What Are the Lengths of Open and Closed Organ Pipes Based on Their Frequencies?
The discussion centers on calculating the lengths of open and closed organ pipes based on their fundamental frequencies. An open organ pipe has a fundamental frequency of 430 Hz, while the closed organ pipe operates at the second harmonic of this frequency, which is 860 Hz. To determine the lengths of these pipes, one must understand the relationship between frequency, wavelength, and the speed of sound, as the length cannot be calculated using frequency alone without knowing the speed of sound.
  • Understanding of fundamental frequency and harmonics
  • Knowledge of the speed of sound in air
  • Familiarity with the properties of open and closed organ pipes
  • Basic principles of wave mechanics
  • Research the speed of sound in air at different temperatures
  • Learn how to calculate wavelengths from frequencies using the formula: wavelength = speed of sound / frequency
  • Study the harmonic series in closed and open pipes
  • Explore the concept of pressure nodes and antinodes in wave mechanics
Musicians, acoustics engineers, physics students, and anyone interested in the principles of sound production in musical instruments.
kellyneedshelp
I do not understand what is meant in this question:
An open organ pipe has a fundamental frequency of 430 Hz. A closed organ pipe has a fundamental frequency that is the second harmonic of the open organ pipe. What are the lengths of the two pipes?
Does the bolded part mean that the fundamental frequency of the closed pipe is twice that of the open pipe? (since 2*fundamental frequency = second harmonic frequency) Something about the wording is tripping me up here.
If so, how would I find the length only knowing frequencies (not velocities or wavelengths)?
thanks!
Try plotting pressure changes along the length of the pipe. The highest pressure will be at the closed end of a pipe (anti node) and the lowest pressure will be at the open end of the pipe (node). This may help you determine the wavelength of the fundamental frequency.
HINT: The wavelengths will be fractional
Regards,
-Hoot
That is correct.
You can't. But you should know the speed of sound. (Look it up!)
19K
  • · Replies 19 ·
