Inverse Functions: Logarithms & Qualitative Conclusions
The discussion revolves around the concept of inverse functions, specifically focusing on logarithms and their relationship with exponential functions. Participants explore the definitions and properties of logarithms as inverses, as well as the general idea of inverse functions in mathematical terms.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the definition of logarithms and their role as inverses of exponential functions. There are inquiries about how to mathematically demonstrate that two functions are inverses of each other, particularly using examples like (x + 1) and (x - 1). Some participants question the existence of inverse functions and the conditions required for them to exist.
The discussion is active, with various participants providing insights and definitions related to inverse functions. Some guidance has been offered regarding the properties of logarithms and the conditions under which inverse functions exist, but there is no explicit consensus on all points raised.
Participants are navigating the definitions and properties of logarithmic and exponential functions, as well as the general concept of inverse functions. There are mentions of the need for functions to be one-to-one and onto for inverses to exist, which adds complexity to the discussion.
Byrgg
In one of my older threads, I posted the following:
log_b (n) = x if and only if b ^ x = n, where b > 0, and b is not equal to one.
It was said this defines logarithm as the inverse to exponential. I don't really see how that works here, I think it just shows how you write logarithms. Could anyone clear this up?
Also, I'm wondering something about inverses in general. Say you have a simple example like (x + 1) - 1 = x. This equation says that (x + 1), and (x - 1) are inverses, correct? Is there a way to mathematically show that? Or do you simply conclude this qualitatively? I'm thinking if it's just qualitative, you could say something like this:
If (x + 1) - 1 = x, then it must be that + 1 and - 1 do opposite things to x. Thus, you can conclude that (x + 1) and (x - 1) are inverse functions, seeing as they do opposite things to x.
Does that sound right? Is there I way to mathematically show this? I know that if you take (x + 1) and (x - 1) and sub one into the other you get either (x + 1) - 1 = x or (x - 1) + 1 = x, but can you do this backwards, by starting from (x + 1) - 1 = x or (x - 1) + 1 = x?
Thanks in advance for any help I get.
Intuitevely, the inverse of a function f(x), noted f^(-1)(x) is such as :
f(f^(-1)(x)) = x . The inverse function "cancels" the effect of f(x) over x.
I would use this definition to prove the inverse.
The subtle question is : Does the inverse funtion exist ?
Interesting analysis arises from such questions and a lot of theorems are devoted to such a topic.
Logarithms and exponentials function can be defined from one another as being inverses , hence Exp(Log(x)) = x
Of course,this is true only if the conditions you stated are fufilled(i.e. same basis not equal to one)
For your other question, f(x) = (x+1) has (x-1) as inverse and vice versa. As you mentionned, it "works both ways".
This is just how the logarithm is defined. It is defined to be the inverse function of the exponential function.As for inverse functions in general, two functions let's call them f(x) and g(x) if and only if
f(g(x)) = g(f(x)) = x
If you can show that this relationship holds for two given functions then these functions are inverses of each other.
Byrgg:
Since it can be proven that:
1. The exponential function is strictly increasing
and
2. Every strictly increasing function HAS an inverse
I really don't see your trouble.
I think I recall from my high school calculus book that log x is defined as [tex]\int_1^x \frac{dy}{y}[/tex], and that ex is defined as the inverse of log x, from which general exponentiation (exponentiation to irrational powers) is defined. I don't know how accurate this is.
No, "showing how you write logarithms" wouldn't have anything to do with exponentials, would it? Saying "logbn= x if and only if bx= n" is exactly saying that they are inverses. If f(x)= y, then f-1(y)= x. That's exactly logb[/sup](x)= y, by= x. Another characterization of inverse functions is: f(f-1(x))= x and f-1(f(x))= x. From your equations logb(b^x)= logb(n)= x and [itex]b^{log_b n}= b^x= n[/itex].
Yes, that is precisely f(f-1(x))= x. Here f-1(x)= x+ 1 and f(x)= x-1. f(f-1(x))= f(x+1)= (x+1)-1= x and f(f-1)(x))= f(x-1)= (x-1)+ 1= x.
