How Does Temperature Affect the Resistivity of a Copper Conductor?
The discussion centers on the effect of temperature on the resistivity of a copper conductor, specifically analyzing a scenario where a copper wire carries a current of 1.000 A at 51.0°C and the expected current at -88.0°C. The resistance formula used is R = R0 [1 + a(Tc — To)], where To is the reference temperature. Participants debate whether standard values from literature can be used to determine To, concluding that the provided data is insufficient for a definitive answer.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the temperature coefficient of resistance (α)
  • Knowledge of the resistivity formula for conductors
  • Basic principles of thermodynamics related to materials
  • Research the temperature coefficient of resistance for copper conductors
  • Study the derivation and application of the resistivity formula
  • Explore standard reference values for resistivity and temperature effects
  • Investigate experimental methods to measure current and resistance at varying temperatures
Electrical engineers, physics students, and anyone interested in the thermal properties of conductors and their applications in varying environmental conditions.
cmilho10
While taking photographs in Death Valley on a day when the temperature is 51.0°C, Bill Hiker finds that a certain voltage applied to a copper wire produces a current of 1.000 A. Bill then travels to Antarctica and applies the same voltage to the same wire. What current does he register there if the temperature is -88.0°C? Assume that no change occurs in the wire's shape and size.
At the low temperature T we write R = R0 [1 + a(Tc — To)] where To =?
tW AV
At the high temperature Th, Rh = = R [1 + a(Th — To)]
My question is how do i find what To is?
Are you allowed to use standard values from literature ? Or must you only use data provided in the question ?
If it is the latter, then there isn't sufficient data in the question as posted by you.
  • · Replies 17 ·
