Finding Electric Field and Speed of Electron in a Parallel-Plate Capacitor
The discussion revolves around calculating the electric field and the speed of an electron as it exits a parallel-plate capacitor. The original poster presents a scenario involving an electron entering the capacitor with a specified initial speed and a measured deflection distance upon exit.
  • Mixed
  • Participants explore the relationship between force, mass, and acceleration using Newton's second law and the definition of electric field. There are attempts to compute time, acceleration, and final velocity, with some questioning the accuracy of their calculations.
Participants are actively engaging with the problem, sharing their calculations and questioning each other's methods. Some have identified potential computational errors, while others are seeking clarification on the problem's requirements. There is a collaborative effort to understand the discrepancies in their answers.
There are indications of confusion regarding the problem's setup and the specific values needed for calculations. Participants mention issues with units and the need for accurate measurements, as well as the constraints of an online grading system that limits attempts.
tony873004
Figure 19-38 shows an electron entering a parallel-plate capacitor with a speed of v = 5.25 106 m/s. The electric field of the capacitor has deflected the electron downward by a distance of d = 0.626 cm at the point where the electron exits the capacitor.
(a) Find the magnitude of the electric field in the capacitor.
b) Find the speed of the electron when it exits the capacitor.
Part A:
E=F/q, but q is not given
F=ma, but m is not given
F=kQq/r2
I don't know where to start.
Part B:
Compute time:
[tex] \begin{array}{l}<br /> t = \frac{d}{v} \\ <br /> \\ <br /> t = \frac{{0.025m}}{{5.25 \times 10^6 m/s}} = 4.2857 \times 10^{ - 8} s \\ <br /> \end{array}[/tex]
Compute acceleration:
[tex] \begin{array}{l}<br /> y_f = y_i + v_i t + 0.5at^2 \\ <br /> \\ <br /> a = \frac{{y_f - y_i - v_i t}}{{0.5t^2 }} \\ <br /> \\ <br /> a = \frac{{0.626m - 0 - 0t}}{{0.5t^2 }} \\ <br /> \\ <br /> a = \frac{{0.00626m}}{{0.5\left( {4.2857 \times 10^{ - 8} s} \right)^2 }} = 6.81644 \times 10^{12} m/s^2 \\ <br /> \end{array}[/tex]
Compute velocity:
[tex] \begin{array}{l}<br /> v_{y,f} = v_{y,i} + at \\ <br /> \\ <br /> v_{y,f} = 0 + 6.81644 \times 10^{12} \times 4.2857 \times 10^{ - 8} \\ <br /> \\ <br /> v_{y,f} = 292133.33 \\ <br /> \\ <br /> v_f = \sqrt {v_{y,f}^2 + v_x^2 } \\ <br /> \\ <br /> v_f = \sqrt {(292133.33m/s)^2 + (5.25 \times 10^6 m/s)^2} \\ <br /> \\ <br /> v_f = 5.258122 \times 10^6 m/s \\ <br /> \end{array}[/tex]
But this answer is wrong.
What are the question sof part A and B?
Oops. Maybe that's why I'm confused. I don't know what they're asking :).
I edited the post to include the questions. Thanks for pointing that out.
1.)
F=ma where m is the mass of an electron.
E=F/q where q is the charge of the electron
I'll have a look at 2.)
Thanks, that's what I was thinking, but I can't trust my answer since I seem to have gotten acceleration wrong in part b, unless my mistake in part b comes after my computation of acceleration.
To be honest part b looks ok to me. Do you have the real answer and perhaps I could work backwards? Probably the fact its past midnight here is not helping me think straight ;)
Is the answer 6x10^6 m/s? If so I'll tell you how I arrived at that.
I don't know what the answer is. The online grading system gave me the red x on the answer I put. In fact, I'm out of guesses, so I can't try 6e6. But I'd still like to know how to do it, and I still need a good value for acceleration for the f=ma part.
Just curious. If you think it's 6e6, then where did we depart in methods?
Thanks for your help so far.
To calculate the velocity i used:
V^2=u^2+2as
That was all really as far as acceleration was concerned I concur with yourself. The final answer was 5.99... some other bunch of numbers so i rounded it up.
What is u and what is s?
For part A, it gives the units for the answer as N/C.
I used my acceleration value of 6.81644e12 with the mass of an electron, 9.11e-31, and the charge of an electron 1.6e-19 C.
6.81644e12 m/s2* 9.11e-31 kg / 1.6e-19 C
-38.11 N/C
But it says this is wrong too. This problem looks so simple.
tony873004 said:
Part B:
Compute time:
Redo this calculation. It's off by a factor of 10.
Thanks for catching that. It's off by more than that. Now I get
4.76E-09
I'll blame it on the calculator :)
u is initial velocity and s is displacement. With the numbers for part a that you've quoted i get 38.81 N/C. I fear perhaps there are just a few computational errors. As far as I can see the method for A is fine just computational errors perhaps (remember it says magnitude aswell) and if you do part b with the formula i used that should be alright.
Oh well there you are how did I not spot that!
Typos galore in this one! Where I wrote 0.025 should read 0.0225, which is the number I used in the calculator. So I am off by exactly 1 magnitude like Doc Al said, and not more like I thought I was.
The answer for part A is 3881. This is exactly 2 magnitudes off of the answer we were getting, which is not surprising since time was off by 1 magnitude and it gets squared.
Thanks Kurdt and Doc Al. Now I understand :)
Was doc al mainly I have to say but its weird cos I tried the time numbers myself and because it was an exact order of magnitude out I did not notice. Apologies.
9K
