Determining Time When Comparing Two Equations
  • Thread starter Thread starter JDK
    Time
The discussion revolves around a kinematics problem involving two vehicles, a car and a motorcycle, starting from rest and accelerating at different rates. The objective is to determine the time it takes for the motorcycle to overtake the car, given their initial distance apart and their respective acceleration values.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the setup of the equations of motion for both vehicles, considering initial distances and accelerations. There is an exploration of how to equate the distance traveled by both vehicles to find the time of overtaking.
Some participants have provided guidance on correctly formulating the equations, including the importance of the initial distance. There is an ongoing exploration of how to manipulate the equations to isolate the variable for time, with some participants expressing uncertainty about the next steps in solving the equation.
Participants mention confusion regarding the initial distance variable and the correct application of the kinematic equations. There is a recognition of the need to combine terms and manipulate the equation appropriately, but no consensus on the final solution has been reached.
JDK
Hello all,
The last time I used these forums for help I got awesome responses. And here I am again needing help. Thought I'd just mosey on over and pop up my question I got. Here it is:
(2) A car and motorcycle start from rest at the same time form rest on a straight track, but the motorcycle is 25.0 m behind the car. The car accelerates at a uniform rate of 3.70 m/s2 and the motorcycle accelerates at a uniform rate of 4.40 m/s2.
(a) How much time elapses before the motorcycle overtakes the car?
I know that I need this formula --> d = Vi(t) + 1/2(a)(t^2)
And I know that it should be set up so that the two distance equations (one for the car and one for the motorcycle) are set equal to each other, so I can further solve the junctioned equation for (t). But, I seem to be having some trouble. I need to know how to go about solving this problem. Any help is very much appreciated! Thanks a lot.
- JDK
The formula "d = Vi(t) + 1/2(a)(t2)" isn't quite correct. It should be d = Vi(t) + 1/2(a)(t2)+ di where di is the initial distance from some reference point.
In this case, if you take the point from which the motorcycle starts as the reference point, then di= 0 for the motorcycle and di= 25 for the car (since the car starts 25 meters ahead of the motorcycle).
Of course, Vi= 0 for both motorcycle and car.
For the car, a= 3.7 m/s2 so d= (3.7/2)t2+ 25= 1.85 t2+ 25.
For the motorcycle a= 4.4 m/s2 so d= (4.4/2)t2+0= 2.2 t2.
The motorcycle will overtake the car when the two d s are the same:
when 1.85 t2+ 25= 2.2 t2. That's the equation you want to solve.
Thank you. Now I understand what I need to do. My problem was not knowing the 'Initial Distance Variable'.
Vi(t) + ½(Ac)(t²) + Dic = Vi(t) + ½(Am)(t²) + Dim
(0)(t) + ½(3.70 m/s²)(t²) + 25m = (0)(t) + ½(4.40 m/s²)(t²) + 0m
½ (3.70 m/s²)(t²) + 25m = ½(4.40 m/s²)(t²)
(1.85 m/s²)t² + 25m = (2.2 m/s²)t²
... excuse my lack of knowledge in this area but next am I supposed to square each side of the equation or divide the right side by (1.85)? Or is it something completely different. I seriously must be having an off day... *embarassment* This usually doesn't happen... I've tried a few things on it but I have no idea what the right answer is... that's my problem right now...
Combine the two terms that contain t2. (Subtract!)
*smacks self promptly*
Pheww... I better do a brain check... anyways, so this is what it should look like then - correct? (My symbols are showing up all googled... I'll change that...)
25m = (2.2 m/s²)t² - (1.85 m/s²)t²
25m = (0.35 m/s²)t²
25m / 0.35 m/s² = t²
71.4 s² = t²
(sqroot)71.4 s² = t
8.4 s = t
Thanks by the way! :)
  • · Replies 26 ·
  • · Replies 20 ·
31K
17K
