| Thread Closed |
angular momentum question |
Share Thread |
| Jan10-06, 02:23 PM | #1 |
ok the question is a spherical star expands to 6 times its volume but its mass remains constant and is uniformly distributed - how does the period of rotation change?
obviously it rotates slower and thus the period goes up, but i dont know how to solve it mathematically. can someone give me some pointers and get me going in the right direction? is there a main equation i should be using and do i need to find the ratio of the radii before and after the star expands? thanks. |
| Jan10-06, 02:36 PM | #2 |
Mentor
Hint: What's conserved? How does the rotational inertia change when the star expands? (Yes, you'll need to know how the radius changes.)
| Jan10-06, 02:47 PM | #3 |
angular momentum is conserved.
and rotational inertia increases as the star expands, hence the angular velocity will go down to conserve angular momentum (L=Iw), right? and if the volume goes up by 6 times, it means the radius went up by ~1.8 times. do i then square that value because I=mr^2? which means the inertia went up by (1.8)^2 = 3.3 and therefore the angular velocity (w) went down by 3.3 to compensate for that? am i understanding this correctly? |
| Jan10-06, 03:10 PM | #4 |
Mentor
Sounds like you have the right idea!
[tex]I = 2/5 m r^2[/tex] [tex]r_2 = 6^{1/3}r_1[/tex] [tex]I_2 = 6^{2/3}I_1[/tex] |
| Jan10-06, 03:13 PM | #5 |
None the less, the difference in the formulas is a constant, so it doesn't change the proportions. You'll get the same ratio either way. |
| Thread Closed |
Similar discussions for: angular momentum question
| Angular Momentum Question | Quantum Physics | 6 | ||
| Angular momentum question | Introductory Physics Homework | 31 | ||
| Angular Momentum Question | Advanced Physics Homework | 0 | ||
| QM angular momentum question | Quantum Physics | 5 | ||
| Angular Momentum Question | Introductory Physics Homework | 4 | ||
