Is the Sum-Function of a Convergent Series Continuous on $\mathbb{R}$?
  • Thread starter Thread starter Math_Frank
    Convergence Series
The discussion revolves around the convergence of the series \(\sum_{n=0}^{\infty} \frac{1}{y^2 + n^2}\) for \(y \in \mathbb{R}\) and its implications for the continuity of the sum-function defined by this series. Participants explore the conditions under which the series converges and the nature of the sum-function.
  • Participants discuss the use of the comparison test for convergence, questioning the validity of comparing the series to \(\sum_{n=1}^{\infty} \frac{1}{n^2}\) and the implications of starting the summation at \(n=0\). There are inquiries about the uniform convergence of the series and its effect on the continuity of the sum-function.
The conversation includes various interpretations of the convergence of the series, with some participants suggesting that it converges for all \(y \in \mathbb{R} \setminus \{0\}\). There is ongoing exploration of the implications of uniform convergence on the continuity of the sum-function, with references to the Weierstrass M-test and the behavior of the series as \(y\) approaches infinity.
Participants note the importance of the starting index in the series and the necessity for \(y\) to be non-zero for convergence. The discussion also touches on the potential for confusion regarding the limits of summation and the behavior of the series at specific points.
Math_Frank
Hello
I have this question here which has puzzled me.
Given a series
[tex]\sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}[/tex]
Show that the series converge for every [tex]y \in \mathbb{R}[/tex]
By the test of comparison
[tex]\left| \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2} \right | \leq \frac{1}{n^2}[/tex]
Since its know that
[tex]\sum \limit_{n=0} ^{\infty} \frac{1}{n^2}[/tex] converge, then the series [tex]\sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}[/tex] converge for every [tex]y \in \mathbb{R}[/tex]
Second show that the series converge Uniformt on [tex]\mathbb{R}[/tex]
Again since
and since [tex]\sum \limit_{n=0} ^{\infty} \frac{1}{n^2}[/tex] converge.
Then by Weinstrass M-Test, then series Converge Uniformt on [tex]\mathrm{R}[/tex]
Third show that the sum-function
[tex]f: \mathbb{R} \rightarrow \mathbb{R}[/tex]
[tex]f(y) = \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}[/tex]
is continuous on [tex]\mathbb{R}[/tex]
Can I conclude here that since the series converge Uniformly on R, then its sum-functions is continuous on [tex]\mathbb{R}[/tex] ?
/Frank
So what is your question? What is puzzling you?
[tex]\left| \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2} \right | < \frac{1}{n^2}[/tex]
y can be 0, so this should be
Math_Frank said:
Hello
Given a series
Since its know that
There's a problem - the sequence you're comparing with is zeta(2), which converges (the sum is pi^2/6). However, that sum goes from n = 1 to infinity. When you start with n = 0, the first term is infinite, so obviously the sequence diverges.
I would suggest amending it like so :
[tex]\sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2} < \frac{1}{y^2} + \sum \limit_{n=1} ^{\infty} \frac{1}{n^2} = \frac{1}{y^2} + \frac{\pi^2}{6}[/tex]
BTW, y must be nonzero for convergence.
So What can I conclude that the series
doesn't converge for every [tex]y \in \mathbb{R}[/tex] ??
/Frank
/Frank
It converges for all [tex]y \in \mathbb{R}[/tex]\{0}
Okay,
what about my other conclusions regarding the series ?
Do they look okay?
/Frank
Math_Frank said:
Okay,
Do they look okay?
/Frank
I honestly do not know enough analysis to comment on those, I'm sure someone more knowledgeable will be along to handle those. :smile:
For all real [tex]y\neq 0,[/tex] we have
[tex]f(y) = \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}=\frac{\pi}{2y} \mbox{coth}( \pi y)[/tex]​
EDIT: my bad, I forgot to start with n=0, but hey: who's counting.
Hello benorin,
Could You please check if my other statements about Uniform Convergence and continuety for the series, are correct?
/Frank
Convergence is uniform for all non-zero real y, since
[tex]\left| \frac{1}{y^2 + n^2}\right| \leq \frac{1}{n^2}[/tex] for all [tex]n\geq 1[/tex]
and [tex]\sum_{n=1}^{\infty}\frac{1}{n^2}[/tex] converges, thus
EDIT: forgot a + sign in this one:
[tex]f(y) = \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}=\frac{1}{y^2}+ \sum \limit_{n=1} ^{\infty} \frac{1}{y^2 + n^2}[/tex]
converges uniformly for all [tex]y\neq 0[/tex] EDIT: by the Weierstrass M-test. Furthermore, as each term in the series is a continuous function of y, the sum function is also continuous by uniform convergence.
Note that you can derive the formula
[tex]f(y) = \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}<br /> =\frac{\pi}{2y} \mbox{coth}( \pi y)[/tex]​
from the partial fraction expansion of coth(x), which is
[tex]\mbox{coth}( x)= 2x\sum \limit_{n=1} ^{\infty} \frac{1}{x^2 + \pi ^2n^2}+\frac{1}{x}[/tex]​
Okay Thank You for correcting me :)
One final question though
I need to show that
[tex]lim _{y \rightarrow \infty} f(y) = 0[/tex]
Can I Do this by Wierstrass M-Test?
/Frank
[tex]f(y) = \sum \limit_{n=0} ^{\infty} \frac{1}{y^2 + n^2}=\frac{1}{y^2} \sum \limit_{n=1} ^{\infty} \frac{1}{y^2 + n^2}[/tex]
converges uniformly for all [tex]y\neq 0[/tex]. Furthermore, as each term in the series is a continuous function of y, the sum function is also continuous by uniform convergence.
Use uniform convergence, the main idea of uniform convergence is to allow the interchange of limiting processes, such as
[tex]\lim_{x\rightarrow \infty}\sum_{n=0}^{\infty}f_n(x) = \sum_{n=0}^{\infty}\lim_{x\rightarrow \infty}f_n(x)[/tex]
if the series is uniformly convergent for all x. Try it.
Then by Uniform Convergence
[tex]{\lim \sup_{n \rightarrow \infty}} \left| f_n(y) - f(y) \right| = 0[/tex]
Can I then conclude that
[tex]{\lim_{n \rightarrow \infty}}f(y) = 0[/tex] ??
What is meant is, do this:
[tex]\lim_{y\rightarrow \infty}f(y)=\lim_{y\rightarrow \infty}\sum_{n=0}^{\infty} \frac{1}{y^2 + n^2}= \sum_{n=0}^{\infty}\lim_{y\rightarrow \infty} \frac{1}{y^2 + n^2} = \sum_{n=0}^{\infty}0=0[/tex]​
