How Does Charge Density Influence Electric Field and Acceleration?
The discussion revolves around the influence of charge density on electric fields and the resulting acceleration of a charged object moving towards a uniformly charged infinite sheet. The original poster presents a scenario involving specific values for charge density, mass, charge, and velocity, seeking to determine the acceleration of the object.
  • The original poster attempts to apply the formula a=qE/m but struggles with determining the electric field E. They question whether their calculations for E and subsequent acceleration are correct, considering the influence of velocity and other forces.
  • Some participants inquire about the correctness of the electric field calculation and its implications for acceleration, while also questioning the original poster's understanding of equilibrium and force balance.
  • Others suggest considering the total forces acting on the object, including gravitational force, and how they relate to the acceleration.
Participants are actively exploring different interpretations of the problem, particularly regarding the application of force balance in non-equilibrium situations. There is acknowledgment of potential discrepancies in the provided answer from the professor, but no consensus has been reached on the correct approach or calculations.
The original poster notes uncertainty about the validity of the professor's answer and expresses concern about the applicability of certain equations in a non-equilibrium context. They also mention that the magnetic field is not a factor in their current analysis.
industry86
Pretty much, an object is moving at a certain velocity towards an "infinite" sheet with uniform charge density of sigma=4.4 nC/m^2. The object has a mass of m=62 ug and a charge of q=3.5 nC. It also has a velocity given in a vector v=(3.90i-4.80k) m/s. I am to find a bunch of stuff, but the first and foremost being the acceleration of the object.
I've drawn the FBD. I'm not sure if I have the correct equation but I know that a=qE/m in general. However, I can't seem to find E. My teacher explained that when the distance r of an object is r<<length*width then to use E=sigma/(2*epsilon-not) (epsilon-not being the permittivity of space or 8.845*10^-12). But if I were to use that, I'd get E=248 N/C. Popping that into a=qE/m gives me the wrong answer however. Should I be accounting for the force the velocity has? Am I even using the right equation to find E? Using the answer I know for the acceleration, I can calculate that the E should be 74400. But then if I were to backtrack even further, that would mean that sigma would have to be some really off number. This is why I'm speculating that E is wrong. Unless I'm not accounting for another force to determine the acceleration.
Ok, I'm rambling now. Any tips out there? Thanks in advance.
Your E = 248.5 N/C looks okay to me.
What does that give you for a?
How do you know that this acceleration is wrong?
If you use the acceleration that you calculate,
what other results do you obtain?
Have you treated the magnetic field yet?
The answer sheet the professor provided lists the acceleration to be 4.2 m/s.
So am I coming up with the wrong equation to use? I tried qE+a=ma but the problem is I know that this is not in equalibrium so I don't know how a FBD can help me figure this out in this instance.
I didn't use my calculations any further since everything else is based off this acceleration. Nice little stepping stone. And the magnetic field is beyond my scope atm. I don't need to worry about that.
The Electric Field provides a Force on a charge that is immersed in it.
This kind of Force is just like any other Force ... gravity, for instance.
It is the SUM of Forces (including gravity, springs, ...) that causes ma .
That's why we use a FBD ... to help us add the Forces vector-wise.
F_electric + F_gravity = ma .
NO, a is NOT equal to qE/m , in general situations.
I totally understand your reply and already knew that. What I'm figuring my problem is, is since it's not in equilibrium (I know I have to figure it's lowest height before it starts on an upswing before hitting this "infinite" sheet), I don't think I can use F_electric + F_gravity = ma. I know this because this also does not equal the correct answer.
I'm starting to think that maybe the teacher wrote down the wrong answer. He's done it before...
  • · Replies 26 ·
  • · Replies 16 ·
