Solving an ODE- I don't freaking know how
  • Thread starter Thread starter Yann
    Ode
The discussion revolves around solving an ordinary differential equation (ODE) of the form (ax+by)dx+(kx+ly)dy=0. The original poster expresses uncertainty about the conditions for the equation to be exact and the process of finding the exact equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the condition for exactness, noting that b must equal k. There is discussion about the implications of this condition and the form of the general solution. Questions arise regarding the interpretation of the general solution and the notation used in the equations.
Some participants have provided detailed explanations regarding the exactness of the ODE and the derivation of the general solution. There is an ongoing clarification of terms and notation, with no explicit consensus on the final interpretation of the solution. The discussion remains active with participants questioning specific details and seeking numerical testing methods.
Participants are navigating the complexities of the ODE without prior exposure to the relevant coursework, which may influence their understanding and interpretations. There is also mention of potential confusion due to notation and terminology used in the discussion.
Yann
I missed a course and now I have to solve an ODE, I don't freaking know how :)
[tex](ax+by)dx+(kx+ly)dy=0[/tex]
So, I have to know on what condition this equation is exact (1), and I have to find the exact equation (2). Well if a, b, k and l = 0 then it's certainly over but i guess it's not really the point.
Let's say M(x,y) = ax+by and N(x,y) = kx+ly, IF I'm right, the ODE is exact when;
[tex]\frac{\partial M(x,y)}{\partial y}=\frac{\partial N(x,y)}{\partial x}[/tex]
Then;
[tex]\frac{\partial (ax+by)}{\partial y}=\frac{\partial (kx+ly)}{\partial x}[/tex]
[tex]b=k[/tex]
So my answer to the first question is; is it exact when b = k. And to show how sure I am (not...) I'll say c = b = k for the next part of this question. However, intuitively, i'd say the winning condition is when a and l = 0, and b = -k, (b=c,k=-c) then by integrating you'll got bxy+kxy = 0, so cxy-cxy=0, 0=0.
And then, I don't know what method to use to find the exact ODE.
Yes, it is true that the differential M(x,y)dx+ N(x,y)dy is "exact" when there exist some function f(x,y) such that
[tex]\frac{\partial f}{\partial x}= M(x,y)[/tex]
and
[tex]\fract{\partial f}{\partial y}= N(x,y)[/tex]
and that requires, in order that
[tex]\frac{\partial^2f}{\partial x\partial y}= \frac{\partial^2f}{\partial y\partial x}[/tex]
that
So your differential equation (ax+by)dx+(kx+ly)dy=0
will be an exact equation if and only if b= k. But I don't know what you mean by "find the exact equation"! Obviously, the exact equation is
(ax+ by)dx+ (bx+ ly)dy when b= k. Is it possible that you mean "find the general solution to the exact equation"??
An equation is exact if and only if the left hand side is an exact differential: For some f(x,y), df= M(x,y)dx+ N(x,y)dy which means that we must have [tex]\frac{\partial f}{\partial x}= M(x,y)[/tex] and that [tex]\frac{\partial f}{\partial y}= N(x,y)[/tex].
In particular, if df= (ax+ by)dx+ (bx+ ly)dy we must have
fx= ax+ by and fy= bx+ ly. Since the partial derivative wrt x is taken by treating y as a constant, we can "back out" by taking the anti-derivative treating y as a constant: f(x,y)= (1/2)ax2+ bxy+ g(y). "g(y)" is the constant of integration". Since we are treating y as a constant, it could be any function of y. Now differentiate that with respect to y: fy= bx+ g'(y)= by+ ly. Precisely because we set k= b, the x terms cancel and we have g'(y)= ly. Integrating that, g(y)= (1/2)ly+ C (since g is a function of y only, that C really is a constant). Putting that into the equation of f(x,y),
f(x,y)= (1/2)ax2+ bxy+ (1/2)ly. Since df= 0 according to the equation, f(x,y) must equal a constant:
(1/2)ax2+ bxy+ (1/2)ly= C is the general solution to the equation.
wow. Thanks, you really took time to answer and it's appreciated.
So...
[tex](ax+by)dx + (kx+ly)dy = 0[/tex]
To be exact, b must be equal to k
And the general answer is;
[tex]f(x,y) = \frac{ax^2}{2}+byx+\frac{ly^2}{2}[/tex]
f(x,y) is equal to a constant because df = 0 (but it could still be written, f(x,y) = ... + C no ?)
[tex]C = \frac{ax^2}{2}+byx+\frac{ly^2}{2}[/tex]
That's clear. However you wrote at the general answer "ly/2" and I got "ly^2/2". It doesn't make more sense ? If "ly/2", then how can you get "ly" when you derive f(x,y) ? And another thing, is there a way to test that answer numerically with Maple (don't know MatLab or Mathematica yet...) ?
Thanks a lot for your time. If you ever need a letter of recommendation from an unknown "non-math major" non-american undegraduate student with a lot of trouble writting in english, I'm your man.
"f(x,y) is equal to a constant because df = 0 (but it could still be written, f(x,y) = ... + C no ?"
No. f(x,y)= (1/2)ax2+ bxy+ (1/2)cy2+C is simply a function in two variables and does not define y, even implicitly, as a function of x. Either (1/2)ax2+ bxy+ (1/2)cy2+C= 0 or, same thing, (1/2)ax2+ bxy+ (1/2)cy2= C does.
"However you wrote at the general answer "ly/2" and I got "ly^2/2". It doesn't make more sense ? "
Yes! I messed up the superscripts in "(1/2)ax2+ bxy+ (1/2)ly= C"!
By the way, your English is far better than my (put practically any language here!).
