Young's Experiment - (problem with equation)
  • Thread starter Thread starter FrogPad
    Experiment
The discussion centers on the equation for Young's double slit experiment, specifically the expression for calculating wavelength, λ = d sin θ / m, where d is the distance between slits, θ is the angle, and m is the order of the maxima. The confusion arises regarding the validity of this equation when m = 0, as it implies θ must also equal 0. It is established that the first maximum occurs at 0 degrees, making it impossible to determine the wavelength solely from the position of the central maximum.
  • Understanding of Young's double slit experiment
  • Familiarity with wave interference concepts
  • Knowledge of trigonometric functions
  • Basic grasp of wavelength and its significance in physics
  • Study the derivation of Young's double slit equation
  • Explore the implications of m values in wave interference
  • Research the significance of the central maximum in diffraction patterns
  • Investigate the relationship between wavelength and slit separation
Physics students, educators, and anyone interested in wave mechanics and optical phenomena will benefit from this discussion.
FrogPad
So my book has the following expression for Young's double slit experiment.
(maxima - bright fringes) [itex]d \sin \theta = m \lambda[/itex]
for [itex]m = 0, \, 1 \, 2 \, \ldots[/itex].So what if you solve this for wavelength.
[tex]\lambda = \frac{d \sin \theta}{m}[/tex]
How is this valid when [itex]m = 0[/itex]
Is this because if [itex]m = 0[/itex], [itex]\theta[/itex] HAS to equal 0?
by the way
d is the distance between the slits
theta is the angle from the central axis
lambda is the wavelength
m is the index of where the maxima occur
The first maximum is always at 0 angle regardless of wavelength. So you can't determine the wavelength from the position of the central maximum.
AM
