How Can I Grind Wasabi Fibre Into Powder?
  • Thread starter Thread starter Hyperreality
    Fibre Powder
The discussion revolves around methods for grinding wasabi stems into a fine powder or paste, exploring various techniques and tools suitable for handling the fibrous nature of wasabi. Participants share their experiences and suggestions, focusing on both traditional and modern approaches.
  • One participant mentions using a blender but struggles with grinding the fiber properly.
  • Another suggests checking traditional Japanese methods, implying that separation of fiber might be involved rather than grinding.
  • Some participants propose grating the wasabi with a fine grater and then using a mortar to achieve a smoother consistency.
  • A suggestion is made to use a specific type of grater with conical teeth for better results, acknowledging that some fibers will remain.
  • There is a discussion about using a coffee grinder, with one participant noting that it is effective for dry herbs but questioning its suitability for wet ingredients like wasabi.
  • Humor is introduced regarding Alton Brown's kitchen philosophy, with participants debating the practicality of a sharkskin grater versus a coffee grinder.
  • One participant expresses skepticism about the effectiveness of a coffee grinder for wet ingredients, while another insists it would work well.
Participants express varying opinions on the best method to grind wasabi, with no clear consensus on whether a coffee grinder or a sharkskin grater is superior. Some suggest trying both methods, indicating that the discussion remains unresolved.
Participants do not provide definitive conclusions, and the effectiveness of each proposed method may depend on individual preferences and experiences with the tools mentioned.
Hyperreality
I have bought a few wasabi plants recently, I have been trying to grind some of the stem of the wasabi into paste (as shown in the supermarket), the trouble I am having is gridingthe fibre down.
First thing I tried is using a blender, it works fine on most part, but I just can't grind the fibre properly. I have looked through a lot of websites, all the grinder online are only good for grinding dry plants.
Are there anyways of grinding down the fibre to some kind of miniscule particle or powder?
I would first check into how the Japanese prepare it. It could be that they separate the fiber from the rest somehow rather than grind the fiber down.
I thought it would be grated with a really fine grater, then you could make it smoother with a morter.
Yes, you grate it just like horseradish.
Supposedly http://www.cityfarmer.org/wasabi.html" for things like wasabi, ginger, galangal and other fibrous rhizomes, roots, etc. Look for one with conical teeth rather than pyramidal, it makes a better endproduct. You are going to end up with some fibers remaining on the rhizome, that's fine, you want the juices and less woody parts anyway.
DocToxyn said:
Supposedly http://www.cityfarmer.org/wasabi.html" sounds like a bit of overkill, unless you're looking to go truly authentic and you don't mind dropping the cash for one and you have no reservations about using a shark-derived product.
What would Alton Brown say?
Alton would tell you to use a coffee grinder. Much higher speed and finer chopping blades.
That's what he uses for all of his bulk spices and herbs...not that I watch that show a lot...
Hah! Good one. However one of Alton's big things is not having anything in his kitchen that is not a multi-tasker (except his fire extinguisher, and he would probably use that as a rolling pin in a pinch). That sharkskin grater seems pretty uni-tasked to me...:biggrin:
Fred Garvin said:
:Alton would tell you to use a coffee grinder. Much higher speed and finer chopping blades.
True, he uses those a lot, and I have several myself, but they are used for dried herbs and spices, nothing wet like fresh ginger or wasabi.
I bet mine would work. It can grind small rocks. A little wet noodle thing would be no match for it.
what do you make out of small rocks? smaller rocks?
Wow, thanks guys, didn't expect that many reply:!) :!)
So, you guys are saying the sharkskin grater could grind the fibre of the stem of the wasabi?
Yes, but it looks like you should try a coffee grinder first, unless you're a professional sushi chef.
lol, good one.
Exactly right, a coffee grinder. Funny how you... hey who said use his fire extinguisher in a pinch? I thought that was funnier than Evo's comment.
  • · Replies 27 ·
  • · Replies 28 ·
10K
  • · Replies 22 ·
