Calculating Space Shuttle Takeoff, Acceleration, Weight & Air Friction
The discussion focuses on calculating various physical parameters related to a Space Shuttle's takeoff, specifically acceleration, weight, and air friction. The acceleration is determined using the formula a = (v_f - v_i) / Δt, resulting in an acceleration of 56 m/s² over 200 seconds to reach a cruising speed of 11,200 m/s. Weight is calculated using the formula W = mg, where g is 9.8 m/s². Air friction is defined as 20% greater than the weight, calculated using F_f = 1.2W.
  • Understanding of basic physics concepts such as acceleration and force
  • Familiarity with the formula for weight: W = mg
  • Knowledge of gravitational acceleration at Earth's surface (9.8 m/s²)
  • Basic algebra skills for manipulating equations
  • Research the concept of uniform acceleration in physics
  • Learn about gravitational force calculations using F = GMm/r²
  • Explore the effects of air resistance on objects in motion
  • Study advanced rocket propulsion and dynamics
Aerospace engineers, physics students, and anyone interested in the mechanics of rocket launches and the forces involved in space travel.
EK03
I got some questions that I am blanking out on, if someone could tell me what formula i use i would greatly appreciate it. 1 problem is about a space shuttle taking off that takes 200 seconds to reach its cruising speed of 11,200 m/s or 25 thousand mph, i have to find out at what rate it accelerates.
2. to calculate a G I divide the acceleration by 10 correct?
3. how do i calculate the weight of the rocket? I have the accelration, mass and force information of it i just need a formula
4. how can i calculate the air friction? its got 20% more magnitiude then the weight of the rocket.
This depends on whether the acceleration is uniform. If it is, then
[tex]a=\frac{v_f-v_i}{\Delta t}[/tex]
No. At the surface of the Earth g=9.8m/s2. To calculate g, you can divide the weight of an object by its mass.
[tex]w=mg[/tex]
Or you can plug in the Earth's radius into
[tex]\frac{F}{m}=g=\frac{GM}{r^2}[/tex], where M is the mass of the Earth and G=6.67x10-11Nm2/kg2
Again, w=mg.
The weight is w=mg. The friction force is 20% greater than this, so
Ff=(1.2)w
Hope that helps!
1. To find the acceleration, you can use the formula a = (vf - vi)/t, where a is the acceleration, vf is the final velocity (11,200 m/s), vi is the initial velocity (0 m/s), and t is the time (200 seconds). This will give you an acceleration of 56 m/s^2.
2. Yes, to calculate the G-force, you divide the acceleration by the acceleration due to gravity (9.8 m/s^2). In this case, the G-force would be approximately 5.7 Gs.
3. The formula for weight is W = mg, where W is the weight, m is the mass, and g is the acceleration due to gravity (9.8 m/s^2). So if you have the mass and acceleration, you can multiply them to find the weight of the rocket.
4. To calculate air friction, you can use the formula F = 0.2W, where F is the air friction force and W is the weight of the rocket. So if you have the weight of the rocket, you can multiply it by 0.2 to find the air friction force.
  • · Replies 22 ·
  • · Replies 20 ·
9K
