Solving Lagrangian Mechanics: Hamilton's Eqns & EL Eqns
The discussion revolves around the application of Lagrangian mechanics to derive Hamilton's equations and analyze the conditions under which the Hamiltonian remains a constant of motion. The problem involves a charged particle with a given Lagrangian, exploring the implications of electric and magnetic fields on the Hamiltonian's time dependence.
  • Participants discuss the formulation of the Hamiltonian from the Lagrangian and question the conditions for its constancy. There are attempts to clarify the relationship between the Hamiltonian and the Lagrangian, particularly regarding time dependence and the role of electric and magnetic fields.
Several participants have provided insights into the formulation of the Hamiltonian and its implications. There is ongoing exploration of Hamilton's equations of motion and their equivalence to the Euler-Lagrange equations. Some participants express uncertainty about the interpretation of time dependence in the context of the electric and magnetic fields.
Participants note that the Lagrangian's explicit time dependence affects the Hamiltonian's constancy. There is discussion about the generalized coordinates and their relationship to time, as well as the implications of the electric field's formulation.
stunner5000pt
The Lagrangian of a aprticle of charge q and mass m is given by
[tex]L = \frac{1}{2} m \dot{r}^2 - q \phi(r,t) + \frac{q}{c} r \bullet A(r,t)[/tex]
a) determine the Hamiltonain function H(r,p) (in terms of r and its conjugate momentum p) and explain what conditions the electric and mangetic field intensities
[tex]E = - \frac{\partial \phi}{\partial r} - \frac{1}{c} \frac{\partial A}{\partial t}[/tex]
[tex]B = \frac{\partial}{\partial r} \times A[/tex]
must satisfy if the Hamiltonain is to be a constant of motion
I am not sure if the Hamiltonian is
[tex]H = \dot{r} \frac{\partial L}{\partial \dot{r}} -L[/tex]
OR [tex]H = r \frac{\partial L}{\partial r} -L[/tex]
[tex]\dot{r} \frac{\partial L}{\partial \dot{r}} = m \dot{r}^2 + \frac{q}{c} \dot{r} \bullet A(r,t)[/tex]
[tex]H = \dot{r} \frac{\partial L}{\partial \dot{r}} -L = m \dot{r}^2 + \frac{q}{c} \dot{r} \bullet A(r,t) - \frac{1}{2} m \dot{r}^2 - q \phi(r,t) + \frac{q}{c} r \bullet A(r,t)[/tex]
[tex]H = \frac{1}{2} m\dot{r}^2 + q \phi(r,t)[/tex]
[tex]H(r,p) = \frac{1}{2} p \dot{r} + q \phi(r,t)[/tex]
for H to be a constant of motion, then dh/dt = 0 ,yes?
[tex]\frac{dH}{dt} = \frac{1}{2} \dot{p} \dot{r} + \frac{1}{2} p \ddot{r} + q \frac{\partial \phi}{\partial t}[/tex] (not sure about the last term)
[tex]\frac{dH}{dt} = F \frac{\dot{r}}{2} + p \frac{\ddot{r}}{2} + q \frac{\partial \phi}{\partial t}[/tex]
im not sure how the E and B field come into play because none of their terms appear in the equation for dH/dt
b) Work out Hamilton's equations of motion for this system (i.e. the first order equations of r(t),p(t)), and show taht htey are equivalent to the second order Euler Lagrange equation for this system.
I am currently on this...
Your help is greatly appreciated
It is a general result in Hamiltonian mechanics that the total derivative with respect to time of the Hamiltonian is just the negative of the partial derivative with respect to time of the Lagrangian. This can be shown by taking the derivative of H, and then plugging in the definitions of p and the Lagrangian equations of motion.
Hi stunner,
1) The Hamiltonian is always given by [tex]H = \dot{q} \frac{\partial L}{\partial \dot{q}} - L = p \dot{q} - L[/tex] for a single coordinate [tex]q[/tex]. If you have more than one coordinate then you generalize to [tex]H = \sum_i \dot{q}_i p_i - L[/tex] where as always the definition of the canonical momentum is [tex]p_i = \frac{\partial L}{\partial \dot{q}_i}[/tex].
2) The Hamiltonian is constant provided the Lagrangian contains no explicit time dependence. This fact is probably proved in your book somewhere, but it is easy to get if you just use the equations of motion. What does this requirement translate into when you include electric and magnetic fields?
3) Hamilton's equations of motion are first order differential equations while Lagrange's equations are second order. Schematically you have [tex]\dot{q} = \frac{\partial H}{\partial p}[/tex] and [tex]\dot{p} = - \frac{\partial H}{\partial q}[/tex]. Hint: differentiate the first equation with respect to time.
