Solve LaGrange Problem: Rod of Length L & Disk of Radius R
  • Thread starter Thread starter don_anon25
    Lagrange
The discussion focuses on deriving the equations of motion for a system consisting of a rod of length L and mass M, pivoted at one end, and a thin disk of mass M and radius R, pivoted at the center of the disk. The kinetic energy of the system is expressed as 1/2 M [(L cos θ - R) θ̇]^2 + 1/2 (I of Rod) (θ̇)^2 + 1/2 (I of Disk) (φ̇)^2, while the potential energy is given by U = (L cos θ - (L cos θ - R) * cos θ) mg. The discussion emphasizes the need to analyze the rod and disk separately for accurate calculations of kinetic energy and potential energy, and suggests using undetermined multipliers to solve the problem.
  • Understanding of Lagrangian mechanics
  • Familiarity with kinetic and potential energy equations
  • Knowledge of the Euler-Lagrange equations
  • Concept of constraints in mechanical systems
  • Study the derivation of the Euler-Lagrange equations in Lagrangian mechanics
  • Learn about the kinetic energy of rigid bodies, specifically for rods and disks
  • Research the method of undetermined multipliers in constraint optimization
  • Examine examples of similar mechanical systems to understand motion equations
Students and professionals in physics and engineering, particularly those studying dynamics and mechanical systems involving rotational motion.
don_anon25
We have a rod of length L and mass M pivoted at a point at the origin. This rod can swing in the vertical plane. The other end of the rod is pivoted to the center of a thin disk of mass M and radius R. Derive the equations of motion for the system.
I have attached a drawing :)
If you can't tell from my drawing, the angle between the vertical and L is theta and the disk has radius R and angle of rotation phi. The rod of length L swings -- the disk swings and rotates. L cos theta would thus be the vertical component...
For the kinetic energy of the system, I have 1/2 M [(L cos theta - R) theta dot]^2 + 1/2 (I of Rod) (theta dot)^2 + 1/2 (I of disk) (phi dot)^2.
Theta dot is the rate of change of angle theta, phi dot is rate of change of angle phi.
Is my generalized term for velocity [(L cos theta - R)*theta dot] correct? I'm a bit uncertain of it. If not, what should it be?
For potential energy of the system, I have U = (L cos theta - (L cos theta - R) * cos theta] mg. Is this correct?
I think I also have an extra constraint: (L Cos theta - R) * theta - R* phi =0. This is when the disc is at its lowest position.
This leads me to believe that I need to use undertermined multipliers to solve this problem. I suppose I will have two Euler-Lagrange equations, one for Theta and one for Phi.
Of course, this may be all wrong...I am terribly confused by this problem. Perhaps someone could refer me to a helpful resource? Or perhaps explain what the kinetic and potential energies should be?
Thanks for help in advance! Everyone on this website is absolutely wonderful when it comes to homework help!
Look at your equations for the velocity and potential energy, they are incorrect. Look at the disk and rod completely separately for this problem. Assume a homogenius rod and a homogenius disk (unless otherwise specified) and then you the velocity of the center of mass for the rod and disk separatly for the kinetic energy. Also, in your constraint where the disk is at its lowest position, theta = 0.
