Thread Closed
Pressure and depth problem
Share Thread Thread Tools
Feb3-04, 08:41 PM   #1
I would like someone to tell me the steps for working out this problem. Specifically I would like to know the Equations needed to use for the problem.
Here is the problem. It seems very simple, but I seen to get lost in converting SI Units and then I get confused.
A Piece of wood is 2cm X 4cm X 2mm. It has a density of 450 kg/m/m. To what Depth will it sink in water?
Anyhow, I dont know exactly what to do. I found the Volume in Meters but I have no clue if it is correct. So I then found the mass from the Density and Calculated Volume. I plug the Volume in the Bouyant Force Equation, then I find the Force of weight of the object. What do I do next? Do I find the apparent Force and divide it by Volume? I have no Idea how to find the Depth. I would like a good Explanation as well. Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb4-04, 05:12 AM   #2
Is density 450kg/m^3?
We don't know your object's rotation? On which side is it sinking?
Since G=F_b
[tex]
V_{sunk}d_{fluid}=V_{object}d_{object}
[/tex]
As you will see the volume under water is the same no matter its rotation.
Thread Closed
Thread Tools
Similar Threads for: Pressure and depth problem
Thread Forum Replies
Absolute pressure at an ocean depth Introductory Physics Homework 1
Static Equilibrium in Fluids: Pressure and Depth Introductory Physics Homework 4
Pressure as a function of depth Introductory Physics Homework 5
Water depth pressure against air pressure Classical Physics 1
absolute pressure. depth Introductory Physics Homework 1
