Band structure of ferromagnetic metal
The discussion revolves around the band structure of ferromagnetic metals, specifically focusing on the phenomenon of exchange splitting of energy bands due to spin interactions in the presence of magnetic fields. Participants explore theoretical aspects, implications for the Fermi level, and seek references for further understanding.
  • Homework-related
  • One participant notes that exchange splitting occurs in ferromagnetic metals, leading to separate energy bands for spin-up and spin-down electrons, influenced by external magnetic fields.
  • Another participant explains that spin splitting can also occur in paramagnetic or diamagnetic materials under external fields, introducing the concept of Zeeman energy and its dependence on the Lande g-factor.
  • It is suggested that in ferromagnets, spin splitting does not require an external field, and the exchange interaction can be described mathematically, with references to the Brillouin function for temperature-dependent magnetization.
  • Concerns are raised about the negligible effect of spin splitting on the Fermi surface position, although some exceptions are noted, particularly in quantum Hall systems.
  • One participant expresses a desire for more information on specific equations and concepts mentioned, particularly regarding the equation for energy splitting and exceptional cases affecting the Fermi level.
  • References to various textbooks and papers are provided to assist in further research on the topic.
Participants appear to have differing views on the significance of spin splitting effects on the Fermi level, with some suggesting it is negligible while others indicate exceptions exist. The discussion remains unresolved regarding the specifics of these exceptional cases and the applicability of certain equations.
Participants reference specific equations and concepts that may depend on the definitions used and the context of the materials being discussed. There are unresolved questions regarding the location of certain equations in the literature and the conditions under which the Fermi level changes are significant.
Kit
for a ferromagnetic metal, the there will be splitting of energy band(one for spin up e- and one for spin down e-) under the influence of external magnetic field. the it is known as exchange splitting.
here are my questions
1. what determine the degree of splitting? i guess it depends on the materials and how strong is the external H-field. any formula can calculate or approximate how strong is the splitting?
2. so if the energy band is splitted, would it affect the fermi level of the metal?
thanks
Actually, for a paramagnetic or diamagnetic material, there will be spin split bands, in the presence of an external field, B. The spin splitting, or Zeeman, energy is given by [itex]U=g\mu_B \mathbf{B \cdot S}[/itex], where g is the Lande g-factor. [1]
In a ferromagnet, you don't need an external field to see spin splitting. The exchange interaction between charge carriers (with spin s at position r) and magnetic moments (with spin Sn at positions Rn) is given by [itex]U_{ex} = -\sum_n J(|R_n-r|) \mathbf{s \cdot S_n}[/itex] [2]. This can be calculated by your approximation of choice, and gives roughly, [itex]\Delta E = SJ(M)[/itex], where M is the temperature dependent magnetization within a domain, and can be approximated by the Brillouin function [3].
Whether your material is ferromagnetic or not, the effect of the spin splitting on the position of the fermi surface is negligible[4]. However, depending on the temperature (and in the case of a para/dia-magnet, also the applied field) the spin splitting can result in a significant polarization of the Fermi surface (whereas, in the absense of spin-splitting, the Fermi surface would be expected to have an equal number of spin up and spin down electrons, and hence, no net polarization) [5].[1] See any solid state textbook : Kittel, Ashcroft & Mermin, Marder, etc. talk about this.
[2] This is the basis of RKKY theory. You can look for references on RKKY or Indirect Exchange.
[3] I've seen this is Kittel and Ashcroft. Note the difference between the J used here - for the exchange integral - and the J you will come across in calculations of the Brillouin function - for the total angular momentum.
[4] There are some exceptions, notably in quantum Hall systems, at low filling factors.
[5] This is the basis of Spintronics. A review paper discussing the use of diluted magnetic semiconductors for spintronics will likely talk about this.
If you're having a hard time finding references, I could look some up for you.
thanks a lot ^^
let me look up the references first
i think i got a better idea but i need more infomation
1. i got the book of kittel but i cannot find the equation Delta E = SJ(M) in the chapter of ferronmagnetism and antiferromagnetism. where can i find more info about this, thanks.
2. i also want more details about the exceptional cases where the change in fermi level is not negligible.
thanks a lot
kit
1. C. Haas, Phys Rev 168, 531 (1968)
2. C. Haas, "
Spin-disorder Scattering and Band Structure of the Ferromagnetic Chalcogenide Spinels", IBM Journal of R&D 14, 282 (1970)
3. Magnetism vol IIB, edited by Rado and Suhl (1966). See the chapter by Kasuya.
thanks a lot
kit
I'm not sure what kind of references to point to for this. The one example that comes to mind is in the high-field quantum Hall regime (ie: a 2D electron gas in a large, perpendicular B-field). You'll have to learn a good bit of 2DEG physics for this. Marder, I think, has a part of a chapter devoted to this. Also, you can read
John H. Davies, The Physics of Low-dimensional Semiconductors : An Introduction, Ch 6: Electric and Magnetic Fields
ok
thanks a lot^o^
kit
  • · Replies 20 ·
