Thread Closed
EM wave - nodes at metal surface
Share Thread
Dec1-05, 03:55 PM   #1
I've read in a book, that if you had a standing electromagnetic wave between two metal plates, only nodes would be at the metal plates. This is due to the infinite high conduction of metal, the book says.
Why is that so?
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Dec2-05, 04:01 AM   #2
Recognitions:
Homework Helper Homework Help
This is one of the boundary conditions of an electric field at the surface of a conductor. Inside the conductor, the electric field will be zero since any electric field will cause the charges to move around as to cancel this field (practically instantaneously).
Same reasoning applies with the wave. Any E-field at the surface of the metal plate will cause the electrons to move around as to cancel this field. So it will always be zero.
Dec4-05, 09:07 AM   #3
So the E-field (and the B-field) at the surface is zero, since the electrons' movements cancel out the E-field? And the movement is so fast that it is really zero?
Dec4-05, 09:39 AM   #4
Recognitions:
Yes, it is practically instantaneous. Mathematically it IS in the case of an ideal conductor.
Any field in, say, the x-direction will push on the charges and cause positive to accumulate x direction and negative charge in the -x direction. This arrangement will produce its own field in the -x direction as to cancel the original field, so the total field will be zero.
Dec4-05, 06:47 PM   #5
Recognitions:
It is only the component of E parallel to the metal'surface that is zero. The component perpendicular to (and just outside) the surface is not zero. For B, it is the opposite. The normal component is zero and the tangential component is not. If the wave vector (k) is perpendicular to the surface, E at the surface is zero, but B is not.
Thread Closed
Similar discussions for: EM wave - nodes at metal surface
Thread Forum Replies
Questions on electrons incident on a metal surface Advanced Physics Homework 0
how to measure parasitic capacitance between rf cable and metal surface Electrical Engineering 7
Polished surface of metal as a mirror General Physics 3
Hydrocarbon/Metal surface bonding energy General Physics 0
