I forgot how to do my ODES Stuck on a PDE question.
  • Thread starter Thread starter calvino
    Odes Pde Stuck
The discussion centers on solving a partial differential equation (PDE) using the assumed solution form U(x,t) = XT, where X and T are functions. The user derives the equation T'/T = kX''/X, leading to kX'' + (h^2)X = 0 after assuming $ < 0. The consensus is that the solution for X can be expressed as X = Acos(mx) + Bsin(mx), which facilitates differentiation for further analysis. It is advised to use exponential forms and Euler's formula for a more manageable solution.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary conditions in differential equations
  • Knowledge of trigonometric functions and their derivatives
  • Basic understanding of Euler's formula
  • Study the method of separation of variables in PDEs
  • Learn about boundary value problems and their solutions
  • Explore the application of Euler's formula in solving differential equations
  • Investigate the implications of different cases for the parameter $ in PDE solutions
Students and professionals in mathematics, particularly those focusing on differential equations, as well as educators teaching PDE concepts.
calvino
Let's say I assumed that the answer to a PDE was U(x,t)= XT, where X,T are functions. I then further my answer by getting to a point for
T'/T=kX''/X, where k is some constant given in the boundary conditions. I then continue by working on either side to find each function. Suppose I work on the right hand side (RHS).
Since i know both LHS and RHS are indepent of each other, I can continue and say that RHS= -$. Now, I check the first case there $<0. So i say that $=-h^2 and get kX'' + (h^2)X=0.
I am stuck here. Does X then turn out to be a function of cosM and sinM, when $<0? (M being theta, or some angle). Furthermore, X=CcosM + DsinM...right?
note: I didnt include that boundary conditions as I doubt that they are needed for my question.
Yes, one form of the solution would be a sum of a sin and cos function. I think you would be better off writing the solution as Acos(mx) + Bsin(mx) rather than cos(M) + sin(M) so that you'll be able to take the derivatives when you plug back into the ODE to find the value of m. Also, I wouldn't bother solving the cases of $>0 and $<0 separately. Just assume the form to be exponential and Euler's formula can put your answer in a more pleasent form.
  • · Replies 36 ·