Yes, that's a very good, less technical, way of thinking about inverse functions: whatever f "does", f-1 "undoes".
Well, once again, f(f-1(x))= x and f-1(f(x))= x are the ways to "mathematically show this". Since applying first one and then the other, whatever one "does" to x, the other "undoes".
You can see why inverse functions are so important: in order to solve the equation f(x)= b, you must "back out" and "undo" whatever f has "done" to x. If you know the inverse function of f, you only need to apply that function to both sides of the equation: f-1(f(x))= x= f-1(b).
Of course, solving equations, in general, isn't that easy! That's because most functions don't have inverses. If f(x1) and f(x2) both equal y, what is f-1(y)? Is it x1 or x2? Since there is no way to answer that, only "one to one" functions have inverse. Further, if there is no x such that f(x)= y, then there can be no f-1(y). Only "one to one" and "onto" functions have inverses. Since (2)2= 4 and (-2)2= 4, as simple a function as f(x)= x2 does not have an inverse. f(x)= x2 is neither "one to one" nor "onto". Instead we "modify" the function to : g(x)= x2 if [itex]x\ge 0[/itex] and is undefined for x< 0. We can say that f is "one to one" and "onto" the set of non-negative numbers. Now, if y is a non-negative number, [itex]g^{-1}(y)= \sqrt{y}[/itex] is defined. Of course, if we have the equation f(x)= x2= -4, precisely because f(x)= x2 is not "onto" the set of all real numbers, we have to say there is no solution because f-1(-4) is not defined. Also, because f(x)= x2 is not "one to one", to solve f(x)= x2= 4, we have to re-interpret the equation as g(x)= 4 to get x= 2, then recognize that there are two solutions, 2 and -2.
Err, HallsofIvy said no to my first question, while everyone else says yes it seems.
How does this define logarithm as the inverse of the exponential? log_b (n) = x and b ^ x = n are the same thing...
Also, is my mathematical explanation here right?(see below)
(x + 1) - 1 = x
If you take (x + 1) as the first function of x, you must apply the inverse to it to obtain x, which is x - 1. So if you sub this into x - 1, you get
(x + 1) - 1 = x, since x - 1 does the opposite thing to x, you just proved that (x - 1) and (x + 1) are inverses.
Quote : "log_b (n) = x and b ^ x = n are the same thing..."
They are not the same thing, but they are linked by an equivalence relation.
It means that if one is true, the other is and vice versa.
HallsofIvy is right in the sense that logarithm's properties and algebra can be considered separately, without mention of the exponential function.
But, to rigorusly proove certain properties of to just define the function itself, it is a possibility to use the inverse of that particular function if the properties of the inverse funtion are well defined.
And I think your last explanation sounds right, just use HallsofIvy's notation/definition to "write it properly".
Also, his statement gives a damn good explanation of what to be aware of in these situations so listen to the man... :-)
No, I did not say "no" to your first question! What I said was
That was in response to your statement
(x + 1) - 1 = x
If I take f(x) = x + 1
and g(x) = x - 1
then what you have shown is that g(f(x)) = (x+1)-1 = x
However you have NOT shown that these two functions are inverses of each other what you have shown is that g is a left inverse for f, or similarly that f is a right inverse for g.
To show that these two functions are inverses you need to show that
Aren't log_b (n) = x if and b ^ x = n two different ways of saying the same thing? If you rewrite log_b (n) = x you get b ^ x = n...
Also, what is the process to work backwards from (x + 1) - x = x to showing that (x + 1) and (x - 1) are inverses? Or has this already been shown?
I'm going to assume you mean (x + 1) - 1 = x not (x + 1 ) - x = x.
let's say we have the function
f(x) = x + 1
for simplicity let's also say y = f(x)
then y = x + 1.
Now if we want to find the inverse function g(x) = f-1(x)
Then g(y) = x because I have defined g to be the inverse function of f.
The typical way to find an inverse function is to start with an initial function like
y = f(x)
Now if you can solve for x in terms of y then you have a function in terms of y such as x = g(y) and this function will be the inverse of the original function f, but this is not always possible to do, and actually is very rarely possible to do especially in cases involing several trig functions, and higher order polynomials.
