How Do You Calculate Line Current for Different Connections in a 3 Phase Line?
  • Thread starter Thread starter scorpio_wan1945
    Electronic Power
The discussion focuses on calculating line current for different connections in a 500V, 3-phase line using a 15 Ohm resistor and 3.83 mH reactors. For the series connection in wye, the line current is identical across each phase, as the resistor and inductor are in series with each phase to neutral. In the parallel connection in delta, the calculation involves Wye-Delta transformations or phase angle differences to determine the current distribution effectively.
  • Understanding of 3-phase electrical systems
  • Knowledge of series and parallel circuit configurations
  • Familiarity with Wye-Delta transformations
  • Basic concepts of inductance and resistance
  • Study Wye-Delta transformations in depth
  • Learn how to calculate phase currents in 3-phase systems
  • Explore the impact of inductance on current in AC circuits
  • Review phasor diagrams for better visualization of circuit behavior
Electrical engineers, students studying power systems, and professionals involved in circuit design and analysis will benefit from this discussion.
scorpio_wan1945
3 x 15Ohm resistor (R) and 3 x 3.83 mH reactors (L) are connected in different ways across a 500V, 3 phase line. without drawing a phasor diagram, calculate the line current for each of the following connections:
a. R and L in series, connected in wye
b. R and L in parallel, connected in delta
i have difficulty in starting to solve...anyone could shed some light here?
thanks
Well, in -a-, you just have a 15 Ohm resistor in series with a 3.83mH inductor from each phase to Neutral, right? It seems that the current in each leg would be identical and independent...
For -b-, you can look first at Wye-Delta transformations,
http://en.wikipedia.org/wiki/Y-delta_transform
or you could solve it using the phase angle differences...
  • · Replies 22 ·
