Electric Field in an Infinitely Long Cylinder
  • Thread starter Thread starter skiboka33
    Cylinder
The discussion focuses on calculating the electric field generated by an infinitely long cylinder with a volume charge density defined as ρ = ρ0(a - r/b). The participants utilize Gauss' Law to derive the electric field's magnitude for two scenarios: inside the cylinder (r < R) and outside the cylinder (r > R). The key takeaway is that the integration limits differ based on whether the point of interest is inside or outside the cylinder, affecting the calculation of the electric field.
  • Understanding of Gauss' Law in electrostatics
  • Familiarity with volume charge density concepts
  • Knowledge of cylindrical coordinates and integration techniques
  • Concept of electric field symmetry in electrostatics
  • Study the application of Gauss' Law for various charge distributions
  • Learn about electric field calculations in cylindrical coordinates
  • Explore the concept of electric flux and its relation to charge
  • Investigate the effects of charge density variations on electric fields
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to electric fields in charged cylindrical objects.
skiboka33
Here's the problem:
An infinately long cylinder of radius R has a volume charge density that varies with the radius as p = p0(a-r/b) where p0, a and b are all positive constants amd r is the distance from the axis of the cylinder. Use Gauss' law to determine the magnitude of the electric field at r<R and r>R.
here's my logic for r < R:
E = k * int[p*dV/r] = k*p0*int[(a-r/b)*dV/r]
-Then sub in V=Pi*r^2*L (solved for r and integrate wrt V)
but what is this L if it's infinite. Also what is the difference being inside or outside of the cylinder? is it just the limits of integration (ie 0-R, or R-r)?
Thanks.
Symmetry tells you the electric field is radial and azimuthally symmetric. Gauss' Law relates the flux of electric field through a closed surface and the amount of charge contained therein. Rethink your approach! :)
