Area - Riemann Sum/Integration problem
  • Thread starter Thread starter Xcron
    Area Riemann
The problem involves determining the values of m for which the line y=mx and the curve y=\frac{x}{(x^2+1)} enclose a region, as well as finding the area of that region. The context is related to the natural logarithmic function, suggesting a connection to integration and possibly optimization.
  • Participants discuss finding intersection points between the line and the curve as a necessary step to determine enclosed regions. There are attempts to relate the problem to optimization by considering the slope of the line. Some participants suggest graphing to gain insights into the problem, while others explore the implications of the quadratic equation derived from setting the line equal to the curve.
The discussion is active, with participants exploring different interpretations of how to find the values of m and the area of the region. There is recognition of the need for two points of intersection for an enclosed area, and some guidance has been provided regarding the use of the discriminant of a quadratic equation to determine conditions on m. However, there is still some confusion about the steps to solve for m and the implications of the derived equations.
Participants are working under the constraints of needing to find values of m that allow for an enclosed region, and there is an ongoing discussion about the necessary calculations and assumptions involved in solving the quadratic equation.
Xcron
This problem is in the section of my book called "The Natural Logarithmic Function" so I am guessing that I would have to use a natural log somewhere...but anyways...the problem says:
For what values of [tex]m[/tex] do the line [tex]y=mx[/tex] and the curve [tex]y=\frac{x}{(x^2+1)}[/tex] enclose a region? Find the area of the region.
For some reason...I related this problem to an optimization problem because I thought if I could find the line with the greatest slope that is tangent to the curve, then I would know the values for which [tex]m[/tex] can be used with...but that didn't seem to use any natural logs or anything..
It may be a good idea to find the intersection points. If there aren't any intersection points, there's no enclosed region.
It can also be useful to graph the problem for a few values of m, this gives you a better insight in the question.
Well, from graphing the problem...it seems like [tex]y=x[/tex] may be the right bound of the interval for which [tex]y=mx[/tex] and the curve enclose a region...but I would need to show a calculation for this...
I tried: [tex]mx= \frac{x}{(x^2+1)} m=\frac{1}{x^2+1}[/tex] but that only gives me the same equation of the curve or perhaps it gives me the equation for the bounds of the interval for which [tex]m[/tex] can be used with..
Seems like [tex]m[/tex] would belong to [tex][0,1)[/tex]...
I think you're on the right track:
[tex]m = \frac{1}<br /> {{x^2 + 1}} \Leftrightarrow m\left( {x^2 + 1} \right) = 1 \Leftrightarrow mx^2 + m - 1 = 0[/tex]
Now, solving this would give the intersection points (which you'll be needing for you integration limits, I assume), but for the moment we're only interested in when there are solutions (i.e. when they intersect and thus enclose a region). You can express this by saying that the discriminant of this quadratic equation in x has to be positive, this will give a condition on m.
Ahh...well, sorry to say this but I am still somewhat confused as to how that equation would be solved...two variables...need to solve for [tex]m[/tex] but that would just give us [tex]\frac{1}{x^2+1}[/tex] ... hmmm...
For the the straight line [tex]y=mx[/tex] and the curve [tex]y=\frac{x}{x^2+1}[/tex] to enclose some finite region, there should be atleast 2 points of intersection.
One point is (0,0). To find the other points, you need to solve
[tex]mx^2 + m -1 =0[/tex].
So for what values of 'm' does a solution to the above equation exist? That will give you the values of 'm' for which a region is enclosed.
To find the area, find the points of intersection in terms of 'm'. You don't need to solve for both the variables, you only need to find x in terms of 'm'.
Ohhhhhh, now I understand. I had understood the part about the 2 points of intersection but was trying to figure out which variable we solve that equation for and I now realize that we find the point on the curve using the intersecting line...which is why we solve for the x in terms of m. I got it, hehe.
so to continue...I would then continue to do:
[tex]\int_{0}^{\sqrt{\frac{1-m}{m}}} (\frac{x}{x^2+1}-mx)dx[/tex]
Is this right?..m would also be a constant, right?
Yeah, that is almost right. What about the other point of intersection (ie, [itex]-\sqrt\frac{1-m}{m}[/itex]? so the area will be twice your integral.
With:
How can I solve for m?
