3D shapes with perfect polygons
  • Context: Graduate
  • Thread starter Thread starter scott_alexsk
    3d Polygons Shapes
The discussion revolves around the formation of 3D shapes using regular polygons, specifically focusing on the minimum number of polygons required to create a complete 3D shape. Participants explore the angles involved in fitting polygons together and the limitations of using regular polygons beyond certain types.
  • One participant, scott, questions the angle at which three pentagons must be positioned to form a 3D shape and proposes an assumption of 12 degrees for further calculations.
  • scott estimates that a pentagon would require around 80 faces to form a 3D shape, raising questions about the validity of this estimate.
  • Another participant notes that there are only five convex polyhedra that can be formed from congruent regular polygons, referencing Platonic solids.
  • scott seeks clarification on the specific angle needed for three corners of a pentagon to fit together, indicating a need for a more precise calculation.
  • A participant suggests looking up the "dihedral angle" for relevant expressions related to polygon angles.
  • There is mention of Archimedean solids, which can be formed using more than one type of regular polygon, expanding the possibilities for 3D shapes.
Participants generally agree on the limited number of convex polyhedra formed by regular polygons, but there is ongoing uncertainty regarding the specific angles and calculations needed for pentagons and other polygons to create 3D shapes.
Participants express uncertainty about the assumptions made regarding angles and the calculations involved in determining the number of faces required for various polygons to form 3D shapes.
scott_alexsk
Hello, (edit should be regular polygons in title)
I have been thinking a lot recently about 3D shapes formed by 2D regular polygons. I was asking myself if there would be any way to calculate the minimium number of regular polygons to form a complete 3D shape. It is fairly easy with an equilateral triangle, which requires 4 sides, and for a square, with 6, but when I got to pentagons many problems arised.
For one I was trying to calculate the angle the corners of 3 pentagons would have to be placed up agaisnt each other relative to a plane (see drawing). I ended up just assuming that the angle was 12, though I really have no idea, and continued with my estimates. So assuming that x (in the diagram) is 12 degrees, then I can calculate that the angle of each face to the other is about 156 degrees. With 156 I found the number of sides of a ploygon with those angles to be 15. From there I guesstimated that a pentagon forming a 3D shape by itself must have a minimum of around 80 faces.
Now I have several questions. Is my assumption that the angle x is 12, correct, if not how do I preform a correct calculation? Also what is the true number of sides a regular pentagon must have to form a 3D shape? Is there an equation which can identify the number of faces required for certain polygons to form 3d shapes? Finally, is there any way a single regular ploygon can approminate a sphere? Beyond a hexagon it is impossible to form 3D shapes since the measure of internal angles goes beyond 120, which means 3 corners cannot intersect.
Thanks,
-scott
Hopefully you can read this.
Mathematics news on Phys.org
Yeah, I knew there would be only a few. But I still have one question. What is the angle that 3 corners of a pentagon have to be bent relative to a plane, (see drawing) to fit together?
Thanks,
-scott
I can't see the drawing because it hasn't been approved yet :-p. If you're talking about the angle I assume you're talking about then there is an expression for it on that page (search for "dihedral angle").
Thanks for the links and info Data.
-scott
Data said:
The number of (convex) polyhedra you can get out of congruent regular polygons is quite limited (there are only 5).
http://en.wikipedia.org/wiki/Platonic_solid.
If you allow more than one type of regular polygon, you can get a few more. Look up: Archimedean solids.
  • · Replies 19 ·
  • · Replies 24 ·
10K
