What Determines Electron Configuration?
  • Context: High School
  • Thread starter Thread starter hedons
    Atom Molecule Physics
The discussion centers on the principles of electron configuration and bonding in atoms, specifically covalent and ionic bonds. A covalent bond is formed when atoms share electrons to achieve stable outer shells, while ionic bonds involve competition for electrons. The bond angle in H2O is influenced by the repulsion of lone pairs of electrons on the oxygen atom, resulting in a bond angle less than 180 degrees. The number of electrons in a shell is determined by the attraction of the nucleus and the shape of the electron orbitals, which dictate electron distribution and repulsion.
  • Understanding of basic atomic structure and electron shells
  • Knowledge of covalent and ionic bonding principles
  • Familiarity with molecular geometry and bond angles
  • Concept of electron orbitals and their shapes
  • Study the principles of covalent and ionic bonding in detail
  • Explore molecular geometry and the VSEPR theory for predicting bond angles
  • Learn about electron orbitals and their shapes in quantum chemistry
  • Investigate the role of electron repulsion in determining molecular structure
Students of chemistry, educators teaching atomic theory, and anyone interested in understanding molecular bonding and electron configuration.
hedons
basic atom & molecule physics
After 30 views, I hadn't received any replies to this thread as posted in the "atoms" forum. Perhaps someone here can help me out.
Thanks,
Glenn
1. Why exactly does a covalent bond work? I understand how the electrons fill up the shells and so forth, but why does it work. Is the bond caused by the two atoms "competing" for the same electron that pulls them together? Is that a correct analogy?
2. Are electrons EXACTLY the same charge as the proton?
3. How is the bond angle in H2O predicted by physics?
4. What dictates how many electrons can occupy a shell?
ok, i have to admit that i saw this post but didnt have the correct material to answer...im not sure if i do but what the hey, ill give it a shot!
1. A covalent bond works i suppose because of the amount of electrons in the outer shell. If an atom needed an electron to fill its shell, and make the atom stable, and another atom had one electron in its outer shell then, it would 'want' to lose that atom so it could have a stable outer shell. So as you know, they bond, but SHARE the electron. Ionic bonds compete for the electron, whereas i suppose the covalent bonds are mutual.
2. Electrons are exactly the same charge as a proton.
3. Bond angles are predicted for H20 because that is the furthest the bonds can be away from each other. The reason it isn't 180 degrees is because the Oxygen has 2 lone pairs of electrons which have more repulsive power than any bond.
4. Nothing other than the attraction of the nucleus determines how many electrons in the atom/ion. However it depends on the shape of the electron orbitals which determine how many electrons. The electrons repel themselves away as much as possible, so i suppose that the amount in each shell would be due to the repulsion of the electrons and the size of the shell.
I hope this has been some use to you
JIMMY
  • · Replies 38 ·
