| Thread Closed |
How much heat is converted into work? |
Share Thread | Thread Tools |
| Apr5-06, 10:55 AM | #1 |
1) Five thousand joules of heat is put into a Carnot engine whose hot and cold reservoirs have temperatures of 500 and 250 K, respectively. How much heat is converted into work?
here's what i did..... i know that.... QC / QH = TC / TH W = 5000, Tc = 250, Th = 500, Qh = ?, Qc = ? first I found Qh , which = (eCarnot = W/Qh) ----- and solve for Qh and get (Qh = W/eCarnot) ------eCarnot also equals [1-(Tc/Th)] = [1-( 250 / 500 ) ] = 0.5 so Qh = W / [1-(Tc/Th) = 5000 / 0.5 = 10000 after I got Qh I used the equation (Qc = Qh - W) to solve for Qc and this should be the answer... Qc = Qh - W = 10000-5000 = 5000 , so Qc = 5000 ...but it still wrong 2) The pressure and volume of a gas are changed along a path ABCA in the figure. The vertical divisions on the graph represent 4.5 105 Pa, and the horizontal divisions represent 4.0 10-3 m3. Determine the work done (including algebraic sign) in each segment of the path. ![]() a ) A to B = ? J b ) B to C = ? J c ) C to A = ? J This question..i know that W= P ( Vf-Vi ) but i still cant locate the dots on the graph!!
| Apr5-06, 03:15 PM | #2 |
For question one the maximum efficencey of a carnot engine is given by;
[tex]1 - \frac{T_{C}}{T_{H}}[/tex] This will give you a fraction. This in the fraction of the energy which can be used (i.e. work done). So all you need to do is multiply the input energy ([itex]Q_{H}[/itex]) by this fractional efficency. -Hoot
| Apr5-06, 11:15 PM | #3 |
Recognitions:
W = .5 Qh = 2500 J. So only 2500 J of the 5000 is converted into work. AM |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How much heat is converted into work?
| physics- work and heat | Introductory Physics Homework | 0 | ||
| work done or heat released | Classical Physics | 5 | ||
| Heat or Work | Introductory Physics Homework | 4 | ||
| Heat and Work interactions | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Heat at work | Atomic, Solid State, Comp. Physics | 4 | ||
