Black holes & expanding universe
The discussion revolves around the behavior of black holes in the context of an expanding universe. Participants explore theoretical implications, potential interactions, and the nature of black holes under cosmological conditions, with a focus on concepts such as gravitational memory and the effects of cosmic expansion.
  • One participant questions whether the expansion of the universe would weaken interactions inside a black hole, potentially leading to an explosion when interparticle forces overcome gravitational forces.
  • Another participant asserts that black holes do not hold matter together and that the interior dynamics of a black hole are unaffected by the expanding universe.
  • A different viewpoint introduces the concept of "gravitational memory," suggesting that a black hole retains its effective gravitational constant from the moment of formation, which could lead to unusual effects over time.
  • Some participants express skepticism about the coexistence of black holes and scenarios like the Big Rip, suggesting they may be mutually exclusive.
  • One participant references advanced concepts, such as the Schwarzschild de-Sitter metric, to explain how black holes can exist in an expanding spacetime, noting that the event horizon may shift but does not preclude their existence.
  • There is mention of the complexities introduced by matter in an expanding universe, with some matter potentially falling into the black hole while others escape, leading to a dynamic situation that may eventually stabilize.
Participants express a range of views, with no consensus on how black holes interact with the expanding universe. Some ideas are contested, particularly regarding the implications of gravitational memory and the compatibility of black holes with scenarios like the Big Rip.
Limitations include unresolved assumptions about the nature of matter inside black holes, the effects of cosmic expansion on black hole dynamics, and the implications of gravitational constants over time.
ifarcas
Hello everyone. I'm a beginner with questions :rolleyes:
Can someone tell me what happens with black holes in an expanding universe? If the fabric of the universe is expanding wouldn't this result into weaker interactions inside the black hole up to the point when the black hole cannot hold the matter togeder? Wouldn't this result into a big explosion caused by interparticle forces overcoming the gravitational force? If so then wouldn't this contradict the idea that nothing escapes a black hole?
Thank you.
Black holes do not hold matter together, and there is probably no matter interaction inside a black hole. In fact nobody knows what happens to matter once it crosses the event horizon. So we certainly do not know what happens inside a black hole regardless of the expanding universe.
Besides, the expanding universe should have no effects on the interior dynamics of a black hole, just as the expanding universe has no effect on us or anything else.
On second thoughts, isn't there a thing as "gravitational memory"? If there is then surely the Black hole "remembers" it's effective gravitational constant at the instant it forms? Then it must remain constant at it's surface as it evolves in time. This would result in some strange things happening.
On the other hand, if the the grav. constant changes with time, then it must do so as to compensate for the expanding universe such that the size of the Black Hole can always be approximated by the formula R = 2GM. I think this sounds like a better explanation. But I am not sure if I can simply rule out that thing called "gravitational memory" (if it exists at all! Maybe someone can help there).
This is an interesting question though (modified): "What happens to a Black Hole in an expanding universe". Forget about the matter interaction and explosions and contradicting the fact that nothing escapes a Black hole and stuff; because it would not be a Black Hole if matter could exit it, would it!?
"because it would not be a Black Hole if matter could exit it, would it!?"
Yes this is exactly what I'm wondering myself. I can't see how a black hole could survive in an expanding universe (http://en.wikipedia.org/wiki/Big_Rip). IMHO black holes and Big Rip seem to be mutually exclusive. Or I'm missing something (beside knowledge :-p )?
At the most basic level, it might help to read and appreciate Ned Wright's cosmology faq
Why doesn't the solar system expand if the whole universe is expanding
On a more advanced level, black holes in an expanding space-time can be represented by the Schwarzscild de-Sitter metric.
http://arxiv.org/abs/gr-qc/0602002
if one goes to the limit of large times, corresponding to a low matter density, i.e. the "end stage" of an expanding universe where the matter density in free space is negligible.
One way of approaching the problem is to calculate the horizon from the resulting metric.
The horizon is located where the metric coefficient for time goes to zero. This traps photons as well, as can be seen if one knows about null geodesics. Photons always have an invariant interval dx^2 - c^2 dt^2 = 0 (in geometric units, used in this paper, dx^2 - dt^2 = 0).
This means that when the metric coefficient g00 goes to zero, one has the position of the horizon. (One can also have a horizon if g11 becomes infinite, but that doesn't apply in this case)
In schwarzschild geometry, this occurs when 1-2m/r = 0, i.e. when r=2m, which is the correct location for the horizon.
In the Schwarzschild de-Sitter geometry, this occurs when 1 - 2m/r - Lambda/r^2 = 0
where Labda is the cosmological constant of the de-Sitteer space-time. So it can be seen that there is no problem with black holes existing in a de-Sitter spacetime. The event horizon gets shifted a bit, that's the only effect.
Another way of approaching the problem is to realize that de-Sitter space is actually static, i.e. time invariant, if the proper coordinates are used. This is mentioned in the Wikipedia article on de-Sitter space (which is rather technical), and the original coordinates that de-Sitter used were in this form.
If one has a FRW expanding universe with matter present, the details will be more compex, due to the presence of matter as well as a cosmological constant. Some of the matter will fall into the black hole, some at a far enough distance will escape, making the initial problem dynamic. As time evolved, though, it will eventually settle down to a static solution. One complicating factor may arise if the black hole mass does not remain fninite. I think I recall reading about such concerns somewhere, by Baez, but I don't recall the details. If one assumes this doesn't happen, the result is fairly simple, a static black hole in a static Schwarzschild de-Sitter spacetime.
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 62 ·
10K
  • · Replies 20 ·
