Thread Closed
Pulley Problem, 1 crate hanging, 1 crate on an incline
Share Thread Thread Tools
Sep24-06, 08:52 AM   #1
Here is a question that I am not sure where to start.
A block of mass m1 = 6.07 kg on a frictionless plane inclined at angle = 33.3° is connected by a cord over a massless, frictionless pulley to a second block of mass m2 = 2.46 kg hanging vertically (Fig. 5-54). (a) What is the acceleration of the hanging block (choose the positive direction up)? (b) What is the tension in the cord?
So far, I have drawn a free body diagram. I will call the crate on the incline m1, and the crate that is hanging m2. So to start, I have drawn a free body diagram. For m2, there is the weight of the crate (M x g), and the tension in the cord that is suspending the crate. Therefore, the tension should be equal to the weight of the box, correct? Next for m1, I altered the axes to corrsepond with the incline. The weight is still acting straight downwards, while the force that is sliding the crate down the incline is equal to (Weight x sin 33.3 degrees). There is also in the tension acting towards the edge of the incline which is opposite of the force acting down the incline. (?). So I have all of these forces, so to find the acceleration, do I simply add the weight of m1 and m2, and also add the tension of wire from the crate that is dangling, then use the mass of m2 to find the accleration? And for the second part of the question, I just unsure what to do, if i just add up the tension on the wire from crates m1 and m2? Thank you for the help
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep24-06, 09:24 AM   #2
Eds
Tension is less than weight of crate. You have 2 equations involving T and a:
Mg – T = Ma (for crate) &
T – mgsin(33.3°) = ma (mass on slope).
Now all you have to do is solve these 2 simultaneous equations for T & a. Don't you have any notes on this?
Thread Closed
Thread Tools
Similar Threads for: Pulley Problem, 1 crate hanging, 1 crate on an incline
Thread Forum Replies
Crate on an Incline Introductory Physics Homework 5
Hanging Crate Introductory Physics Homework 0
Reactions with crate and pulley Mechanical Engineering 1
friction and a crate Introductory Physics Homework 7
Crate being pulled Introductory Physics Homework 3
