Is Linear Momentum Conserved in Relativistic Angular Acceleration?
  • Context: Graduate
  • Thread starter Thread starter carl fischbach
    Bullet Relativistic
The discussion revolves around the conservation of linear momentum in the context of a bullet undergoing angular acceleration while traveling at relativistic speeds. Participants explore the implications of angular acceleration on linear momentum, mass changes, and the effects of forces applied to the bullet.
  • One participant describes a scenario where a bullet is fired at 86.6% of the speed of light and then experiences angular acceleration, questioning why linear momentum appears not to be conserved as the bullet's mass increases.
  • Another participant challenges the notion of applying angular acceleration without affecting linear motion, suggesting that angular acceleration implies a change in trajectory.
  • Some participants propose that if the bullet's mass increases while maintaining constant velocity, its linear momentum should also increase, raising questions about energy transfer and system momentum.
  • There is a discussion about the relationship between angular velocity and the effective mass of the bullet, with some arguing that angular acceleration can occur without changing linear speed.
  • A later reply introduces the concept of transforming reference frames to analyze the mass and momentum of the bullet, suggesting that the total relativistic mass can be calculated based on the particles comprising the bullet.
  • One participant provides an example involving a particle accelerated in multiple directions, discussing the differential work required due to varying gamma factors, which complicates the understanding of momentum conservation.
Participants do not reach a consensus on whether linear momentum is conserved in the described scenario. Multiple competing views exist regarding the effects of angular acceleration on linear momentum and mass.
Participants express uncertainty about the definitions of angular acceleration and linear motion, as well as the implications of relativistic mass changes. The discussion includes unresolved mathematical steps and assumptions regarding energy transfer and system dynamics.
carl fischbach
Lets say you take a 30 gram bullet and fire it out
of a barrel that gives the bullet a linear velocity of 86.6% of c
with no angular velocity.
Now it's mass would be 60 grams. Next you
accelerate the bullet angularly while it is in
motion,with a force that in no way affects the
bullet's linear motion.Assuming mechanical
failure isn't allowed, the bullet is angularly
accelerated until the bullet's mass becomes
90 grams. The bullet's linear velocity of 86.6%
of c won't be affected, since the angular
acceleration force acted perpendicular to the bullet's
linear motion.Relativistic momentum of the
bullet is given by p=gamma*(rest mass bullet)*v.
You now have a case where linear momentum of the
bullet at 86.6% of c,before angular acceleration
is(p=2*.03*.866*c),after angular acceleration of
the bullet,the linear momentum is now
(p=3*.03*.866*c).Why aren't these 2 momentums
equal since linear momentum must be conserved?
Originally posted by carl fischbach
...Next you accelerate the bullet angularly...
What do you mean by "accelerate the bullet angularly? To me this means seems to mean that you're forcing it to move in a circle. As such that linear momentum of the particle is not conserved.
... while it is in motion,with a force that in no way affects the
How can you not effect linear motion and yet accelerate it? What do you mean by linear motion?
.. the bullet's mass becomes 90 grams. The bullet's linear velocity of 86.6% of c won't be affected, since the angular
linear motion.
The mass of the bullet is a function of speed alone. If the speed is 86.6% of c (i.e. |v|/c = 0.866) then gamma ~ 2 no matter what the velocity is. As such the mass must be twice its rest mass and thus remains 60 grams.
I think carl means the bullet starts spinning.
If the mass of an object in motion increases, and you keep its velocity constant, its linear momentum will increase.
You can get an idea of why and how this applies to your relativistic bullet by considering energy. If your bullet initially was not spinning, and you spin it up, you have to give it energy somehow.
If that energy comes from 'outside' the bullet, you need to consider how the spinning up was done; and however it was done you will need to consider the linear momentum of the whole system, not just the bullet.
If you spin up the bullet 'from inside', again you need to consider how that was done. Most likely it would involve some loss of mass (e.g. firing small rockets tangentially on the rim of the bullet), and you need to consider the linear momentum of the whole system (e.g. include the linear momentum of the gas molecules in the rocket exhaust).
relativistic bullet
The angular velocity I am referring to, is the
same angular velocity a bullet has when it
it is fired out of a standard rifle barrel,it
spins.It is possible to accelerate a bullet
angularly when the bullet is traveling in a
straight line and not effect it's trajectory.
