Integrating to Find Perimeter of Semi-Circle/Circle Using x(t) & y(t)
  • Context: Graduate
  • Thread starter Thread starter Alkatran
    Integration Trig
The discussion revolves around finding the perimeter of a semi-circle and a full circle using integration with parametric equations x(t) = cos(t) and y(t) = sin(t). Participants explore the integration process and the implications of substitutions in the calculations.
  • One participant proposes using the integral of the square root of the sum of squares of x(t) and y(t) to find the perimeter of a semi-circle, arriving at π.
  • Another participant suggests that even with a substitution u=2t, the integral would still yield π, but emphasizes the need to account for the differential du = 2dt.
  • A third participant challenges the distance/perimeter formula by stating that the differentiation of x(t) and y(t) must be considered, implying that the initial approach may be flawed.
  • A later reply acknowledges the oversight of not differentiating x(t) and y(t), indicating a realization of the complexity involved in the problem.
Participants express differing views on the correctness of the integration approach and the implications of substitutions, indicating that the discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made in the integration process, particularly concerning the differentiation of parametric equations and the handling of substitutions in integrals.
Alkatran
Let's say I wanted to find the length of the perimeter of a semi-circle using integration with x(t) = cos(t) and y(t) = sin(t). I would do like so:
[tex]\int_{0}^{\pi} \sqrt{sin(t)^2 + cos(t)^2} dt<br /> = \int_{0}^{\pi} \sqrt{1} dt<br /> = \pi[/tex]
now if I wanted to do it for the whole circle I would do it like so:
[tex]\int_{0}^{\pi} \sqrt{sin(2t)^2 + cos(2t)^2} dt<br /> = \int_{0}^{\pi} \sqrt{1} dt<br /> = \pi[/tex]
Now obviously I made a mistake: I didn't replace 2x with u (etc...). But my question is: why can't I do this? What rule stops me from eliminating the cos^2 + sin^2 and getting the wrong answer?
Well even if you make the substitution u=2t you would still arrive at an answer of just pi, because you have to account for du = 2dt.
If [itex]x = \cos(2t)[/itex] then [itex]dx^2 = 4 \sin^2(2t) dt^2[/itex] and similarly for y so your distance/perimeter formula is incorrect.
Tide said:
If [itex]x = \cos(2t)[/itex] then [itex]dx^2 = 4 \sin^2(2t) dt^2[/itex] and similarly for y so your distance/perimeter forumula is incorrect.
No wonder I was having trouble doing the problem, I forgot to differentiate x(t) and y(t)! :smile:
  • · Replies 29 ·
