Volume of Revolution for Curve y=(12/(x + 3))- 4 Rotated about the y-axis
  • Thread starter Thread starter jack1234
    Curve Volume
The discussion centers on calculating the volume of revolution for the curve defined by the equation y=(12/(x + 3))- 4, specifically when rotated about the y-axis. The correct volume, as stated in the textbook, is 36π(1+2ln2). The user initially miscalculated the volume by considering the wrong region; they calculated the volume generated by the curve and the y-axis instead of the area between the curve and the line x=3. The error was identified as needing to subtract the volume of the region calculated from the volume of a cylinder with radius 3 and height 2.
  • Understanding of calculus concepts, particularly volume of revolution
  • Familiarity with the method of disks/washers for volume calculation
  • Knowledge of logarithmic functions and their properties
  • Ability to interpret and manipulate equations of curves
  • Study the method of disks for calculating volumes of revolution
  • Learn about the application of the washer method in volume calculations
  • Explore logarithmic identities and their applications in calculus
  • Practice problems involving volumes of revolution around different axes
Students and educators in calculus, particularly those focused on volume calculations, as well as mathematicians interested in geometric applications of integrals.
jack1234
The question is
Given a curve C whose equation is give by y=(12/(x + 3))- 4,
find the region bounded by C, the line x=0, the line x=3 and the line y=8 is rotated through 360 degree about the y-axis. Calculate the exact value of the volume generated.
My solution is here
http://www.geocities.com/myjunkmail31/Volume.jpg
However, this solution is not the answer in the textbook. The anwser in the textbook is
36pi(1+2ln2).
Can someone show me where am I doing wrong?
The error is in V1: Easy fix: [tex]V_1 = \pi 3^2 (2) - \pi (54 - 2 ln 2)[/tex].
The volume you calculated is that of the solid generated by rotating the region between the given curve and the y-axis about the y-axis, but you wanted to rotate the region between the given curve and x=3 about the y-axis. So just subtract what you got for V1 from the volume of the cylinder of radius 3 with height 2.
Awesome, very thanks=)
  • · Replies 20 ·
