Solve Equilibrium Problem: Uniform Beam Weight & Forces
  • Thread starter Thread starter kbehie
    Equilibrium
The problem involves a uniform beam weighing 200 N that supports an additional weight of 450 N. Participants are tasked with finding the forces exerted by the supports at each end of the beam, considering the beam's horizontal position and the placement of the weights.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of equilibrium principles, including the balance of forces and moments. Some express uncertainty about how to proceed with two unknowns, while others suggest using torque to simplify the problem.
Guidance has been offered regarding the use of moments to eliminate unknowns, and some participants have shared their understanding of the forces involved. There appears to be a productive exchange of ideas, with some participants feeling more confident in their approach.
Participants mention the need for a force-body diagram and the application of Newton's laws, indicating a focus on foundational concepts in mechanics. There is also a reference to external resources for further clarification on torque.
kbehie
A uniform beam weighs 2.00 x 10^2 N and holds a 4.50 x 10^2 N weight. Find the magnitudes of the forces exerted on the beam by the two supports at its ends.
There is a diagram shown... the beam is horizontal, and a vector is drawn from the centre of the beam, pointing down. The weight is located 1/4 of the beam's length from the right hand supporting beam. The supporting beams are represented as F1 and F2. The beam appears to be resting on the supports, with no hinges or any other thing.
Any help? :cry:
I'll call the weight of the beam FWB and the weight of the actual weight being supported FWW. L is the length of the beam.
This is what I've done:
[-FWB(L/2)] + [-FWW(L/4)] + F1 + F2 = 0
I have two unknowns, F1 and F2. I don't know what to do with them!
Number 1, the center of the object where the force is drawn is the object's weight.
Number 2, 1/4 from RS (right side) is the weight.
Number 3, 3/4 from LS (left side) is the weight.
So, Newton's Law states that the sum of the forces must always be zero for an object to be in equilibrim (my understanding of it).
So, the weight of the object and the weight of the beam are the only vectors pointing downwards. The only vectors pointing upwards are the force done by the supports.
Seeing how we use vectors, by convention, take the upward direction as positive. Downward as negative.
Draw a force-body diagram.
Sum of all forces pointing upward = sum of all forces pointing downward.
For some reason, you will have to use torque, if you don't know it already X_X
T is force times distance. So you are given everything pretty much :-)
See if that helps... If you don't know torque, let me know.
Thanks so much for your help! I got some help from a student who took the course last semester, and it all makes sense to me now!
Thanks again :smile:
  • · Replies 18 ·
