Finding the Point of Intersection: Y=x+6 and Y=x^3
The discussion revolves around finding the point of intersection between the equations y = x + 6 and y = x^3. Participants explore methods to determine where the two curves intersect by analyzing the equation x^3 - x - 6 = 0.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss solving the equation x^3 - x - 6 = 0 and consider the use of divisors of the constant term to find potential integer solutions. There are suggestions to plug in values and graph the functions to visualize the intersection.
The discussion includes various attempts to find solutions, with some participants suggesting numerical testing and graphical methods. There is acknowledgment of the need to check integer solutions, and at least one participant claims to have found an intersection point, although the overall consensus on the method remains unclear.
Participants are working under the constraints of homework rules, which may limit the methods they can use or the information they can share. There is a focus on finding integer solutions and understanding the behavior of the functions involved.
teng125
may i know how to find the point of intersection between y=x+6 and y=x^3 ??
See for what values of x, the y values are the same, so solve:
[tex]x^3 = x + 6 \Leftrightarrow x^3 - x - 6 = 0[/tex]
Divisors of the constant term (6) are possible zeroes.
ya,but then from x^3 - x - =0 how to solve pls
ya ,from x^3 -x - 6 = 0
You TRY SOMETHING!
Have you even tried plugging in numbers to get an idea of how large the solutions should be?
And as I said, you should try the divisors of the constant term, if you're looking for integer zeroes.
http://www.sosmath.com/algebra/factor/fac11/fac11.html
Scroll down to "solving the depressed cubic" because that is the form you have.
Though indeed, it is easier to look for an integer solution as TD said, and you can see graphically from the original problem that there are no other solutions.
You can always plot the 2 functions to get an idea where the intersection is.
the answer is it = to 6 and zero??
Try graphing the two equations as suggested by others. I graphed it on an online graphing calculator and can see that the two curves intersect at only one point. Remember that intersections are points on the x-y plane, so they should have the form (x,y), not just single numbers. Example: The curves intersect at (1,3) and (5,2).
i have already drawn it but i can't find the point using the eqn above so i ask for help in this forum
try to put divisors of 6 , 1,2,3,6 and -1,-2,-3,-6 in the equation(x^3 -x - 6 = 0)
1^3 - 1 - 6 = -6 wrong , I continue 2^3 - 2 - 6 = 8 - 8 = 0 Bingo
the 2 graphs intersect at (2,8).usualy when u have such equation you should what TD told u to do.
okok got it thanx
  • · Replies 21 ·
  • · Replies 27 ·
