Calculate Eccentricity and Period of Central Force III Planet's Orbit
The discussion revolves around calculating the eccentricity and period of an extra-solar planet's elliptical orbit around a star, given specific distances related to the orbit. The participants explore concepts in celestial mechanics and orbital dynamics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive the eccentricity and period using known relationships in orbital mechanics, referencing Kepler's laws and conservation principles. Some participants question the necessity of applying conservation of energy and angular momentum in their calculations. Others suggest using specific equations for velocity and energy to analyze the problem further.
Participants have provided guidance on the application of Kepler's laws and conservation principles, with some exploring the implications of angular momentum and energy conservation. There is a mix of interpretations regarding the necessity of certain calculations, and while some have found clarity, others continue to seek understanding.
There are indications of confusion regarding the application of conservation laws and the definitions of certain variables, such as angular momentum and energy terms. Some participants express uncertainty about the relevance of specific equations and their implications for the problem at hand.
Nusc
An extra-solar planet moes in an elliptic orbit around a star of mass M. The max distance between the planet and the star is known to be r2 = 8r1 where r1 is the min distance between the planet and the star.
a) What is the eccentricity of the planet's orbit?
b) What is the period of the planet's orbit in terms of the distance r1 and the mass of the star?
c) Compute the numerical value of the ratio of the planet's max speed to the planet's min speed.
a) r min = r1 = a(1-e)
r max = r2 = a(1+e) but rmax = 8rmin
a(1+e) = 8a(1-e) and continue...
e = 7/9
b) I suppose you can use kepler's third law
T^2 = (4*pie^2*a^3)/GM
a = r1/(1-e) = r1/(2/9) =r1= 9r1/2
T^2 = [4*pie^2 *(9r1/2)^3]/GM
T = 27pie sqrt[r1^3/(2GM)]
was this the right approach?
c) how do I begin with part c?
In part b,
T2 = [itex]\frac{4\pi^2\,a^3}{GM}[/itex], where a is the semi-major axis of the elliptical orbit, and rmin = a (1-e). Your approach is correct.
In part c, one applies conservation of angular momentum.
rmin*vmax = rmax*vmin
the min rel velocity occurs at apoapsis (max distance) and max rel velocity occurs at periapsis (min distance).
Then apply conservation of energy Tp + Up = Ta + Ua where T is orbital kinetic energy and U is gravitational potential energy.
Did you solve for theta dot using the conservation of energy?
Cause I got sqrt(-1/(ma^3(1-e^2))),
Why did we apply the conservation of energy in the first place?
Going back to T2 = [itex]\frac{4\pi^2\,a^3}{GM}[/itex],
[itex]\dot{\theta}[/itex] = [itex]\omega[/itex] = [itex]\frac{2\pi}{T}[/itex], so from the above equation,
[itex]\omega[/itex] = [itex]\sqrt{\frac{GM}{a^3}}[/itex].
The equation for conservation of energy is only necessary in order to solve for the expressions of the velocities.
since on has rmin*vmax = rmax*vmin, then one only needs to rearrange to get the ratio for part c.
or vmax / vmin = rmax / rmin
Why did you solve for the angular frequency ?
[itex]\dot{\theta}^2[/itex]=[itex]\sqrt{\frac{GM}{a^3}}[/itex]
So we have E= T + V
So for r min
.5mr^2 [itex]\dot{\theta}^2[/itex] - k/r
.5m(a(1-e))^2 [itex]\dot{\theta}^2[/itex] - k/(a(1-e))
So for E= Tp + Vp
I get
.5m(1-2e+e^2)GM/a - k/a(1-e) should I carry one? how do I find v if I'm going to subsititute it for V = rdot <er> + r theta dot <e theta>
In either case, how would L get into my answer/
Nusc said:
So for E= Tp + Vp
I get
I am not sure what the question is here.
Is this related to showing [itex]\dot{r}[/itex] = 0 in the post on Central Force IV?
Have you determined the equation of motion in polar coordinates.
I was thinking along the lines of r (t) = L / (1 + e cos [itex]\theta (t)[/itex]). The only independent variable is [itex]\theta (t)[/itex], and as e -> 0, then r = L = a = b, i.e. r is constant.
This assumes by L, one means semilatus rectum, rather than angular momenum, L = r x p, which some texts do.
Assuming L is the semilatus rectum, one also has 1/L = (1/rmin + 1/rmax)/2 or L = a (1-e2).
Nevermind, I got the answer to the question and it was much easier that I thought. The cons. of energy is not necessary.
