Electrical Potential of a Uniformly Charged Ring
The discussion revolves around finding the electric potential on the axis of a uniformly charged disk with a hole, characterized by inner radius R_in and outer radius R_out, at a distance z from the center. Participants are exploring the appropriate mathematical expressions and integration techniques to derive the potential.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the potential of a ring and consider whether to use a modified formula for the disk. There are attempts to derive the potential through integration of contributions from small rings, with questions about the correctness of proposed integrals and substitutions.
The discussion is active, with participants providing guidance on how to approach the problem through integration and questioning the validity of certain expressions. There is a focus on understanding the contributions of small charge elements and their integration to find the total potential.
Participants are working within the constraints of a homework problem, which may limit the information available and the methods that can be used. There is an emphasis on deriving expressions rather than providing direct solutions.
Gramma2005
I am stuck on this problem:
A disk with a hole has inner radius R_in and outer radius R_out. The disk is uniformly charged with total charge Q. Find an expression for the on-axis electric potential at distance z from the center of the disk.
I started this problem by looking at the electric potential of a ring, which is:
[tex]V=\frac{kQ}{\sqrt{R^2+z^2}}[/tex]
So then if it varies in the thickness of the ring, would it be reasonable to have it be:
[tex]V=\frac{kQ}{\sqrt{(R_{out}-R_{in})^2+z^2}}[/tex]
Or would I need to use the equation for the electric potential of a uniformly charged disk with radius R_out, then subtract the electric potential of the inner disk of radius R_in.
Thanks for your help!
P.S. Hope I did the LaTeX right
No, that is not correct. You can't just substitute R_in and R_out.
One way of doing this, is finding the contribution of a small ring and integrating to get the contribution of the disc.
Would it be something more like this?:
[tex]V=\frac{2Q}{(R_{out}-R_{in})^2}*\int_{R_{in}}^{R_{out}}\frac{dx}{2*\sqrt{x}}[/tex]
I'm not sure if this is the right integral for the equation?
No, that's not right.
First, consider a small ring of thickness [itex]dr[/itex] with a radius of [itex]r[/itex].
Now, what is the potential due to this ring at point at a height 'z' at the axis? It is,
[tex]V=\frac{kdQ}{\sqrt{r^2+z^2}}[/tex]
where, dQ is the small charge on the ring. How do you find this dQ?
You can find the uniform surface charge density [itex]\sigma[/itex] from the question right? (Hint:Total charge/Total area). Since the ring has a small thickness [itex]dr[/itex], the small area will be [itex]2 \pi r dr[/itex]. From this, you can find the charge "dQ" on the small ring.
How do you find the potential of the disc? Notice that, if you sum the contributions of such small rings, you will get the potential of the disc. So you integrate the contribution the small ring where the radius varies from [itex]r_{in}[/itex] to [itex]r_{out}[/itex]
Can you put this in mathematical equations and post the answer here?
Alright, I see how it works now, thanks so much for the help. The final solution is:
[tex]V=\frac{Q*(\sqrt{R_{out}^2+z^2}-\sqrt{R_{in}^2+z^2})}{2*\pi*\epsilon_0*(R_{out}^2-R_{in}^2)}[/tex]
  • · Replies 69 ·
  • · Replies 16 ·