If you have a device that is traveling next
to the bullet at 86.6% of c that applies an
accelerating force evenly all around the
outside surface of the bullet,perpendicular to
it's line of travel, you will not effect it's
trajectory or speed.When you accelerate
angularly you are increasing the effective mass
of the bullet,since energy=mass,but you are
not changing it's linear speed.If you allow the
bullet's angular velocity to remain constant
when decelerating it from 86.6% of c to zero it
feels heavier to the decelerating force than the
accelerating force,when no angular velocity is
present.It follows that linear momentum posessed by
the bullet with angular velocity is
(p=3*.03*.866*c)
spins.
Okay. I see now. You're not thinking of the bullet as a particle then. If the total momentum is zero but the bullet is spinning about its center of mass then the mass of the bullet has increased from m_o to m'_o. Now change to a frame of referance which is moving relative to the bullet. The momentum is then p = gamma*m'_o*v.
When you accelerate
Yes. Quite true.
There is an easy way to look at this. Think of the moving spinning bullet as composed of particles. As the bullet moves down the barrel the particles are moving in a helix. The mass of the particles depends on the speed of the particles moving along the helix. The bullet speed then reflects only one component of the velocity of the particles. The mass of the bullet is then the sum of the masses of all the particles.
Carl - I think I have the answer to your question.
The transformation equation for the Lorentz funny factor is Eq. (2) at
http://www.geocities.com/physics_world/sr/energy_momentum_trans.htm
Think of the most simple example: Let S be an inertial frame of referance. Let a particle of proper mass m0 move in a circle in the yz-plane at constant speed u. Call S the rest frame.
Then m = m0/sqrt(1-u^2/c^2) is the mass of the particle in frame S.
Now transform to the frame S' which is moving in the +x direction with velocity v. Let gamma = 1/sqrt[1-v^2/c^2]. Let u' be the speed of the particle as measured in S'. Then the mass, m', of the particle in the frame S' is given by
m' = m0/sqrt(1-u'^2/c^2)
This can be expressed in terms of the mass of the particle as measured in frame S as
m' = m/sqrt(1-v^2/c^2)
It should be clear that we can now just add up all the masses of all the particles which make up the rotating bullet in S and obtain the equation
M' = M/sqrt(1-v^2/c^2)
where M is the total relativistic mass in S which then becomes the zero momentum frame. In that frame it is reasonable to call M the 'rest mass' of the bullet. Notice that the rest mass of the bullet is then the sum of the relativistic masses of the particles which make up the bullet
The equation for the momentum is then trivial
P = Mv
The results above can formally be obtained by noting that mass, m is proportional to the time component of the 4-momentum vector P where
P = (mc, p)
where p is the momentum vector. Thus one can simply form this vector in S and transform to S' and you have m'
relativistic bullet
Arcon I'm not high up the ladder in theoretical
physics it's a hobby of mine so I didn't
really fully follow your explanation, but that
doesn't matter.Here's an example I might better
make my point with. You start with a x-y axis
and place a particle at the origin and accelerate
it in the y direction to 61.2% of c,then
accelerate it in the x direction to 61.2% of c so
the net velocity of the particle is 86.6% of c
at 45 degrees.Since the gamma factor at 61.2% of
c is 1.265 the change in gamma factor of the
particle in the
y axis acceleration is 1.265-1 or .265 the change
in the gamma factor in the x acceleration is
2-1.265 or .735 . Roughly 3 times the work
was required to accelerate in the x direction
than in the y direction since the gamma factor
is 3 times greater in the x direction. The integral
of force as a function of time acting on the x or
y-axis during acceleration is not equal when a particle is
accelerated in this way.If particle
is now moving at 86.6% of c is decelerated to zero with
equal forces on the x and y-axis it will
decelerate in a straight line.You now have
a situation where the forces of acceleration
and deceleration are not balanced for the x and y
axis.In a nonrelativistic situation these forces
will be balanced when a particle is accelerated
and decelerated in this way.
...Roughly 3 times the work was required to accelerate in the x direction than in the y direction since the gamma factor is 3 times greater in the x direction.
Let
gamma1 = 1.26
gamma2 = 2.00
What you did was to do an amount of work in the y-direction. That amount of work equals the change in kinetic energy of the particle. The change in kinetic energy was
dK = (gamma1-1)m0c2 = 0.26 m0c2
Then you did more work on the particle by exerting a force on it in the x-direction. Note that this was perpendicular to the initial velocity. The final kinetic energy was
K = (gamma2-1)m0c2 = m0c2
K - dK = 0.74 m0c2
The reason for this is that the larger the velocity the more force you have to exert to obtain the same changes in velocity. In the first part the initial velocity was zero. You were then exerting a force which was at all times parallel to the velocity. The force is related to the acceleration by
Fy = gamma3m0a = mLay
where
mL = gamma3m0
is called the Longitudinal mass. Notice that when you first applied the force the velocity was zero and therefore
Fy = m0ay
When you then exerted a force in the x-direction the particle had a non-zero velocity. So the moment you applied the force it was already moving and as such had a greater inertia. However the force/acceleration relation for force perpendicular to velocity is different than it was for the parallel case.
