| Thread Closed |
Center of Rotation |
Share Thread | Thread Tools |
| Dec8-05, 02:52 PM | #1 |
Center of Rotation
If w = 1.0 rad/s
0-----0-----0-----0 lenght 1 = 2 m lenght 2 = 3 m lenght 3 = 4 m each circl is a object weighing 1 kg. find center of rotation and tension in the massless rods getting center of rotation was easy but tension.. well i know if theres 3 objects, to get tension, i used m*wsquare*r from each object to the center of rotation giving me 2 tensions, that worked, but with 4 objects, what do we do here. ( iknow we should get 3 tensions) |
| Dec8-05, 04:28 PM | #2 |
Recognitions:
It's much easier than you might think. After solving for the outer tensions. Look at one of the "inside masses." The ouside tension is pulling outward, and the inside tension pulls inward. The net force here must be centripetal force. If you did things correctly, it doesn't matter which inner mass you choose, because the tension must be the same on each (tension pulls equqally at both ends).
| Dec8-05, 04:51 PM | #3 |
is this right then?
t1 = 4 N t3 = 5N t2 = 1 N (difference between 2 ends?) letmeknow thanks |
| Dec8-05, 06:27 PM | #4 |
Recognitions:
Center of Rotation
YOu have 1 and 3 correct, but the middle tension is not.
call the four particles a, b, c, d. You can see that the centripetal force on the c must be 1 N right? Well, in perfect uniform circular motion, the centripetal force must be the net force. Tension 3 is pulling on c to the right with 5N (since 5 N is pulling on d at the other end), but the net force on c must be 1 N. How much must tension 2 be to make it so? You find the same answer if you use the same longic on b. |
| Dec8-05, 07:10 PM | #5 |
i get 4 N when using C
and 6N when using B shudnt they be teh same for C -fnet + 5 =1 fnet = 4 for b -4 + fnet = 2 fnet = 6 |
| Dec9-05, 03:13 PM | #6 |
Recognitions:
Fnet = 1N Fnet= T2 - 5N = 1N (5N is T3 on d) For b: Fnet = 2N Fnet = T2 - 4N = 2N (4N is T1 on a) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Center of Rotation
| Center of gravity (it's not center of mass!!!) | General Physics | 28 | ||
| rotation in QM | Advanced Physics Homework | 1 | ||
| the geometric center of the Earth and the center of mass | Classical Physics | 9 | ||
| Can two objects with the same center of mass oscillate about that center? | Introductory Physics Homework | 0 | ||
| The center of Mass perfectly match the center of Force-> | General Physics | 9 | ||