Physics Monkey said:
Hi stunner,
i don't think I am interpreting this right
text says that the hamilton (for this problem) is usually not time dependent since dL/dt is not zero. (unless phi, A are not explicitly time dependent)
so then if we look at hte Elefctric field... since A is not explicitly time dependent, then E should be
[tex]E = - \frac{\partial \phi}{\partial r}[/tex]
also i m taking from from StatusX said taht [tex]- \frac{dH}{dt} = - m \dot{r} \ddot{r} - q \frac{\partial \phi}{\partial r}\frac{\partial r}{\partial t} - q \frac{\partial \phi}{\partial t}[/tex]
and this shouldbe equal to
[tex]\frac{dL}{dt} = m \dot{r} \ddot{r} - q \frac{\partial \phi}{\partial r}\frac{\partial r}{\partial t} - q \frac{\partial \phi}{\partial t}+ \frac{q}{c} \frac{\partial r}{\partial t} + \frac{q}{c} \frac{\partial A}{\partial r} \frac{\partial r}{\partial t} + \frac{q}{c} \frac{\partial A}{\partial t}[/tex]
so then these terms should e zero
[tex]m \dot{r} \ddot{r} - q \frac{\partial \phi}{\partial r}\frac{\partial r}{\partial t} - q \frac{\partial \phi}{\partial t}[/tex]
so r shouldn't be time dependent?? And A shouldn't be time dependent?
I think you may be confused so let me repeat the correct fomulation. If the Lagrangian contains no explicit time dependence [tex]\partial L/ \partial t = 0[/tex] (not [tex]d L/ dt = 0[/tex] !) then the Hamiltonian is time independent [tex]dH/dt = 0[/tex].
Actually the particle's generalized coordinates are x,y,z and of course everything needs to be adapted.
Daniel.
ok ok
so the Hamilton is
[tex]H(r,p) = \frac{p^2}{2m} + q \phi(r,t)[/tex]
[tex]\frac{\partial H}{\partial t} = \frac{p}{m} \dot{p} + q \frac{\partial \phi}{\partial t}[/tex]
for the Lagrangian
[tex]\frac{\partial L}{\partial t} = \frac{p}{m} \dot{p} - q \frac{\partial \phi}{\partial t} + \frac{q}{c} \dot{r} A + \frac{q}{c} r \frac{\partial A}{\partial t}[/tex]
ok so then in order for dl/dt = - dh/dt then r and A need to be constant wrt time.
so that [tex]E = -\frac{\parital \phi}{\partial r}[/tex]
and [tex]B = \frac{\partial}{\partial r} \times A[/tex]
for the B part
[tex]\dot{r} = \frac{\partial H}{\partial p} = \frac{p}{m}[/tex]
so then [tex]p = m \dot{r}[/tex]
[tex]r(t) = \frac{p}{m} t + r_{0}[/tex]
[tex]\dot{p} = -\frac{\partial H}{\partial r} = - q \frac{\partial \phi}{\partial r}[/tex]
not sure how to do this part ...
If [itex]H\left(q^{i},p_{i},t\right)[/itex] is given by
[tex]H=\frac{1}{2m}\left(p_{x}^{2}+p_{y}^{2}+p_{z}^{2}\right) +q\varphi \left(x,y,z,t\right) -\frac{q}{c}\left(x A_{x}(x,y,z,t)+y A_{y}(x,y,z,t)+z A_{z}(x,y,z,t)\right)[/tex]
what is
[tex]\frac{dH}{dt}[/tex]
equal to?
HINT: Use Hamilton's equations of motion.
Daniel.
illl do it for the x and t only
but isn't what u wroteh texpression for hte Lagrangian and not hte Hamiltonian?
isnt hte hamilton [tex]H = \frac{p^2}{2m}+ q \phi(r,t)[/tex]
[tex]\frac{dH_{x}}{dt} = \frac{p_{x}\dot{p_{x}}}{m} + q \frac{\partial \phi}{\partial x} \frac{\partial x}{\parital t} + q \frac{\partial \phi}{\partial t} - \frac{q}{c} \dot{x}A - \frac{q}{c} x \frac{\partial A}{\partial x} \frac{\partial x}{\partial t} - \frac{\partial A}{\partial t}[/tex]
but i don't hink i need the totla derivative... in my text it says if the partial of H wrt time is equal to the negative of the partial of L wrt time are equal then H is constnat
its quite clear that A sohuld be indepednant on time and that the variables of motion x,y,z should be independnt of time as well
is this fine?
how do i solve for the hamiltonian equations of motion, however?
Hamilton's equations are
[tex]\dot{q}^{i}\left(t\right)=\frac{\partial H}{\partial p_{i}}[/tex]
[tex]\dot{p}_{i}\left(t\right)=-\frac{\partial H}{\partial q^{i}}[/tex]
U can compute them quite easily using the Hamiltonian's expression written above.
As for
[tex]\frac{dH}{dt}=\frac{\partial H}{\partial t} + \frac{\partial H}{\partial q^{i}} \dot {q}^{i} +\frac{\partial H}{\partial p_{i}} \dot{p}_{i} =0[/tex]
i'm sure you know how to compute each term of the equation above...
Daniel.
  • · Replies 16 ·
