beam).
This disproves the theory that the moment applied at some point of the beam should be supported by a moment at the end of the beam. Instead the beam can be supported by a force at the end of the beam
What theory is this?
If you only support the beam by one end, and the support is not embedded (inserted in a wall), then your system is not stable. More equations than unknowns.