I'll go through an example with y = x + 1
Now for sake of ending up with a function in relatively the same form I am going to interchange x and y so that I will end up with a function for y in terms of x, however I am going to denote y by y' to denote that this is not the same y.
So now I have x = y' + 1
or y' + 1 = x and subtracting 1 from each side leaves
y' = x - 1 so I now have found the function that is the inverse of the original, and you can easily show that if I let y = f(x) and y' = g(x) that f(g(x)) = g(f(x)) = x to more rigorously show that these functions are indeed inverses.
That true because [itex]b^{log_b(x)}= x[/itex], if [itex]log_b(n)= x[/itex], you get [itex]b^x= n[/itex]. In other words, logb(n)= x is equivalent to bx= n precisely because logb(x) and bx are inverse functions.
d_leet said:
I'm going to assume you mean (x + 1) - 1 = x not (x + 1 ) - x = x.p
Yeah, I did mean to type (x + 1) - 1 = x, sorry about that.
When you started the work, you started simply with f(x) = (x + 1). I Wanted to know how you go about it right from (x + 1) - 1 = x.
Also, what would change if you didn't switch y and x towards the end there?
As for Hallsof Ivy... I think I'm understanding that better now, those two equations are equivalent because taking the log(base b) of n results in x only if b ^ x = n. This can only be true if the logarithm is the inverse of the exponential, and so therefore this must define them as inverses, right?
If i hadn't changed y and x, it really wouldn't have made a difference i would have ended up with the same inverse function, but it would have been in the form of x as a function of y and i would have had x = g(y) = f-1(y) which would still have been the inverse function and if I wanted this to be in the same form as y = f(x) I can just change the variables to y = g(x) and it really doesn't matter as long as you are consistent and understand what you are doing when you do this. And I apologize if this explanation doesn't make much sense because I don't think it does but I'm having trouble trying to explain this in a way that makes some logical sense.
And I'm not quite sure what you mean by this, I tried to you how to get
y = x - 1 as the inverse function of y = x + 1 in my last post, so I think I am just not understanding the questiong you're asking here.
When you started to show the work, you said "let's say we have the function f(x) = x + 1".
I wanted to know where that came from, I was wondering how you would start at (x + 1) - 1 = x, and then get to the rest.
Also, how would you work with the resulting function if you didn't switch y and x there? Could you show me how that would work out?
If I start from there I have (x + 1) - 1 = x + 1 - 1 = x + (1 - 1) = x + 0 = x.
All that really says is that -1 is the additive invers of 1.
But I guess you could look at it like this
give (x + 1) - 1 = x
Now let u = x + 1 you could say that u = u(x)
Then we have u - 1 = x
Now let's say that v = u - 1 but it wouldn't really change this equation if I say that u = x, note that this has nothing to do with the previous function I defined, so I now have v = x - 1 = v(x)
and so I have v(x) = x -1 so let's substitute u(x) into this giving
v(u(x)) = u - 1 = u(x) - 1 = (x + 1) - 1 = x saying that v is a left inverse of u ot u is a right inverse of v.
To me this seems incredibly messy and awkward because I started with an equation, a statement that I can't change and built from this functions, I really don't like this and this process doesn't really seem logical to me. It's preferable to find an inverse the way I stated in one of my previous posts.
Again I don't really understand your question here. I thought that I tried to explain this in my last post.
That part there kind of confused me, more specifically when you said "but it wouldn't really change this equation if I say that u = x, note that this has nothing to do with the previous function I defined".
I didn't really understand that part, could you explain it please?
Also, why would you assign (x + 1) the value 'u' like you did?
Now about the reversal of x and y, if you didn't reverse them, it would've ended up like this, right?
y = x + 1
y - 1 = x
What would you have done with this relationship? That is more what I'm asking for this part.
What was the u = x part about?
Also, why would you assign (x + 1) the value u like you did?
