How can I calculate the rate of change between a rising balloon and a cyclist?
The discussion revolves around a problem involving related rates in a scenario where a balloon rises and a cyclist moves along a straight path. The original poster attempts to determine how fast the distance between the balloon and the cyclist is increasing after a specific time interval.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the Pythagorean theorem and related rates to find the rate of change of distance between the balloon and the cyclist. There are attempts to clarify the correct values for variables involved, particularly the height of the balloon and the distance covered by the cyclist over time.
Some participants have provided guidance on how to approach the problem, suggesting the need to account for the balloon's movement and the changing height over time. There is an ongoing exploration of the correct values for the variables involved, with multiple interpretations being discussed.
Participants note that the height of the balloon changes as it rises, which affects the calculations. There is also mention of the cyclist's distance covered in relation to the balloon's height at different times.
jacy
Hello,
This is what am trying to solve
A balloon is rising at the rate of 5ft/s. A boy is cycling along a straight road at a speed of 15ft/s.when he passes under the balloon it is 45 ft above him.
How fast is the distance between the balloon and the boy increasing 3 seconds later
Please let me know if am on the right path
s^2=x^2+y^2
dy/dt = 5
dx/dt = 15
y= 45
so
2s ds/dt = 2x dx/dt + 2y dy/dt
is this correct but also we can conclude that ds/dt = 15.81,
but i think we have to find ds/dt.
In the above equation am getting two unkowns that's were am getting stuck. Please help, thanks.
The "y = 45" you should write as y(0) = 45 since y is really a function. In the equation you have last, 2s ds/dt = 2x dx/dt + 2y dy/dt, you have all the information you need. You can find s, x, and y by simple algebra and geometry, and you already know dx/dt and dy/dt. Then you can solve easily.
Thanks for replying. In this problem since its given to us that the cyclist is traveling at 15 ft/s, so in 3 seconds he will cover 45 ft and this will be the value of x. Now i have x, and y so i can find s and that will be s = 63.64 ft.
Now i can plug everything in the equation
ds/dt = 1/s (x dx/dt + y dy/dt)
so am getting ds/dt = 14.14 ft/s
please let me know if this is correct, sorry bout 15.81.
Not quite, you don't have the right value for s or y. Remember the balloon is moving too.
sorry bout 15.81.
My attitude is, it's far better to make errors at first but be right in the end than say nothing.
I used pythagorean theorem to get 15.81. I was thinking 15 to be the base and 5 to be the adjacent side.
Y= 45 ft high only when the cyclist is right under it. As the cyclist is moving away the balloon keeps on rising so the y value is changing. Balloon is rising at the rate of 5 ft/s, so this is dy/dt and 15 ft/s is dx/dt. My value of x is correct right. The cyclist is moving at 15 ft/s and in 3 seconds he would cover 45 ft. When the cyclist is 45 ft away from the balloon the height of the balloon will be 4 Y = 45 + y true. Thanks for looking into this problem.
The height of the balloon will be 60 feet. It is at 45 feet at time 0 and it moves with a speed of 5 ft/s over a period of 3 seconds.
Thanks orthodontist for ur help, am getting the answer