Fx = gamma m0a = mTax
where
mT = gamma m0
is called the Transverse mass.
The integral of force as a function of time acting on the x or y-axis during acceleration is not equal when a particle is accelerated in this way.
Yes. That is correct. A very astute observation on your part in fact. Nice work!
Hope that helps!
No, it is still 30g.
Next you
90 grams.
You mean you want to give it spin?
P = gamma*m*v
By putting spin on it m, not gamma, changes. The momentum would be greater by the factor that m changed by. If you add spin in such a way that the speed did not change then there is a back reaction on the sorce of the torque on the bullet conserving momentum.
No, mass is invariant.
See also
http://www.geocities.com/physics_wo...weight_move.htm
It addresses how to measure the increase in mass of a system when the particles have an increased speed and thus an increase "internal" energy...The transformation equation for the Lorentz funny factor is Eq. (2) at
http://www.geocities.com/physics_wo...entum_trans.htm
That is your own site and is wrong as mass is invariant to velocity transformation.
...is called the Longitudinal mass...is called the Transverse mass...
Instead of introducing more and more mass definitions, just do it the correct and easy way. Use modern relativity in which there is only one mass m which is invariant.
gamma 2 or 3
Is gamma 2 or 3?
This is my view on the situation:
To keep things simple let say you put the 30 grams
of the bullet on the outside circumference of the
bullet at radius R.Next you would start the bullet revolving
along it's central axis at a speed where it's
total energy would now be the equivalent 45 grams.
If you didn't know that bullet was spinning
it would now have a rest mass of 45 grams. If
you then accelerated the bullet to 86.6% of c
then Gamma would be 2 and the bullet would have
a total energy of 90 grams.
If you knew the bullet was revoling then it must
have a velocity with respect to a stationary
observer so therefore it must already have
a Gamma factor, if you knew it's angular velocity
and that it's total energy is 45 grams you could
calculate that it's stationary mass would be
30 grams and the Gamma factor would be 1.5.Now
when you accelerate the bullet to 86.6% of c
the molecules of the bullet would have a helical
trajectory with a velocity that would produce
a Gamma factor of 3 and a total energy of the
bullet of 90 grams.So you could say technically
that the gamma factor could be 2 or 3 in my view.
To keep things simple let say you put the 30 grams of the bullet on the outside circumference of the bullet at radius R.Next you would start the bullet revolving along it's central axis at a speed where it's total energy would now be the equivalent 45 grams. If you didn't know that bullet was spinning it would now have a rest mass of 45 grams. If you then accelerated the bullet to 86.6% of c then Gamma would be 2 and the bullet would have a total energy of 90 grams.
That is 100% correct.
If
If you knew the bullet was revoling then it must have a velocity with respect to a stationary observer so therefore it must already have a Gamma factor, if you knew it's angular velocity and that it's total energy is 45 grams you could calculate that it's stationary mass would be 30 grams and the Gamma factor would be 1.5. Now when you accelerate the bullet to 86.6% of c the molecules of the bullet would have a helical trajectory with a velocity that would produce a Gamma factor of 3 and a total energy of the bullet of 90 grams.
That is 100% correct. This is a result of the way mass transforms from one frame to another. Assume the x-component of velocity in the frame S is zero. There is a gamma factor for the bullet in this frame. Go to the inertial frame S' moving in the x-direction. There is a gamma factor due to this motion. The overall gamma of the bullet in S' is the product of these two gammas. Thus M = Gamma(s') gamma(bullet)m_o = (2)(1.5)(30 grams) = 90 grams.
For proof of this relationship between gamma's please see
http://www.geocities.com/physics_world/sr/velocity_trans.htm
The relevant equation is Eq. (15)
Is gamma 2 or 3?
2.
Ok.
If
Absolutely not. Mass is invariant to translational velocity boosts.
http://www.geocities.com/physics_wo...ocity_trans.htm
This is your own site pmb, not a valid referrence. Instead see
http://www.geocities.com/zcphysicsms/chap3.htm
Arcon, DW - Enough with Waite & pmb. Discuss the issues at hand. Lose the baggage. Your discussions are welcome. The harassing is not. My patience is coming to an end.
  • · Replies 114 ·
13K
  • · Replies 16 ·