Because this thread is about inverse functions and the only way I was able to get inverse functions from the equation you wanted to start with was to assign some part of that function a new name. I also said in my last post that I really didnt like this way of finding two inverse functions, it was messy and I'm sure that not everything in that post logically followed from what came before it.
y = x + 1
y - 1 = x
Yes so you have that x = y - 1 this is x as a function of y and goes back to what I said earlier that if y = f(x) then x = g(y) where g is the inverse of f. However, if I wanted them both to be functions of x and to maybe graph this so that it looks different than the original function( specifically it is a reflection about the line y = x which is probably better justification for interchanging x and y to find the inverse function) you should change the places of x and y. Again this is a rather poor explanation on my part, but it makes some sense, and hopefully enough to try and explain the problem.
Ok, that answered the last part of that quote, which was: "Also, why would you assign (x + 1) the value 'u' like you did?", but what about the first part of the question I asked in that quote?
So then if you didn't switch x and y, from f(x) = x and g(y) = x, you would get:
f(y - 1) = x and g(x + 1) = x
What would you do from there?
Maybe this?
Since f(y - 1) = x and g(x + 1) = x
f(y - 1) = g(x + 1)
And then what? I don't think there's much else to do...
Maybe this?
f(y - 1) = g(x + 1)
I'll assume you meant f(x) = y, but none of what you have here makes any sense at all, I don't see how you get to f(y - 1) = x and g(x + 1) = x, and yes if they both equal the same value then you can equate them by something called the transitive property. Beyond this I have no clue about what you did here.
Ok, woops, f(x) = y, but then what value can be subbed into x? Didn't you do something like y = x + 1, let y = f(x), so by switching it around, you get x = y - 1. So then f(y - 1) = y, right?
Also, g(y) = x, so then what value can be subbed in for y here? Since y = x + 1, couldn't you sub in the value for y to get g(x + 1) = x?
Oh, and there's still part of one of my questions which remains unanswered(see beginning of last post).
First as to y = f(x) this is NOTATION, that means y is a function of x, I'll give an example
say f(x) = 3x2 + 17x3
I can substitute anything into f(x), like 1 and end up with a numerical answer so in this case f(1) = 20, you could also plug in u and get
f(u) = 3u2 + 17u3, I could even plug in "cat" and get something similar.
Your logic and math in this post is still very messy and rather illogical, but I think your problem is confusing notation.
This should take care of your other question as well, but all I did was to substitute u into make it a bit cleaner despite the fact that I will say this again that that is a really messy way of showing functions are inverses.
At some point, you must "switch y and x". I personally prefer to switch at the beginning. (So I won't forget at the end!) That's the whole point of "inverse function". If f is some function (such as x+ 1) the writing y= f(x) means: "if we apply the function f to the number x, the result is the number y". Specifically, if y= x+1 and x= 3 then y= 3+1= 4.
That is, the function changes the number 3 to the number 4. The inverse function must do the opposite; change the number 4 to the number 3.
Another way of look at it is to say that if we were graphing this function, we would plot points (x,y)= (x,f(x)) where the second number, y, is the number we get by applying f to the first number, x. The graph of y= f(x)= x+1 must contain the point (3,4) and so the graph of its inverse function, y= f-1(x) must contain the point (4,3). (The graph of y= f-1(x) has the nice geometric property that it is the reflection of the graph of y= f(x) around the line y= x.)
In order to find the inverse of y= f(x), a very basic method is: first switch x and y, x= f(y), and then solve for x. If f(x)= x+ 1, switch x and y to get x= y+ 1 and solve for y- subtracting 1 from both sides x-1= y so y= f-1(x)= x-1. N
"Switch x and y" is not one of the things you normally do while solving equations because the whole point here is not to get an "equivalent" equation, one satisfied by the same values, involving the same function, but rather to get an equation involving a new function, the inverse.
Another example: if f(x)= 3x-2 then y= 3x-2. Switch x and y to get
x= 3y- 2. Now solve for y: x+ 2= 3y so y= (x+2)/3. f-1(x)= (x+2)/3.
