Maximizing Limits and Integrals: Solving Three Challenging Problems
  • Thread starter Thread starter MathematicalPhysicist
    Integrals Limits
The discussion revolves around three mathematical problems involving limits and integrals. The subject area includes analysis, specifically focusing on the evaluation of limits and the properties of definite integrals.
  • Mixed
  • Participants explore the evaluation of limits using Riemann sums and question the correctness of their approaches. There is also discussion on the application of integration by parts and the use of dummy variables in integrals.
Some participants have provided their answers to the limit problems, while others are seeking clarification on their reasoning and methods. Hints have been offered regarding the differentiation of functions defined by integrals, but no consensus has been reached on the third problem's approach.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is an emphasis on understanding the reasoning behind the steps taken in their solutions.
i have three questions:
1) find the limit of [tex]b_n=\frac{1}{\sqrt n^2}+\frac{1}{\sqrt(n^2-1)}+...+\frac{1}{\sqrt(n^2-(n-1)^2)}[/tex]
2) if a is any number greater than -1, evaluate [tex]\lim_{n\rightarrow\infty} \frac{1^a+2^a+...+n^a}{n^{a+1}}[/tex]
3) prove that [tex]\int_{0}^{x}[\int_{0}^{u}f(t)dt]du=\int_{0}^{x}f(u)(x-u)du[/tex]
for the first i got: half pi, and for the second question i got 1/(a+1) is this correct?
for the third question, here's what i did:
[tex]\int_{0}^{x}u'[\int_{0}^{u}f(t)dt]du=[\int_{0}^{u}f(t)dtu]_{0}^{x}-\int_{0}^{x}uf(u)du[/tex] now my question is can i use here a change of dummy variable here for the first integral, from f(t)dt to f(u)du and to get the equality?
no one has got anything to say?
How did you get the first one?
i used riemann sums here, we have the sum:
[tex]\sum_{k=1}^{n-1}\frac{1}{n}\frac{1}{\sqrt{1-(\frac{k}{n})^2}}+\frac{1}{n}[/tex]
is this correct?
Your first two answers look good.
For the third, I can't make sense of what you've done. What is u'?
Heres a hint:
Define the functions F and G as
[tex]F(x) = \int_{0}^{x} \left( \int_{0}^{u} f(t)dt \right) du[/tex]
[tex]G(x) = \int_{0}^{x}f(u)(x-u)du[/tex]
Find the derivatives of F and G with respect to x. Deduce from this that there is a constant C such that F = G + C.
u' is the derivative of u wrt u.
i.e du/du=1.
Oh I see, you used the product rule (integration by parts). That'll work too!
Sure, you can always substitute the dummy variable so long as its different from the one used for the limit of integration, so in this case you'd have to first evaluate the expression,
[tex]\left[ \int_{0}^{u}uf(t)dt \right]_{0}^{x} = \int_{0}^{x} x f(t)dt[/tex]
and then make the substitution.
  • · Replies 16 ·
