How do I configure my network with a new switch and router?
  • Thread starter Thread starter BlackJack
    Network
The discussion revolves around configuring a home network involving a new switch and router, addressing connectivity issues and setup configurations. Participants explore various configurations, potential hardware problems, and troubleshooting steps related to network setup.
  • Homework-related
  • One participant describes their initial setup with a switch and router, expressing frustration over connectivity issues when trying to ping the router.
  • Another participant suggests detailing the exact cable connections to diagnose the problem more effectively.
  • There is a mention of the possibility of a faulty cable, with a request for methods to test the cable's functionality.
  • A participant proposes a different configuration, suggesting that connecting the computers directly to the switch and the switch to the modem might work better.
  • Concerns are raised about whether a crossover cable is needed when connecting directly to the modem.
  • Another participant emphasizes the importance of checking indicator lights on the hardware to ensure proper connections and suggests configuring the router to obtain IP addresses automatically.
  • There is a discussion about whether cable modems can function as routers and the implications for IP address acquisition from the cable company.
Participants express differing views on the correct setup and whether the router should be used in the configuration. There is no consensus on the best approach, and multiple competing views remain regarding the setup and troubleshooting steps.
Participants mention various configurations and the need for specific types of cables (patch or crossover) without resolving the implications of these choices. The discussion lacks clarity on certain assumptions, such as the capabilities of the modem and router involved.
BlackJack
*sigh*
I bought today a new switch and tried to setup my little network. Now the situation is like this. 2 PC's are connected to a switch (Type: FS605 v2). The switch is then connected to a router (Type: RP614). The router is then connected to my little modem :smile:. When I try to ping my router I get no answer... . What should I do ? Switch the switch and the router ? Or could it be that the bloody cable is faulty ? (I don't hope that's the case but if it is somebody is going to pay )
Please help :smile:
PS: Read "network help" for more info
https://www.physicsforums.com/showthread.php?threadid=9868
Computer science news on Phys.org
Update: Now I changed the settings. The router is now where the switch was. I can configure now the router which wasn't possible before. Could really a cable be faulty ? How can I test that ?
Seems like you have a little problem :wink:
can you list out EXACTLY how you have the cables hooked up.
example:
1. cable modem connected to WAN of router.
2. Computer 1 is connected to LAN of router
Also specify which computer your pinging from and how it is hooked up in relation to the other devices.
If it goes on like this I going to shoot my cablemodem.
I connected now my pc DIRECTLY with the cablemodem but when I try to establish a connection the software from the company says: standard gateway couldn't be configured and stops :frown:. I'll go to them tomorrow and bash they're bloody heads in . I need cable
Were you using a crossover when you hooked directly up to the modem? You're going to have to.
2 PC's are connected to a switch (Type: FS605 v2). The switch is then connected to a router (Type: RP614). The router is then connected to my little modem .
This would work better:
computers -> switch
switch -> modem
If you insist on using the router then disable all the features on it so it acts like a switch or hub.
-HBar
Originally posted by HBar
Were you using a crossover when you hooked directly up to the modem? You're going to have to. This would work better:
computers -> switch
switch -> modem
-HBar
And that would work HOW, if his cablemodem isn't a router as well? ;)
What cable company is this? TimeWarner? Cox?
Internet > Router > Switch > Computers
That setup will be fine if done right.
There needs to be more information posted to fix this though.
That is the correct setup (most of us have the router and switch in the same package).
FYI, most cable modems ARE routers, just not NAT routers (they are real routers). The problem of course becomes where to get the IP addresses - you have to buy them from the cable company.
Blackjack, check your indicator lights to make sure you have a good connection between hardware (and check in your instruction manuals for the type of cable - patch or crossover - you need). Assuming the router has a built-in switch, connect one of the lan ports to the wan port of the second switch and connect the wan port on the router to the cable modem.
Set up the computers to "obtain ip address automatically" and log onto the router to run its setup applet. You don't need to install any software, but the router likely won't work right unless you configure it.
14K
20K