We've already pointed out that the inverse function to f(x)= x+ 1 is f-1(x)= x- 1 because f is just the "add one" function and "subtract one" is the opposite of that. This new example is just slightly harder than that. f(x)= 3x-2 says "first multiply x by 3 then subtract 2". The opposite of "multiply by 3" is "divide by 3" and the opposite of "subtract 2" is "add 2". To "undo" f, I have to do the opposite operations in the opposite order: first add 2 then divide by 3.
Finding the inverse function is exactly the same as solving the equation y= f(x). Of course, some equations, such as y= x2, can have more than one solution so have no inverse function.
I think I'm understanding most of this pretty well now but here's what I'm really wondering:
When you look at (x + 1) - 1 = x, d_leet assigned the variable u to (x + 1), I'm curious as to why you can do that in the first place. In an example like this, it may be easy to simply assign part of it a value like this, but what if the equation was much more complex than this? I don't know if you can simply assign part of it a value.
Why you can do it or why you want to do it? Obviously you can assign a single variable to anything you want. d_leet did that because the whole question was about the inverse of the function f(x)= x+ 1 and he wanted to single that out.
You could find the inverse of f(x)= x+1 by just solving for x:
Subtracting 1 from both sides, x= f(x)- 1. Remembering that the inverse function must satisfy f(f(x))= x, it is clear that the inverse function is "subtract 1". In "function notation", f-1(x)= x-1 where I have just replaced f(x) with x to get the standard notation.
Because it is simpler to manipulate a single letter than something like "f(x)", d_leet used u= x+1 instead of f(x)= x+1. Solving u= x+ 1 for x is easy: x= u-1 so f-1(u)= u-1 or, more standard notation, f-1(x)= x-1.
Because the most common notation is y= f(x), I personally would have used y instead of u: y= f(x)= x+1. Now, (again a personal choice) go ahead and switch x and y: x= y+ 1 (this is the step that changes the function to the inverse function). Solving for y, y= x- 1= f-1(x).
I don't know if you have read my last post, but I will repeat the part that is relevant to "what if the equation was much more complex than this? "
Suppose we want to find the inverse function to f(x)= 3x+ 2. Write this as y= 3x+ 2. (You say "I don't know if you can simply assign part of it a value." Yes, of course, you can. You can assign a variable to any part of anything!) Switch x and y to get x= 3y+ 2. Now solve for y: 3y= x- 2 so y= (x-2)/3. The inverse function is f-1(x)= (x-2)/3.
You could write 3((x-2)/3)+ 2= x or ((3x+2)-2)/3= x but you don't have to see that initially in order to find the inverse function.
An even more complicated example: [itex]f(x)= 5(2^{3x+2})- 7[/itex]. Write this as [itex]y= 5(2^{3x+2})- 7[/itex] and solve for x:
[tex]y+ 7= 5(2^{3x+2})[/tex]
[tex]\frac{y+7}{5}= 2^{3x+2}[/tex]
[tex]log_2\left(\frac{y+7}{5}\right)= 3x+2[/tex]
because [itex]log_2(x)[/itex] is the inverse of [itex]2^x[/itex].
[tex]log_2\left(\frac{y+7}{5}\right)- 2= 3x[/tex]
[tex]\frac{log_2\left(\frac{y+7}{5}\right)- 2}{3}= x[/tex]
Finally, since we didn't switch x and y to begin with, we need to do that in order to be able to write this in the "standard form":
[tex]f^{-1}(x)= \frac{log_2\left(\frac{x+7}{5}\right)- 2}{3}[/tex]
But say you didn't know what to single out, say you didn't know what the inverses were for (x + 1) - 1 = x, what would you do then? It's easy to single out a part of this equation, simply because we already know the inverses involved, but in a situation where you don't know the inverses, how would you determine what to single out?
"What the inverses were for (x+1)- 1= x" makes no sense. Functions have inverses. What you "single out" depends on what function you are talking about. You seem to think that you start with something like "(x+1)- x= x" and "single out" parts that make an inverse. You start with something like f(x)= x+ 1 and then show, as I have explained above, that f-1(x)= x-1. After you know the inverse, then you know that f-1(f(x))= x or, in this case, (x+1)-1= x. You also know that f(f-1(x))= x or, in this case, (x-1)+ 1= x.
