| Thread Closed |
diffusion equation & separation of variables |
Share Thread | Thread Tools |
| Mar26-06, 03:51 AM | #1 |
hi
i have been trying to solve the diffusion equation using separation of variables. i know the answer should turn out something like the normal probability density function but its just turns into a mess when i try it. i am given the following information: [tex]\frac{\partial p}{\partial t}=D\frac{\partial^2 p}{\partial x^2}[/tex] where [tex]p=p(x,t)[/tex] [tex]p(0,0)=1[/tex] [tex]p(L,t)=0[/tex] [tex]p(-L,t)=0[/tex] where D is a constant (its not specified whether its negative or positive). it would be safe to say the sign for D which gives the easiest solution is the right one. now this is what i did [tex]p(x,t)=T(t)X(x)[/tex] [tex]X\frac{dT}{dt}=DT\frac{d^2 X}{dx^2}[/tex] which gives 2 equations, namely [tex]\frac{1}{DT}\frac{dT}{dt}=\lambda[/tex] (1) and [tex]\frac{1}{X}\frac{d^2X}{dx^2}=\lambda[/tex] (2) solving (1) and applying the initial conditions and boundary conditions i get [tex]T(t)=\exp(D\lambda t)[/tex] for (2) i assumed [tex]\lambda>0[/tex] to get [tex]X(x)=a \exp(\sqrt{\lambda}x)+b \exp(-\sqrt{\lambda}x)[/tex] then finally you plug all back in to [tex]p(x,t)=T(t)X(x)[/tex] now i'm not sure where to go here, or how to apply the initial and boundary conditions and nor can i see how this would end up being something like a normal pdf (with an exp(-x^2) in there somwhere) thanks in advance |
| Mar26-06, 06:30 AM | #2 |
The general solution will be a sum of the separate solutions: [tex]\Sigma X(x)T(t)[/tex] |
| Mar26-06, 08:20 AM | #3 |
i assumed lambda to be positive so that the solution to (2) was an exponential (if its negative then i think the solution involves sin and cos, further i would not know what the solution is if lambda can be positive and negative). i am doing stuff to do with the distribution of random walking particles over a period of time, its behaviour is said to display a normal distribution. i thought i needed a function like p(x,0) but it was not given. could you explain why p(0,0)=1 is not sufficient? is the equation not solvable given the information in the first post?
cheers |
| Mar27-06, 04:08 AM | #4 |
Firstly, on the positive assumption of $\lambda$...
In this problem, it's usual to take your $\lambda$ (seperation constant) as $-\lambda$ and $D$ as, say, $\alpha^2$, then you reqns become: $\dot{T}+\lambda\alpha^2=0$ and $\ddot{X}+\lambda\alpha^2X=0$ You should now see that the different signs of (this new) $\lambda$ give constant, normal or hyberbolic trig fn answers. For you initial condition - you need to specify $p(x,0)=f(x)$ - I guess you want $f(x)=0$ which is fine but you should probably state $0\le x\le L$ |
| Thread Closed |
| Thread Tools | |
Similar Threads for: diffusion equation & separation of variables
| Diffusion equation and neutron diffusion theory | Nuclear Engineering | 15 | ||
| Differential Equation- Separation of Variables | Calculus & Beyond Homework | 4 | ||
| Separation of variables and the separation constant | Calculus & Beyond Homework | 4 | ||
| Paritial Differential Equation separation of variables | Calculus & Beyond Homework | 8 | ||
| Separation of variables | Calculus | 1 | ||
