G for the new carWhat is the fuel efficiency (MPG) for the new car?
  • Thread starter Thread starter stevo13
    Flux Loop
The problem involves calculating the magnetic flux through a loop and a rectangle in the presence of a uniform magnetic field. The context is set within a calculus-based physics course, focusing on magnetic fields and flux calculations.
  • Participants discuss the relationship between the magnetic field and the areas of the loop and rectangle, questioning whether flux passes through the loop and how to define the area for flux calculations. There are inquiries about the dimensions and configurations of the shapes involved.
The discussion is active, with participants providing insights and clarifications regarding the setup of the problem. Some have offered guidance on the definition of magnetic flux, while others are exploring different interpretations of the geometrical arrangement.
There is mention of confusion regarding the two radii of the loop and the implications for calculating flux. Participants are also considering the constraints of the problem as it relates to their coursework and final exam context.
stevo13
Here is the problem: You have a loop of radius r1 and r2. You have a rectangle with dimensions of length a and b (b>a) with a uniform magnetic field only passing through this rectangle, into the page. What is the magnetic flux through the loop? To better help visualize the diagram, the length b is parallel to the y-axis, while the length a is parallel to the x-axis. This problem was on our final (I'm taking the calculus based physics course). If someone could work this out so I could compare it with what I did at home (assuming I did it the same as on the final) I would appreciate it. Thanks.
Steve
Could you include a diagram? I assume the loop is smaller than the rectangle?
Open the attachment for the diagram.
What is your work
Is there is any flux passing through the loops, other then the flux through the rectangle.
The only location the magnetic field passes through is the through the rectangle. Since there isn't a uniform magnetic field passing through the hoop, you have to use the definition flux=int B dA.
whether this flux passes through the hoops or not?
if no no flux through the hoops.
if yes what is its value?
The magnetic field is B. There is no numerical value. The rectangle is circumscribed within the solid loop of radius R1 and R2, therefore, the magnetic field also passes through the loop; but only through the rectangle...nowhere else. I will tell you this, the two radii confused me at first. I would think that if we were dealing with a loop the radius would be just R. On the other hand, if the shape was described as a ring then the two different radii would make sense. Hope this helps.
The dog beautifully passed through the fire ring!
[tex]In any of the case, if we have two circular rings of radii r_1 and r_2 ,or a circular thin strip of inner radius r_1 and thickness r_2 - r_1 <br /> the flux of magnetic field <b>B</b> is passing through it, but only within the area <b>A</b> and hence \phi = <b>B.A</b> = Bba.[/tex]
MP
In the circus the dog beautifully passed through the fire ring!
the flux of magnetic field B is passing through it, but only within the area A and hence \phi = B.A = Bba.
MP
  • · Replies 35 ·
