How Do You Calculate Distance Traveled and Minimum Stopping Acceleration?
  • Thread starter Thread starter Girldistracted
    Increasing Velocity
This discussion focuses on calculating distance traveled and minimum stopping acceleration for a car. The car accelerates uniformly to a speed of 3.20 m/s in 8.00 seconds, and the distance traveled from 1.80 to 3.60 seconds can be determined using the average velocity formula: d = v * t. For the second scenario, involving a car traveling at 64.2 mi/h (converted to 28.7 m/s), the necessary minimum constant acceleration to stop without hitting a deer 107 m away can be calculated using the equation d = vi * t + 1/2 * a * t^2, rearranging to solve for acceleration.
  • Understanding of kinematic equations
  • Familiarity with average velocity calculations
  • Knowledge of unit conversions (mi/h to m/s)
  • Ability to manipulate algebraic equations
  • Study kinematic equations in detail, focusing on distance and acceleration calculations
  • Learn how to calculate area under a velocity-time graph
  • Practice unit conversion techniques, especially for speed
  • Explore real-world applications of stopping distance calculations in automotive safety
Students in physics, automotive engineers, and anyone interested in understanding motion dynamics and vehicle stopping distances.
Girldistracted
The Graph above shows the speed of a car traveling in a straight line as a function of time. (Sorry no graph) The car accelerates uniformly and reaches a speed Vb of 3.20 m/s in 8.00 seconds. Calculate the distance traveled by the car from a time of 1.80 to 3.60 seconds.
Im not sure what equations to use to find this...i thought i would find the change in time and then multiply that by the final velocity but that was wrong and i don't know what else to use bc the equations i have require another velocity or acceleration.
My second question is A driver in a car traveling at a speed of 64.2 mi/h sees a deer 107 m away on the road. Calculate the minimum constant acceleration that is necessary for the car to stop without hitting the deer (assuming that the deer does not move in the meantime).
I changed the speed to 28.7m/s. I used the equation
v^2=v0^2+2a(x-x0) and solved for a but that was wrong...can anyone help??
For first part you have the graph why don't you find the area under the curve v-t from t=1.8 to t= 3.6
For the first question, you can use the equation for average velocity: v = (vf + vi)/2, where vf is the final velocity and vi is the initial velocity. Rearrange the equation to solve for distance traveled: d = v * t. Plug in the values for v and t, and you will get the distance traveled in that time interval.
For the second question, you can use the equation for distance: d = vi * t + 1/2 * a * t^2, where vi is the initial velocity, t is the time, and a is the acceleration. In this case, vi is 28.7 m/s, t is the time it takes for the car to stop (unknown), and d is 107 m. Rearrange the equation to solve for a, and you will get the minimum acceleration needed for the car to stop without hitting the deer.
  • · Replies 33 ·
