What Is the Best Method to Solve the Integral \(\int\frac{dx}{x^2\sqrt{4x+1}}\)?
  • Thread starter Thread starter G01
    Integral Method
The discussion revolves around solving the integral \(\int\frac{dx}{x^2\sqrt{4x+1}}\), which falls under the subject area of calculus, specifically integral calculus. Participants are exploring various methods and substitutions to approach this integral.
  • Participants suggest using substitutions such as \(u=\sqrt{4x+1}\) and discuss the implications of these substitutions on the integral. There are mentions of trigonometric substitution and partial fractions as potential methods. Some participants express uncertainty about their calculations and seek clarification on the correctness of their approaches.
The discussion is active, with multiple participants sharing their attempts and corrections. Some guidance has been offered regarding the use of substitutions and the structure of the integral, but there is no explicit consensus on a final solution. Participants are still exploring different interpretations and methods.
There are indications of potential calculation errors and adjustments to earlier assumptions, such as the factor of 4 in the integral. Participants are also questioning the validity of their approaches and the steps involved in the integration process.
G01
[tex]\int\frac{dx}{x^2\sqrt{4x+1}}[/tex] Can someone give me a hint? I've been working on this forever.
Let [tex]u=\sqrt{4x+1} \Rightarrow du=\frac{4dx}{\sqrt{4x+1}}[/tex]
also, [tex]\frac{1}{x^2}=\frac{16}{(u^2-1)^2}[/tex]
then use trig substitution
NVM, my calculation was wrong. but i can tell you that the answer involves arctanh.
This will give
[tex]\int\frac{dx}{x^2\sqrt{4x+1}} = 4\int \frac{du}{(u^2-1)^2}[/tex]
ok using trig substitution, i got the integral of cos^2x / sin^3x dx. Is this correct so far?
OK i think i may have gotten this. Is this the answer.
[tex]\frac{-\sqrt{4x + 1}}{2x} - 2\ln|\frac{\sqrt{4x + 1} - 1}{\sqrt{4x}}| +C[/tex]
I get
[tex]\int\frac{dx}{x^2\sqrt{4x+1}} = \log \left| \frac{\sqrt{4x+1}+1}{\sqrt{4x+1}-1}\right| -\frac{\sqrt{4x+1}}{2x}+C[/tex]
you can always differentiate to check.
EDIT: I forgot the factor of 4.
EDIT: Oops! should be:
Let [tex]u=\sqrt{4x+1} \Rightarrow du=\frac{1}{2}\frac{4dx}{\sqrt{4x+1}}[/tex]
to give
[tex]\int\frac{dx}{x^2\sqrt{4x+1}} = 8\int \frac{du}{(u^2-1)^2}= 2\log \left| \frac{\sqrt{4x+1}+1}{\sqrt{4x+1}-1}\right| -\frac{\sqrt{4x+1}}{x}+C[/tex]
BTW, for real x,
[tex]\mbox{arctanh}^{-1}(x) = \frac{1}{2}\log\left| \frac{x+1}{x-1}\right|[/tex]
which would help if you went to www.integrals.com
[tex]8\int \frac{du}{(u^2-1)^2}[/tex]
Im screwing up this integral somwhere. Did you use u = sec[tex]\theta[/tex]? And did you end up with:
[tex]-4\csc\theta\cot\theta - 4\ln|\csc\theta - \cot\theta| + C[/tex]
Thanks a lot for all of this help.
You didn't screw-up, I did. My bad, do this rather:
[tex]\frac{8}{(u^2-1)^2}=\frac{8}{(u-1)^2(u+1)^2}[/tex]
and now partial fractions
[tex]\frac{8}{(u-1)^2(u+1)^2}=\frac{A}{u-1}+\frac{B}{(u-1)^2}+\frac{C}{u+1}+\frac{D}{(u+1)^2}[/tex]
cross-multiply to get
[tex]8=A(u-1)(u+1)^2+B(u+1)^2+C(u-1)^2(u+1)+D(u-1)^2[/tex]
plug-in u=1 to get 8=4B or B=2;
plug-in u=-1 to get 8=4D or D=2;
plug-in u=0 to get 8=-A+B+C+D, but B=D=2, so 4=-A+C
plug-in u=2 to get 8=9A+9B+3C+D, but B=D=2, so -12=9A+3C
solving these two equations gives A=-2 and C=2. Finally, we get
[tex]\int\frac{8du}{(u-1)^2(u+1)^2}=\int\left(\frac{-2}{u-1}+\frac{2}{(u-1)^2}+\frac{2}{u+1}+\frac{2}{(u+1)^2}\right) du = -2\log |u-1|-\frac{2}{u-1}+2\log |u+1|-\frac{2}{u+1}+C[/tex]
[tex]= 2\log \left| \frac{u+1}{u-1}\right|-\frac{4u}{u^2-1}+C[/tex]
but [tex]u=\sqrt{4x+1}[/tex] so...
ok thanks a lot man...
  • · Replies 105 ·
13K
  • · Replies 22 ·
