Deriving Expression for Volume of Ellipsoid
  • Thread starter Thread starter tandoorichicken
    Ellipsoid Volume
The original poster attempts to derive an expression for the volume of an ellipsoid defined by the inequality \(\frac{x^2}{a^2} +\frac{y^2}{b^2} +\frac{z^2}{c^2} \leq 1\). They express uncertainty about how to proceed from this definition to the desired volume expression.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Some participants suggest setting up the integral based on the ellipsoid's geometry, with one participant detailing the integration bounds in the xy-plane and for z. Others propose using spherical coordinates and changing variables to simplify the integration process. There is also a discussion about the challenges faced when integrating the resulting expressions.
Participants are exploring various methods to approach the problem, including parameterization and substitution techniques. There is no explicit consensus on the best method, and some participants express confusion about the integration steps and the expected form of the final answer.
Some participants note difficulties with the integration process and the resulting expressions, indicating that the problem may involve complex calculations that are challenging to resolve by hand.
tandoorichicken
I've been asked to derive an expression for the volume of an ellipsoid. I know what the expression is, I just don't know how to get there from the information given. All that is given is that it is defined by
[tex]\frac{x^2}{a^2} +\frac{y^2}{b^2} +\frac{z^2}{c^2} \leq 1[/tex],
a standard inequality/definition for an ellisoid. Not quit sure how to go about this.
Have you tried anything? Like first drawing a picture. Certainly it is straight forward to set up the integral. The ellipsoid's widest girth comes in the xy-plane where it is an ellipse:
[tex]\frac{x^2}{a^2}+\frac{y^2}{b^2}= 1[/tex]
That is is covered by taking x from -a to a and, for each x, y from [itex]-b\sqrt{1-\frac{x^2}{a^2}[/itex] to [itex]b\sqrt{1-\frac{x^2}{a^2}}[/itex]. For each (x,y), z ranges from [itex]-c\sqrt{1-\frac{x^2}{a^2}- \frac{y^2}{b^2}}[/itex]. The volume is
[tex]\int_{x=-a}^a\int_{y=-b\sqrt{1-\frac{x^2}{a^2}}}^{b\sqrt{1-\frac{x^2}{a^2}}}\int_{z=-c\sqrt{1-\frac{x^2}{a^2}-\frac{y^2}{b^2}}}^{c\sqrt{1-\frac{x^2}{a^2}-\frac{y^2}{b^2}}}dzdydx[/tex]
or
[tex]2c\int_{x=-a}^a\int_{y=-b\sqrt{1-\frac{x^2}{a^2}}}^{b\sqrt{1-\frac{x^2}{a^2}}}\sqrt{1-\frac{x^2}{a^2}-\frac{y^2}{b^2}}dydx[/tex]
Use spherical coordinates, with a twist.
I agree with the previous poster, use spherical coordinates. You have (x²/a²) + (y²/b²) + (z²/c²) = 1. Spherical coordinates woudldn't work too well with that equation the way it is. It would be much better if your ellipse was transformed into a sphere with an equation like u^2 + v^2 + w^2 = 1. This suggests a change of variables. Consider u^2 = (x²/a²) and likewise for the other components for the three obvious substitutions.
if anyone could further evaluate this problem, i would greatly appreciate it. I followed the parameterization suggestion and set u=x/a, v=y/b, and w=z/c and switched the bounds on the integral. However, after integrating once I run into the problem of
2C * sqrt(1-u^2-v^2)
When I integrate that, I am unable to do it by hand and must do it on a computer system, which gives me a very long answer with two arctangents. I am pretty sure that will not work out to give me 4/3Piabc.
Thanks in advance.
That's not difficult to integrate. It is essentially [itex]\sqrt{a^2- u^2}[/itex] for which the standard substitution is the trig substitution [itex]u= a sin(\theta)[/itex]. Here that would be [itex]u= \sqrt{1- v^2}sin(\theta)[/itex]. Integrating that, with respect to u, will give something involving [itex]\sqrt{1- v^2}[/itex] which you do with another sin substitution.
I'm sorry but I don't understand. The formula listed in my previous post...
is the resulting formula after having already integrated with respect to u.
You said "integrating that, with respect to u," but I need to integrate that with respect to v.
Also, if I introduce a sin(theta) into the equation, I don't see a point in the future at which that constant will disappear, and thus my answer would have a trig function in it, although the correct answer should be
4/3 * Pi * abc. Correct me if I'm wrong, I'm just not following your suggested method.
Ok, so just do 2C*sqrt[ (1-u^2)-v^2] and integrate with respect to v. By making the trig substitution, you're actually integrating with respect to sin(theta) instead, so it goes away then
  • · Replies 0 ·
10K
