Solve Vector Problem: Find Magnitude & Angle of A+B+C
  • Thread starter Thread starter mixedtape_15
    Vector
The discussion revolves around a vector problem involving the addition of three vectors A, B, and C, with the goal of finding the magnitude and angle of the resultant vector A+B+C. The vectors are defined with specific magnitudes and directions, requiring conversion from polar to rectangular coordinates.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the components of each vector and sum them to find the resultant vector. Some participants question the correctness of the component calculations, particularly the use of sine and cosine functions for the angles provided.
Participants are actively engaging in checking the calculations and providing guidance on the correct application of trigonometric functions. There is a recognition of a potential mix-up in the assignment of components, and one participant suggests reviewing the equations for accuracy.
The original poster expresses uncertainty about their calculations and has not yet attempted to find the angle of the resultant vector due to concerns about the accuracy of their previous work. There is an indication that the problem may involve common misconceptions regarding vector components.
mixedtape_15
I can't figure this out for the life of me.
Vector A = 7.00 m and points 40.0o north of east. Vector B = 3.00 m and points 20.0o west of north, and Vector C = 3.00 m and points 35.0o west of south.
What is the magnitude of the resultant vector A+B+C?
What angle does the resultant vector A+B+C make with respect to the east?
So I've drawn it out and everything and I'm solving for "D" and what I drew out was some weird quadralateral(sp?). Anyways I solved for each of the Vectors and got the X Components and the Y Components. And this is what I got.
A -> Ax = (7.0m)(sin(40 deg)) = 4.5m
Ay = (7.0m)(cos(40 deg)) = 5.4m
B -> Bx = (3.0m)(cos(20 deg)) = 2.8m
By = (3.0m)(sin(20 deg)) = 1.0m
C -> Cx = (3.0m)(sin(35 deg)) = 1.7m
Cy = (3.0m)(cos(35deg)) = 2.5m
So then I added all the x components and all the y components and got the x and y components for D.
Dx = 4.5m - 2.8m + 1.7m = 3.4 m
Dy = 5.4m + 1.0m + 2.5m = 8.9m
and then I used the pythagorean theorem to get D which would be
3.4^2 + 8.9^2 = D^2
D = 9.5m
and I thought that was my answer but its telling me it was wrong. So I didn't even attempt to get the angle because that will probably be wrong to.
So yeah can someone help me please o:)
Excellent job showing your work -- that helps a lot in our ability to help you.
I believe that you are just mixing up the N and E components a bit. You are using the correct method, of converting from the "polar" coordinates they give you into rectangular (E,N) or (x,y) components. Looking at your Ax,Ay conversion, I can see that you've got them backwards. Since they give you the vector A as pointing 40 degrees north of east, the x component will be the cos() term, and the y component will be the sin() term. Make sense?
Just run back through the equations and check the sin() and cos() terms. My guess is that you'll get it right.
Remember, you can solve this with a ruler and a protractor.
Thank you so much for the help. It really helped me to figure out where I messed up and after that it was pretty easy :D
11K
