The acceleration of a particle on a horizontal xy plane
The problem involves determining the position vector and the angle of a particle moving on a horizontal xy plane, given its acceleration, initial position, and velocity. The acceleration is defined as a function of time, and the task requires integration to find the position and velocity at a specific time.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss integrating acceleration to find velocity and position, with some questioning the introduction of additional variables like theta. There is also mention of applying the dot product to find the angle between the direction of travel and the x-axis.
The discussion is active, with participants sharing their approaches to integration and initial conditions. Some guidance has been offered regarding the integration process and the use of initial conditions, but there is no explicit consensus on the best method yet.
Participants are navigating the integration of functions and the implications of introducing new variables. There is an emphasis on maintaining clarity in the problem-solving process without overcomplicating the equations.
kara
The acceleration of a particle on a horizontal xy plane is given by a=3ti + 4tj, where a is in meters per second-squared and t is in sec. At t=0, the particle has the position vector r=(20.0m)i + (40.0m)j and the velocity vector
v=(5.00m/s)i +(2.00m/s)j. At t=4.00 s, what are its position vector in unit-vector notation and the angle between its direction of travel and the positive direction of the x axis?
I have no idea what to do at all https://www.physicsforums.com/images/smilies/surprised.gif
Find the general equations for position and velocity by integration and use the initial conditions.
"the angle between its direction of travel and the positive direction of the x axis"
For that you can apply the dot product.
so would i integrate a to find position and then velocity?
You integrate acceleration to find velovity, and then integrate velocity (after plugging in the initial condition) to find position.
alright so i got:
dx = 1.5t^2 + vcos0t + 20
dy = 2t^2 + vsin0t + 40
where the 0 is theta
kara said:
alright so i got:
Bringing in new variables (such as theta) without any need will just make the answer more complicated.
Here's an example on how to go about the problem:
[tex]\frac{dv_x}{dt} = 3t[/tex]
[tex]v_x = \frac{3}{2}t^2 + C[/tex] (C is the constant of integration)
Now put in the initial condition, the value for v_x when t = 0 and find the value for C. Similaraly find v_y. The process is the same for finding position.
You can be a bit more formal and use [tex]\vec{v}(t) = \int \vec{a}(t)dt + \vec{v}_{0}[/tex], i.e. [tex]\vec{r}(t) = \int \vec{v}(t)dt + \vec{r}_{0}[/tex], but basically that's the same thing Neutrino wrote.
